Old 11-24-2013, 08:35 AM   #1
airmack
1989 37' Airstream 370
Howick , Quebec
Overdrive
Hi I have a 1989 370le with a Ford 460 and c6 transmission and a 5.29/1 differential, that doesn't gtive much of a highway speed. Has anyone added a gear venders overdrive, is the engine have enough power to run the coach with that much of a diffenertial ratio reduction. Thanks Malcolm Peddie
airmack is offline   Reply With Quote
Old 11-24-2013, 11:10 AM   #2
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
I think a gear vendors unit was offered as an option on some models.
I used one on my truck at one time but was disappointed in the life expectancy of the units. The best lasted 150K the worst only a couple thousand miles. I finally took it off at about 450K on the truck
The customer service was pretty good and that was a few years ago so they may have some of the problems worked out now
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Gear Vendors Under/Overdrive marydixon555 Mechanics Corner - Engines, Transmission & More... 10 05-27-2015 12:01 PM
Vehicle tow/Haul mode? urnmor Tow Vehicles 31 10-17-2011 03:14 AM
US Gear Overdrive 1982 310 Diesel FIX gcgreenwood Classic Motorhomes 4 07-07-2011 09:56 AM
Overdrive while towing? neal Tow Vehicles 15 06-20-2011 07:49 AM
GearVendor Vs. MileMarker Buttercup Mechanics Corner - Engines, Transmission & More... 25 01-04-2011 08:00 PM
