Old 10-18-2015, 12:15 AM   #1
german6563's Avatar
1977 24' Argosy 24
Hilden , NRW
Parking Brake Cable
Hello everyone
yesterday trying to fix the brakes I realized that the emergency brake cable is badly corroded and not working. I started to search google where I can buy but there are different cables. any of you know the parts number of the cable? (My Argosy is 24 feet in 1977) a my cable measures about 2.5 meters long. is the cable running from the front to the separation and each rear wheel
thanks for the help
Herman
german6563 is offline   Reply With Quote
Old 10-21-2015, 09:21 PM   #2
Rivet Loser
Punch's Avatar
La Ronge , Saskatchewan
Hallo Herman.... here is a possibly helpful link:
77 1977 Chevrolet P30 Parking Brake Cable - Brake - Dorman, Wagner, Front, Intermediate, Rear, Rear Left, Rear Right - PartsGeek
There are some useful pictures, if you have the old cable in front of you.
Do you have this manual?
73-87chevytrucks.com/techinfo/7387CKMans//Service/ST_330_76_1976_Chevrolet_Light_Truck_Service_Overh aul_Supplement.pdf
or this one
ourgosee.com/wp-content/uploads/2014/07/1975-Argosy-Owners-Manual-Small.pdf
Vielen Glück!
1989 345LE
Punch is offline   Reply With Quote
Old 10-22-2015, 10:44 AM   #3
german6563's Avatar
1977 24' Argosy 24
Hilden , NRW
hello Punch
thanks for the help about the link , unfortunately, do not send the parts to Germany, I have followed this issue, when I need something for my Argosy, most companies do not send to Europe, only USA
and thank for the manual
Herman
Old 10-22-2015, 06:46 PM   #4
Rivet Loser
Punch's Avatar
Originally Posted by german6563 View Post
hello Punch
Herman
At least maybe you can find out which cable you need? Then find another supplier.
Another possibility would be to take the old cable to someone in your area who makes up cables. That would be quite easy here, but I don't know about Germany.
Thirdly, I would be happy to have them come here, then I would send them to you in Germany, but usually the cost of shipping to Canada is very high, and then cost to send to Germany would be high......
1989 345LE
Old 10-24-2015, 12:56 AM   #5
german6563's Avatar
1977 24' Argosy 24
Hilden , NRW
Punch through.
I'll take your idea to get someone here that you can play.
For your information, not just discriminate against sending Europe, but also Canada, Alaska, etc, would the world
Herman
Old 10-25-2015, 09:05 AM   #6
Rivet Loser
Punch's Avatar
Punch through.
Herman
Herman, if you are near to the sea or a big lake where people use power boats and yachts, then any marina with a good service department should be able to make up cables, or would know how to have it done.
Man braucht nur die Enden und die Länge.
1989 345LE
Old 10-25-2015, 10:27 AM   #7
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
I am sure one of us would happily take delivery of a cable and then forward it on to you. But the issue is identifying the cable. You need to know the detail of the fittings at each end, and an exact length (fitting to fitting) as there are many many different ones available; if you check out the Rockauto website for a 1977 454 P-30 you will see.
From your description, none of these are 2.5m, the closest is 87.25in or approx 2.2m
https://www.rockauto.com/catalog/mor...nid=504&jpid=3
That cable is currently $9 from RockAuto so very inexpensive....if it is the correct cable for you.
martin300662 is offline   Reply With Quote
Old 10-26-2015, 12:32 PM   #8
german6563's Avatar
1977 24' Argosy 24
Hilden , NRW
Thanks Martin for the tip, they sent to Germany, but I forward the idea of Punch, I got a company that makes cables for boats and they told me there was no problem, I hope to have it ready this week
thank you all for the help they have given me
Herman
Old 10-26-2015, 07:09 PM   #9
Rivet Loser
Punch's Avatar
Klasse!
1989 345LE
Coax Cable for Outside Cable Connection Frank&Mike Audio, Video & TV 7 12-17-2012 08:16 AM
Courtesy parking or rental parking needed, Perris Valley, California skydiva Our Community 1 01-13-2011 06:13 PM
Should I get a parking brake on my new axle? FrenchBern Brakes & Brake Controllers 8 05-12-2007 04:33 AM
parking brake remcolent Brakes & Brake Controllers 5 03-24-2007 08:31 AM
parking brake on trailor remcolent Brakes & Brake Controllers 1 01-02-2004 09:01 PM
