Old 05-10-2009, 10:59 AM   #1
geirws's Avatar
onan generator
I have a 4kw onan bf series generator. It started to run rough and slowed down. I shut it down. Now it won't start. When I try to start it the solenoid just clicks. Does anyone have any Ideas. Also does anyone know the torque for the head bolts.
irwin
geirws is offline   Reply With Quote
Old 05-10-2009, 01:40 PM   #2
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Is there any oil in the engine? Can you turn it over by hand?
Old 05-10-2009, 01:44 PM   #3
Excella CM's Avatar
1978 31' Excella 500
Venice , California
Sounds like you ran out of ignition/starting power.
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 05-10-2009, 02:09 PM   #4
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
In mine, the battery for the Onan is way forward and the heavy cable finally gave up; replaced it (not cheap cable), problem solved.
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 05-26-2009, 07:31 PM   #5
geirws's Avatar
thanks guys. I think the relay burnt out. I'm going to take it to a mechanic and make sure.
Old 06-04-2009, 02:29 PM   #6
Dr.Theopolis's Avatar
1977 24' Argosy 24
St. Augustine , Florida
Hi Irwin, I have an Onan BF also. I just bought the RV and am working on getting things working. My generator hasn't started yet but that isn't surprising since it hasn't been running for years. While playing around with it, I took off the cylinder head and there was a lot of really thick build-up of gunk on everything including the valve seats. So I cleaned it but there is another cylinder on the far side. Do you know how I could access it without removing the generator from the RV?
You can verify if your starting solenoid is working by using a voltmeter. Another thing to keep in mind is that if your battery is going bad or just not charged, then there might not be enough juice to turn the generator when starting.
Dr.Theopolis is offline   Reply With Quote
Onan Generator af12680252 Land Yacht/Legacy Motorhomes 10 09-28-2011 07:39 AM
Onan Generator gunworks Land Yacht/Legacy Motorhomes 7 07-22-2009 08:46 PM
Onan Generator - Help gdeterra Land Yacht/Legacy Motorhomes 1 03-12-2007 05:57 AM
Onan Generator Hillgenberg Generators & Solar Power 2 08-24-2006 12:32 PM
Generator onan Paul Daugherty Airstream Motorhome Forums 6 11-26-2002 12:51 PM
