Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Mechanics Corner - Engines, Transmission & More...
Old 08-24-2003, 10:00 AM   #1
Clyde Gartman's Avatar
Profile:
Send a message via ICQ to Clyde Gartman
Angry Overheating 1999 Diesel Cutter
I have a 1999 Cutter diesel with a 6 speed Allison transmission. The temp is getting to the high side of normal with trans temps reaching 220+ I understand the trans and engine are both cooled by the same system but where should I start looking for the problem (or is it a problem) ?
I called the CAT people and they said "Nothing to worry about until it get out of the normal range" I usually pull into a rest stop and it cools very quickly (within 10 minutes it back to normal)
I bought the Cutter used and it has 40,000 miles on it. I've checked the levels of the transmisson and coolant.
I might add that I was pulling a light wieght auto and was going up some hills and the outside temp was about 90, but it has done it befor when I was not pulling an auto and the outside temp was about 100 degrees.
I am not a mech but would like to change the transmission oil at least. How hard is that to do?
Clyde
Clyde Gartman is offline   Reply With Quote
Old 08-24-2003, 01:30 PM   #2
Profile:  LOST , Hawaii
Go to Allison's site and type 1099b in the search box. That is a pdf with recommended change intervals and fluids for the different transmissions.
John
74Argosy24MH is offline   Reply With Quote
Old 08-25-2003, 10:15 AM   #3
John Brimer's Avatar
Profile:
Send a message via AIM to John Brimer
I have the definitive solution to your problem, because I have had the same running battle on my 1999 Cutter.
First of all, there was a recall to replace the valve cover breather tube on the engine. This recall MUST be done to prevent a further occurance of your problem. The original breather tube ended at the bottom of the engine. This arrangement allows the engine blowby (which is more than you can imagine as normal) to be collected by the fan, shroud, innercooler, and radiator. The exit of this tube MUST be behind the radiator. Unfortunately, this creates a problem for the towed vehicle unless some sort of catch can is manufactured. (I am working on that)
Next, the radiator and innercooler MUST be removed and completely cleaned. You will not believe the amount of imbedded cruded that accumulates between the innercooler and radiator. Also completely clean the shroud and fan. I recommend that you do not replace the belts at this time. I did that, and in less than a thousand miles, I had to replace the new Green Gates water pump belt with my old belt. (which I kept for emergencies)
If you play your cards right, the whole thing should be covered under the recall, unfortunately, mine was funded and designed by me!
I know this sounds crazy, but I pull a 20,000 lb race car trailer behing my 35 ft Cutter. I have to slow down to 60 and put in in 5th gear on hilly terrain and in 95+ temps to keep operating temps in normal range. I did install a custom made cooler for the transmission with auxiliary fan. This helped before I solved the problem. Now, I hardly have to use the transmission fan.
I put 20,000 to 25,000 miles a year on my coach. I encountered the heating problem in my first six months of use. It took me a year to figure out the problem. I tried cleaning the radiator without taking it out, it does NOT WORK.
I would be glad to help you anyway that I can.
John
John Brimer is offline   Reply With Quote
Old 08-25-2003, 10:41 AM   #4
HowieE's Avatar
Profile:  1991 34' Excella
Princeton , New Jersey
Images: 11
If you have not yet seen what can become accumulated between your radiator intercooler and AC condenser take a look at my web page noted in my signature. These pics represent 9,500 miles of use.
If in fact your breather tube is forward of the radiator and discharges any level of oil vapor I would assume the accumulation of bugs would be increased due to the oil file that may be present.
WBCCI 12156 AIR 3144 WDC unit
1997 6.5 Diesel Chevy 2500 See my pages mysite.verizon.net/vze54tx9/
and mysite.verizon.net/vze54tx9/kayak/
1991 34 ft. Excello +110,000 miles, new laminated flooring, new upholstery, new 3200 lbs axles
HowieE is online now   Reply With Quote
Diesel Mtrhm Data 1995 - 2003 phred Airstream Motorhome Forums 0 02-13-2004 07:40 PM
Diesel competition davidz71 Tow Vehicles 26 02-01-2004 01:07 PM
Switching to Diesel? silverback On The Road... 44 11-25-2003 02:30 PM
'97 Cutter 34' Lhill Airstream Motorhome Forums 0 06-18-2003 04:58 PM
Diesel truck owners FrankR Off Topic Forum 3 11-23-2002 06:35 AM
