12-07-2008, 03:12 PM
Richmond
, Kentucky
Power steering powered wiper motor?
While poking around an old mid 70s Revcon Motorhome I noticed that the wiper motor was not the typical one I've seen on other Motorhomes including our Classic Motorhomes.
I had never heard of this arrangement before. Is it a dependable and reliable system? My guess is its probably a bit more expensive to install and I wonder how it would operate while turning and braking at the same time?
Just curious.
1975 24' Argosy Motor Home
12-07-2008, 03:36 PM
2002 31' Classic
Ozark
Brad, How bizzzare! Charles said it should break the arms on an Icy windshield!
John B
12-07-2008, 03:40 PM
Richmond
, Kentucky
John B
I hadn't thought about the wiping power that would be involved using the power steering hydraulics. Maybe I aught to go back and pull that wiper motor!
12-08-2008, 12:55 AM
Salem
Hydraulic wipers
Hi, back in the early seventys Lincoln Mark III's had hydraulic wipers. They worked very well and had about 15 speeds. The only draw back that I found back then was the fact that on the inlet side of the wiper motor was a filter screen; Most people didn't know about the filter and when it got clogged up [very rare] the wipers and power steering would be weak.
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
12-08-2008, 01:05 AM
, At Large
Brad, did you follow the lines to the pump? I've seen wiper motors, especially on medium duty trucks, with vacuum-powered wipers.
12-08-2008, 11:58 AM
Richmond
, Kentucky
Terry,
I followed the lines down to the lower left front area of the engine. The lines appeared to be high pressure lines that connected to the wiper motor. When I first saw the arrangement I thought it was a vacuum arrangement. But after looking closer at the high pressure lines and where they were routed I decided it was operated from the power steering pump.
After having vacuum wipers on my first car (1955 Olds Delta 88 Deluxe) I decided I never wanted to use vacuum wipers again, especially in the winter in Nebraska!
12-08-2008, 12:00 PM
Richmond
, Kentucky
How was the speed adjusted from inside the car?!
12-08-2008, 12:26 PM
1965 17' Caravel
1983 27' Excella
Walnut Grove/Laguna Woods
There will be one high pressure line, and one return line, just like the power steering unit.
My 1972 Chevy "Snap-On" truck had power brakes that were powered in the same way.
12-08-2008, 01:02 PM
, At Large
Jim, do you know if that was a Hydroboost or Hydravac system? Not that it matters in this discussion, just curious.
12-08-2008, 01:21 PM
1965 17' Caravel
1983 27' Excella
Yes, I think it was a Hydroboost, but I can't tell you for sure. Too many miles under the wheels since then.
12-08-2008, 01:31 PM
1965 17' Caravel
1983 27' Excella
Just did a little search. Yes, it was a Hydro-boost. Worked just fine. They are used extensively on vehicles such as diesels which have no vacuum. My truck was gas, but I think it was used there as it could be placed sideways. The hood on that truck was very short.
12-08-2008, 01:54 PM
1979 23' Safari
1954 29' Liner
Orange
My 1977 Lincoln Continental has the same system for the power brakes.
Bill
Just my personal opinion
12-08-2008, 02:37 PM
, At Large
Bill
IIRC, your Continental also had something called "Anti-Skid" as an option. It was the first ABS system I am aware of, available from 1975-77 on higher-end models such as Grand Marquis, LTD Brougham, Town Car, and Continental.
Boy, we've dragged this thread way off topic, from power windshield wipers to ABS systems...
12-08-2008, 02:44 PM
1979 23' Safari
1954 29' Liner
Orange
Terry,
You are somewhat correct, in that I believe that the "Anti-Skid" option was available only with rear disc brakes. Perhaps standard on the Marks, since I think that they had rear disc brakes. My Lincoln has drums on the rear.
Bill
12-08-2008, 10:46 PM
Salem
More information?
Hi, on the dash board was an ordinary wiper knob that turned on the wipers; It had several detents in the switch and each detent was a diffferent speed.
Hi, Hydro boost and hydaulic wipers worked from the power steering pump pressure. On 462 Lincolns the pump was mounted to the timing cover and turned directly from the crank shaft
Hi, my Mac Tools truck in 1986 built on a GM P-30 chassis with a Grumman Olsen body had hydro boost power brakes, and it was also a gas engine.
Hi, the early Ford/Lincoln ABS system was called "Sure Track"; It had a control module under the dash and a second vacuum booster and master cylinder mounted, on the frame, under the A/C evaporator case.
12-08-2008, 11:01 PM
Salem
Hi, looking at the picture, the main body of this wiper motor looks very much like a vacuum motor, but vacuum wipers only had one small vacuum hose connected to it instead of the two larger hydraulic hoses. Also the cable connection from the in-dash switch is the same set up for both type motors.
12-08-2008, 11:10 PM
1978 31' Sovereign
Scottsdale
The 1966 T-bird had wipers operated with fluid from the power steering pump. I would guess that the '64 and '65 did also. The control was a lever that could be position anywhere from off to full on.
Harry W
4CU Charter Member
AIR # 13858, WBCCI # 2420
12-24-2008, 04:29 PM
2008 28' International
Palm Springs
My 1965 Lincoln Continental had the same set up as your T-Bird. It was a fully variable speed control and very reliable..no leaks or mechanical problems during the time I had the car.
