Old 12-07-2008, 03:12 PM   #1
Power steering powered wiper motor?
While poking around an old mid 70s Revcon Motorhome I noticed that the wiper motor was not the typical one I've seen on other Motorhomes including our Classic Motorhomes.
Name:	power steering powered wiper motor.jpg
I had never heard of this arrangement before. Is it a dependable and reliable system? My guess is its probably a bit more expensive to install and I wonder how it would operate while turning and braking at the same time?
Just curious.
Old 12-07-2008, 03:36 PM   #2
J&C
J&C's Avatar
2002 31' Classic
Hillsboro , Texas
Images: 11
Brad, How bizzzare! Charles said it should break the arms on an Icy windshield!
John B
J&C is offline   Reply With Quote
Old 12-07-2008, 03:40 PM   #3
John B
I hadn't thought about the wiping power that would be involved using the power steering hydraulics. Maybe I aught to go back and pull that wiper motor!
Old 12-08-2008, 12:55 AM   #4
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hydraulic wipers
Hi, back in the early seventys Lincoln Mark III's had hydraulic wipers. They worked very well and had about 15 speeds. The only draw back that I found back then was the fact that on the inlet side of the wiper motor was a filter screen; Most people didn't know about the filter and when it got clogged up [very rare] the wipers and power steering would be weak.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 12-08-2008, 01:05 AM   #5
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Brad, did you follow the lines to the pump? I've seen wiper motors, especially on medium duty trucks, with vacuum-powered wipers.
Old 12-08-2008, 11:58 AM   #6
Terry,
I followed the lines down to the lower left front area of the engine. The lines appeared to be high pressure lines that connected to the wiper motor. When I first saw the arrangement I thought it was a vacuum arrangement. But after looking closer at the high pressure lines and where they were routed I decided it was operated from the power steering pump.
After having vacuum wipers on my first car (1955 Olds Delta 88 Deluxe) I decided I never wanted to use vacuum wipers again, especially in the winter in Nebraska!
Old 12-08-2008, 12:00 PM   #7
How was the speed adjusted from inside the car?!
Old 12-08-2008, 12:26 PM   #8
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
There will be one high pressure line, and one return line, just like the power steering unit.
My 1972 Chevy "Snap-On" truck had power brakes that were powered in the same way.
Old 12-08-2008, 01:02 PM   #9
Well Preserved
1993 21' Sovereign
Jim, do you know if that was a Hydroboost or Hydravac system? Not that it matters in this discussion, just curious.
Old 12-08-2008, 01:21 PM   #10
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
Yes, I think it was a Hydroboost, but I can't tell you for sure. Too many miles under the wheels since then.
Old 12-08-2008, 01:31 PM   #11
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
Just did a little search. Yes, it was a Hydro-boost. Worked just fine. They are used extensively on vehicles such as diesels which have no vacuum. My truck was gas, but I think it was used there as it could be placed sideways. The hood on that truck was very short.
Old 12-08-2008, 01:54 PM   #12
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
My 1977 Lincoln Continental has the same system for the power brakes.
Bill
Just my personal opinion
Old 12-08-2008, 02:37 PM   #13
Well Preserved
1993 21' Sovereign
Bill
IIRC, your Continental also had something called "Anti-Skid" as an option. It was the first ABS system I am aware of, available from 1975-77 on higher-end models such as Grand Marquis, LTD Brougham, Town Car, and Continental.
Boy, we've dragged this thread way off topic, from power windshield wipers to ABS systems...
Old 12-08-2008, 02:44 PM   #14
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Terry,
You are somewhat correct, in that I believe that the "Anti-Skid" option was available only with rear disc brakes. Perhaps standard on the Marks, since I think that they had rear disc brakes. My Lincoln has drums on the rear.
Bill
Wiper Motor Pivot Shaft realpank Argosy Motorhomes 3 08-05-2008 06:35 AM
Wiper motor park position on Classic mh bkahler Mechanics Corner - Engines, Transmission & More... 4 09-20-2007 09:18 AM
1978 Argosy 28' Windshield Wiper Motor Replace/Repair? joshw Argosy Motorhomes 8 07-12-2007 07:26 PM
82' MoHo windsheild wiper motor realpank Classic Motorhomes 5 12-14-2006 11:57 AM
Wiper motor arm assembly question? Paul J Mauro General Motorhome Topics 4 10-16-2005 06:31 AM
