Old 07-26-2004, 06:01 PM   #1
noiva's Avatar
Chesapeake , Virginia
Images: 46
Onan Generator loping
Have '89 Airstream Motorhome with Onan NHE 6.5Kw generator. Generator lopes under load most of the time, but not 100% of time. Manual says to first adjust points. Is that usually what causes this? Points are almost impossible to adjust without removing generator. Any help with this?
Thanks.
noiva is offline   Reply With Quote
Old 07-26-2004, 06:16 PM   #2
Orland Dewey's Avatar
Generator Question
Hello,
Sounds to me like you should try to adjust your high-speed needle
jet a little each way to see if it makes a difference. Try richer first
and then leaner. Be sure to remember where you started from before
making any turns on the needle jet adjustment. Some motors have a
fixed high-speed and cannnot be adjusted. Galloping or hunting is usually
caused by carb. out of adjustment. Also check your fuel filter to be sure
its not restricting gas flow.
Hope this helps a little ODD
ODD
Orland Dewey is offline   Reply With Quote
Old 07-26-2004, 06:27 PM   #3
87MH's Avatar
1978 31' Sovereign
Images: 292
Originally Posted by noiva
...Onan NHE 6.5Kw generator. Generator lopes under load most of the time..... Manual says to first adjust points. Points are almost impossible to adjust without removing generator.
Check out this thread: http://www.airforums.com/forum...ht=onan+points
Also, do a search for "Onan".... lots of info here.
Points are easy to get to and are inexpensive.
Could be the throttle linkage is sticking, carb out of adjustment (if over 5 or 6 hundred hours, just replace the carb), valves sticking, or a fuel supply problem.
The 370 is indeed rare, I don't think there is another active member here on the Forums with one. Most of us have the Chevy Chassis and the 454. The Gillig chassis with the Ford 460 sounds as if it would be a good match.
How long have you had yours?
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Old 07-26-2004, 08:33 PM   #4
noiva's Avatar
Images: 46
Onan help
ODD,
Thanks. I am suspicious of the carb adjustments, but the manual doesn't mention them as a cause of galloping. Tomorrow I'll give that a shot. I'll let you know if that does it.
noiva
Originally Posted by Orland Dewey
Hello,
Old 07-26-2004, 08:42 PM   #5
noiva's Avatar
Images: 46
Onan help
Dennis,
The points appear to be located almost all the way back on the top of the generator. I located the cover today, but couldn't do more because the gen was still hot. I'm not sure how to get to the crank to rotate it for the points to open and allow me to adjust them. Anyway, I'm thinking fuel and/or carb since it doesn't lope all the time. The 370LE is very interesting, but isn't mine quite yet. It belongs to my brother, but I have the luxury of using it for as long as I like to see if I want to buy it from him. (I've always been a trailer hauler). It's like new, 15,000 miles, exterior completely redone by A/S 2 years ago. Everything works, but lack of use is a concern. Systems do better when used, especially when they're as complex as this unit. I'm a little intimidated by the complexity, but I LOVE the motorhome.
noiva
Old 07-26-2004, 09:13 PM   #6
LOST , Hawaii
If you can get at the end of the generator see if there is a bolt in the end of the shaft you can turn it with.
John
74Argosy24MH is offline   Reply With Quote
Old 07-26-2004, 09:17 PM   #7
JohnG's Avatar
Replace your generator's fuel filter
Many times the fuel filter will become clogged a little and the generator will operate normally ithout a load, but when a load is applied it will begin loping as you have described.
There is no way to check the fuel filter other than to replace it and see if that solves the problem.
Just adding my 2 worth
John G
___________________________
1975 31ft Sovereign International
........Rear Bath Double Bed Model
Tow Vehicle:1999 GMC Serria SLE Classic 1500 5.7Ltr
System: Jordon 2020 Ultima Brake Controller
Hook-Up: Equalizing Hitch and Sway Bar
JohnG is offline   Reply With Quote
Old 07-27-2004, 01:57 PM   #8
IPM
1996 clipper gas 34'
Blue Springs , Missouri
New points made mine run smooth. They are cheap and easy to install, at least in my unit. Try it. They're in a box directly on top. Tried to clean them and that only lasted for about an hour and the problem returned. Fresh points much better.
It's all good
IPM is offline   Reply With Quote
1986 AS 345 MH Onan generator Jim Tyrney Airstream Motorhome Forums 0 06-18-2004 10:58 PM
Onan 4k 1979 Oil Filter? RichardT Mechanics Corner - Engines, Transmission & More... 2 09-28-2003 07:50 AM
Puzzling Onan Air Filter on 1995 Land Yacht scotta Airstream Motorhome Forums 1 08-20-2003 06:37 AM
onan troubleshooting help rcaldwel Generators & Solar Power 2 03-10-2003 05:00 PM
Generator onan Paul Daugherty Airstream Motorhome Forums 6 11-26-2002 12:51 PM
