Old 07-11-2009, 07:34 PM   #1
swanky's Avatar
Grosse Pointe Park , Michigan
Picture of the brackets
I posted this under Classics but I think it's better here. Anyone have these installed? If so, did you work from a service bulletin from AS? My truck shop would prefer to work from some sort of documentation but AS has not gotten back to me on that request. The fact that the factory just left them in the camper without telling me about them makes me think that they wanted the tranny repair guy to use them, but he didn't notice them until too late.
He said they will need holes bored into them and holes bored into wherever they go--he thought a couple hours would do the trick. I plan to have this done when I take the old girl in for her alignment check and inspection.
The part numbers are on there and they are marked for left and right. My search for the part numbers didn't get me anywhere.
ID:	83791   Click image for larger version
ID:	83793   Click image for larger version
Audrey
1982 280 Turbo Diesel Limited
Classic Motorhome
"A Silver Lining" or Silvie for short
"Ah, well. I'm off to get my life sustaining supplies - cornmeal and gunpowder, hamhocks and guitar strings."
swanky is offline   Reply With Quote
Old 07-11-2009, 07:45 PM   #2
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Question
Are they bell housing supports for a GM tranny?, Workhorse chassis, if so a dealer my be able to supply the needed documentation from the stamped numbers.
W. H. Auden
"The hardest thing about Airstreaming, clearing your head and accepting how others feel it’s supposed to be done"…..
Amanamus
"Tahawus"
Old 07-11-2009, 08:55 PM   #3
swanky's Avatar
That's the problem, I have no idea. They just showed up in the coach when it was taken from the Airstream Factory to the trans repair shop. That guy said they would help prevent tension on the flex plate--I think. It was chaotic, I'd been up for two nights, I had just written a big, fat check to the guy...I really didn't get everything he was telling me. If AS doesn't get back to me, I'll just go up to the truck shop and see if they can figure it out by looking at them. Thanks,
Audrey
Classic Motorhome
Old 07-12-2009, 01:12 AM   #4
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, on the castings it says THM for Turbo-Hydra-Matic and 400 - 475. The 475 is the truck version of the Turbo 400.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 07-12-2009, 07:25 AM   #5
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
That's what I got out of the numbers at first glance. Swanky ,they are RIGHT and Left So warn your truck shop tech. guy.
Roger
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
May your roads be straight and smooth and may you always have a tailwind!
Mikethefixit is offline   Reply With Quote
Did you install the aluminum brackets? swanky Classic Motorhomes 4 07-17-2009 05:43 PM
Source for AC and PS Brackets guy99 Mechanics Corner - Engines, Transmission & More... 21 12-07-2008 10:28 AM
Wall tracks/ brackets firelily007 General Repair Forum 2 04-17-2008 03:09 PM
Need Window Awning Brackets RBolton Awnings 3 08-01-2007 12:13 PM
Need bunk bed brackets Safari Tim Cabinets, Counter Tops & Furnishings 8 05-01-2007 11:20 PM
