Old 06-27-2016, 03:47 PM   #1
1979 24' Airstream Excella 24
Forlė , Italy
please help me, fuel pump replacement
Good morning Airstreamer!I've a problem on my MH Excella 245 (1979) . I ask a suggestion. I have broken the mechanical pomp of the gasoline, you recommend me one of exchange mechanics or electric and what type?
Grazie , ciao Cesare
Gocart is offline   Reply With Quote
Old 06-27-2016, 03:51 PM   #2
CRH
1995 25' Excella
xxxxx , xxxxxx
I would replace it with a mechanical just like what's on it.
CRH is offline   Reply With Quote
Old 06-27-2016, 04:30 PM   #3
Waipio Rim's Avatar
1984 31' Airstream310
Honokaa , Hawaii
Keeping the fuel pump pushrod up in place can make installation of a mechanical pump difficult. Some blocks have a bolt in the front that you can take out, and install a longer bolt to hold the pushrod up. Make sure to replace that bolt with the short one after the pump is in. If there is no bolt, use grease on the end of the pushrod to hold it in place.
Waipio Rim is offline   Reply With Quote
Old 06-28-2016, 06:38 AM   #4
Forlė , Italy
thanks for the info.....Ciao Cesare
Old 06-28-2016, 06:43 AM   #5
87MH's Avatar
1978 31' Sovereign
Images: 292
My Opinion - Go Electric
Gasoline likes to be pushed and not pulled.
Easy install on an electric pump as close as possible to the fuel tank.
The longer MoHo's of the mid to late 80's had two fuel pumps, an electric at the tank and the engine mechanical pump.
If you bypass the mechanical a good electric pump should have no problem at all supplying gasoline to the carb.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Old 06-29-2016, 03:31 PM   #6
Forlė , Italy
thanks for the information.Near the mechanical I've installed a pomp from 15 gals / H but in the roads in slope he doesn't send gasoline to the carburetor and the motor he extinguishes.Now I have found these technical cards, I will try again.
sorry for my english!!
Ciao Cesare dall'Italia
ID:	265531   Click image for larger version
ID:	265533   Click image for larger version
Old 06-29-2016, 06:04 PM   #7
Waipio Rim's Avatar
Honokaa , Hawaii
Another cause for vapor lock not mentioned in your reference document is the hard fuel line going from the mechanical fuel pump to the carburetor. I solved our vapor lock problems by insulating that line with header wrap. The line is subject to extreme heat because of its location.
Old 06-30-2016, 08:29 AM   #8
Forlė , Italy
Hi Waipio
I will also do that.
Grazie , Cesare
Old 08-01-2016, 03:36 PM   #9
1999 33' Land Yacht
Pooler , Georgia
Have a 1999 Land Yacht 33' with a Onan 7000 gen. Has anyone changed the fuel pump ? Does unit have to be dropped ?
Thks
Cobia13 is offline   Reply With Quote
Old 08-02-2016, 11:36 AM   #10
Boom Sounds's Avatar
1991 25' Airstream 250
Oxford , Oxfordshire
The unit will almost certainly have to be dropped. Check out a proper chevvy service repair manual which are available if you google it.
What makes you think you have a bad pump? Have you measured the fuel pressure?
Boom Sounds is offline   Reply With Quote
HELP: Onan BF fuel pump - kit / schematics MrJ Mechanics Corner - Engines, Transmission & More... 1 03-03-2012 01:52 PM
Fuel Line & Fuel Tank crazeevw Mechanics Corner - Engines, Transmission & More... 4 12-02-2011 07:38 PM
YAHAMA 2400 help with pictures please! TRI FUEL CONVERSION!!! sandiegoguy Generators & Solar Power 3 09-21-2011 08:38 AM
Help please re: ultra low sulfur diesel fuel! Wingeezer Tow Vehicles 17 02-09-2009 06:45 AM
Electric fuel pump and fuel line routing cooperhawk Mechanics Corner - Engines, Transmission & More... 7 02-06-2003 10:16 AM
