O-K, I got up early this morning and fired Brutus up. Jacked up the front and did the left and right thing and pumped the brakes. It's quite a bit better, but still a faint moan. I am confident that it will be fine. Thanks again for all the help.
O-K, another question: While playing with things, I was trying to loosen up the valve on the hose for the heater under the couch. While working it the soldered in nipple came out of the housing of the heater. It really doesn't look like a very good joint to begin with as it appears to simply solder up to a hole in the side of the box without any kind of a flange. If pressurized water from the radiator goes through this, I would think it would be attached better. Am I o-k to simply solder this back on?
JB
86' 345 MH. Named "AirBus". The wife and I finally agree.
