Old 09-18-2015, 04:15 PM   #1
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
Please help identify plug and relay
the plug is just forward of the carb and the relay is mounted at the rear of the drivers side valve cover. This engines has been converted to EFI, so I wonder what the original purpose was?
ID:	248411   Click image for larger version
1991 25' Excella Trailer
1990 25' Excella Trailer
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Old 09-18-2015, 05:10 PM   #2
Peter, I found that same relay on the 1986 345 that I dismantled. I did some research and the best I could come up with is the relay is used as part of the emissions system. I don't remember exactly what as I had no plans to use it on my Argosy.
Hopefully someone more knowledgeable will chime in with info.
Old 09-18-2015, 05:12 PM   #3
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
It is/was part of the AIR system. I remember it would actuate the valve that sat at the end of the injection tubes.
Old 09-18-2015, 05:17 PM   #4
Terry, that makes sense. That 345 did have the air injection system.
Old 09-18-2015, 06:11 PM   #5
Airstream Driver
1997 30' Excella
Images: 51
thanks Terry and Brad, always can count on the guys with the experience.
One side of the plug is hot with ignition on, just dangling on top of the engine. I guess I can carefully remove everything related to that.
AIR #13
Old 09-21-2015, 09:35 PM   #6
1982 28' Airstream 280
Redwood City , California
Peter, I can't get the pic to display right now, but I believe I have the same "relay" on my '82 ('81 chassis). I also tried to figure out what the heck is is for. I do believe it has something to do with the emissions. I think one of the wires from the distributor electronics runs to it and I thought it did something based on engine rpm. I wish I knew as well. Of course here in Calif I have to keep all emissions equipment in working order as to be able to smog the MH every two years.
"We are free to go where we wish and to be what we are"
Richard Bach, Jonathan Livingston Seagall
dadstoy is offline   Reply With Quote
Old 09-21-2015, 09:49 PM   #7
1974 Argosy 20
Kooskia , Idaho
It also could be something used if the original choke stove was converted to an electric choke. That had not been done on my AS 310, but had been done on my GMC motorhome with the 455 Olds engine and Q jet.
Old 09-21-2015, 10:57 PM   #8
1968 24' Tradewind
1967 17' Caravel
Northborough , Massachusetts
Might have never been used...
Open the hood of any new vehicle and you will generally see several unused connectors. Depending upon what options were ordered (or not).
Even more if you look under the dash or at the wiring harness...
Chuck
cwbiii is offline   Reply With Quote
Please help me Identify my Airstream Model and year. ulia86 1966 - 1969 Ambassador 6 11-21-2012 08:54 PM
Please help me identify what model this is freeofecho Our Community 9 10-22-2010 07:12 AM
Help Identify my new trailer please kstampa Vintage Kin 10 06-05-2010 08:18 AM
Airstream or not? Please help IDENTIFY! fcavolijr General Motorhome Topics 20 09-22-2009 10:49 AM
