Old 06-04-2014, 02:59 AM   #1
MrJ
MrJ's Avatar
1976 28' Argosy 28
Dallas , Texas
P30 Ball Joints - which ones?
I have a bad lower ball joint I need to replace. Should I replace all the ball joints? Don't want to spend $350 if not needed though. But worn tires are not cheap.
I'm seeing all types of stuff about 11,000 rear Axle, 14,000 GVW, etc. Some say motorhome, sometimes not. Between NAPA, Autozone, and O'Riley it's getting confusing.. I've found their parts lists are wrong sometimes. Depending on who you get at the counter, it's a crap shoot.
I'm going to assume the 20-30$ parts would not be ideal VS the 60-80$ versions..
Lowers NAPA: I think this will work, seems quality?
NAPA AUTO PARTS
Upper NAPA.
NAPA AUTO PARTS
MrJ is offline   Reply With Quote
Old 06-04-2014, 05:30 AM   #2
r carl's Avatar
Lin , Ne
I've always used Moog front end parts. They were better than TRW parts.
r carl is online now   Reply With Quote
Old 06-04-2014, 05:57 AM   #3
dznf0g's Avatar
Oswego , Illinois
I am also a fan of Moog front end components. Proven over many years and any vehicles.
-Rich-
Old 06-04-2014, 07:38 AM   #4
richinny's Avatar
2011 34' Classic
mr j.
i've seen posts on the forum that refer to the airstreams as a P32. i'm not sure if there is a suspension difference.
Ricky
Old 06-04-2014, 07:54 AM   #5
1982 28' Airstream 280
Redwood City , California
I no longer buy parts from the autozone type stores and only buy from napa if it is an emergency. I have a good old fashion auto parts shop I buy from. They are willing to take the time to find the right part. More expensive but I've learned my lesson on buying cheep. Ask for U.S. made parts if available.
"We are free to go where we wish and to be what we are"
Richard Bach, Jonathan Livingston Seagall
dadstoy is offline   Reply With Quote
Old 06-04-2014, 07:58 AM   #6
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Another vote for Moog.
J. Morgan is online now   Reply With Quote
Old 06-04-2014, 08:11 AM   #7
Years ago, my dad had the ball joints replaced while on a trip. Heading back home through the mountains one broke. The shop installed the wrong ball joints. He almost lost the coach.
Also I'm one of those that if one ball joint is bad, I replace all of them.
Old 06-04-2014, 01:38 PM   #8
MrJ
MrJ's Avatar
1976 28' Argosy 28
Dallas , Texas
Part correct?
You guys are great, thanks for the help!
Here's the Moog upper:
Moog - Ball Joint
Part Number: K6174
Line: MOO
Limited Lifetime Warranty
UPC: 80066117652
Multiple Applications
Front Upper
- Standard Cargo Van
- 11000 Lb. Rear Axle
Front Upper
- Stripped Chassis
- Motorhome
- 14000 Lbs. Gross Vehicle Weight
Here's the lower:
Moog - Ball Joint
Part Number: K6511
Line: MOO
UPC: 80066273471
Front Lower
Stripped Chassis
Motorhome
Do these look correct? Any suggestions?
These are the more expensive ones that say 14,000 and motorhome on O'reilly's site.. I just found these parts at almost half on rockauto.com, WOW! 100$ savings for the same parts.
Let me know what you guys think, I'll order these if they're correct.
Again, thanks guys.
Old 04-25-2015, 06:52 AM   #9
GlenCoombe's Avatar
1984 28' Funeral Coach
Belleview , Florida
Images: 27
MrJ, did those parts work out for you. I will be reworking my front end soon and only want to do it once if possible. Like you said front tires aren't cheap.
Glen Coombe AIR #8416
Former Rolling Showroom & PuttLab (now party bus)
"I'm not an expert. But I did sleep in an Airstream last night."
GlenCoombe is offline   Reply With Quote
Old 04-27-2015, 03:04 PM   #10
MrJ
MrJ's Avatar
1976 28' Argosy 28
Dallas , Texas
yes, we had to use a jack to get the lower ones in there. They were a little tight. Top ones works once I grinded off the original ones that were riveted in. I did have a top boot brake which I'm not happy about. I used Rock Auto and saved a lot of money over Autozone, etc.
Old 04-27-2015, 03:20 PM   #11
halftimer's Avatar
irving , Texas
Thumbs up
I would not use anything but moog Napa would be second choice they are made by perfect circle which is good you will need ball joint press or large socket to fit over ball joint you can knock them out with a good heavy hammer after supporting a arm very solid jack stand as close to outside as you can even with a press they can be hard to get back in. Think the the top are riveted in just grind off and replace with bolts. If your doing that check upper a arm bushing normally they are only good for 35000 miles. Good luck
halftimer is offline   Reply With Quote
Old 04-27-2015, 03:29 PM   #12
Kevin245's Avatar
I just rebuilt the front suspension on our TV. With 250,500 miles on a 4.6 liter gasser. It would be easy to justify scrimping on parts, but a ball joint, or tie rod failure at speed it not a pretty sight.
I spent $750 in parts and can sleep well as a result. Moog for me as well.
Eleanor Roosevelt
Old 04-27-2015, 03:34 PM   #13
Cardinal283's Avatar
Dallas , Texas
If in doubt contact Moog directly. I've been on the phone with them several times. They will help you find the right part number. Also, the 14,000 gvw isn't an option if you want to get a heavy duty part or a lighter duty part. One is the right part for your vehicle and one is not. You need to determine the actual gvw of your vehicle and the axle rating to get the correct part.
Cardinal283 is offline   Reply With Quote
Old 04-28-2015, 12:48 AM   #14
MrJ
MrJ's Avatar
1976 28' Argosy 28
Dallas , Texas
I used the Moog part #s from the e-mail above from Rock Auto. Saved a lot of money.
I agree, using cheap auto parts is not a good idea.
Big ones or little ones...which is better? Phrunes LP Gas, Piping, Tanks & Regulators 20 03-07-2013 07:36 AM
Loose ball joints - can it be fixed fast? redstart Tow Vehicles 15 09-18-2009 07:19 AM
Which ones had hydraulic brakes? Roze Brakes & Brake Controllers 3 09-29-2004 05:19 PM
front suspension/ ball joints wb13798 Mechanics Corner - Engines, Transmission & More... 13 11-07-2003 07:57 AM
Skinny +short AS-which ones ? oldvws Our Community 6 01-10-2003 03:58 PM
