Old 12-09-2010, 04:31 PM   #1
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
Talking Over heated calipers and pads
If you see tan colored powder around the caliper piston, it is residue of breakdown of the bakelite piston.
Had a sticking brake on drivers side but both rear wheel calipers had heat damage, including the external rubber seals.
May have been caused by the open grease system, standard to use silicone grease on the sliding mechanism open to the weather, found rust on the seldom used surfaces.
Also the brake pads and rotors had etching and pad material due to the lack of use and over heating.
The mechanic that recommends a monthly trip to excercise everything has a good point, but somehow I will have to keep the pads and rotors dry in storage, maybe take it out on a dry day use the brakes a few times and then make sure they are covered in storage.
Old 12-23-2010, 06:21 PM   #2
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
Replaced both rear pads and calipers, on researching job I found Workhorse is now recommending flushing brake fluid every two years. Emptied reservoir, using a mirror I could see clumps of crud, scraped it clean an refilled with fluid, tried to make it a one person job, bought a vacuum pump from HF, turns out only the old way works, get copilot to do the brake and signal with taps to frame. Two quarts of fluid to have clear new fluid with no bubbles.
Old 12-23-2010, 09:26 PM   #3
Dave Park's Avatar
2005 22' Safari
Hyde Park Place , Ohio
The new fluid will dissolve a lot of the crud out and get contaminated fairly quickly since it managed to get into this state. You may want to do your next brake flush early, then you should be ok.
TX-16
Dave Park is offline   Reply With Quote
calipers, disk brakes, storage
Heated Holding Tanks LY-30 jbwsc Land Yacht/Legacy Motorhomes 3 01-24-2016 11:58 PM
Disc brake parts, pads and calipers Excella CM Brakes & Brake Controllers 31 04-16-2011 08:37 PM
Heated Floor Install IronGiant Furnaces, Heaters, Fireplaces & Air Conditioning 1 09-18-2010 08:20 PM
possessed heated seats boondockdad Tow Vehicles 2 05-07-2008 08:06 PM
heated tanks tmtrkingco1 Waste Systems, Tanks & Totes 4 10-25-2007 10:10 PM
