Old 09-27-2003, 05:09 PM   #1
RichardT's Avatar
Question Onan 4k 1979 Oil Filter?
what is the correct filter for the generator in my 79? it is a Onan 4k green in color if that helps.
UPDATE
here is what i found
ONAN 1220323
stp or fram 3600
carquest 85762
wix 1762
my onan is a BFA A
always compare filter before using
I used the fram toughgaurd 3600 and it fit
RichardT is offline   Reply With Quote
Old 09-27-2003, 05:37 PM   #2
LOST , Hawaii
Go to Onan's site and click on Onan Parts. You will need the model and spec number, that should be on the generator tag.
John
74Argosy24MH is offline   Reply With Quote
Old 09-28-2003, 07:50 AM   #3
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
I bought my filter at NAPA they have a big cross reference guide.It was 4 or 5 bucks. Mine is an 82 if it is heloful I will go and get the no. off it. Also a 4kw. NH series.
Oil Filter Study ViewRVs Mechanics Corner - Engines, Transmission & More... 32 03-11-2010 06:26 PM
Oil Filter cooperhawk Mechanics Corner - Engines, Transmission & More... 8 11-03-2003 12:57 PM
carb cleaning George Mechanics Corner - Engines, Transmission & More... 7 09-01-2003 07:55 PM
Puzzling Onan Air Filter on 1995 Land Yacht scotta Airstream Motorhome Forums 1 08-20-2003 06:37 AM
GM/Dodge advice needed uwe On The Road... 16 08-17-2003 09:10 AM
