Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Mechanics Corner - Engines, Transmission & More...
Old 09-30-2005, 06:23 PM   #1
WYScott
Profile:  Jackson , Wyoming
Question Oil pressure sensor on 454??
Hello- Scott here, putting finger to keyboard in Jackson, Wy. I'm helping a mechanically challenged friend square away the '82 Airstream 310 that he bought last fall.
The needle on the oil pressure gauge sits unmoving at 4:00pm. The engine runs fine, other gauges WNL, so I s'pect it's probably the oil pressure sensor. Pretty simple fix, right?
I can't find the oil pressure sensor on the engine. It is not behind the carb near the distributer. I have crawled around underneath and can't find it. I have a replacement, so I know what it should look like.
Is there a secret that only Airstream folks know? A conspiracy to befuddle us shadetree mechanics? Does any body here know where the &%#*$ thing is located?
And BTW, that motorhome is one beautiful piece of work, very nicely done.
Thanks for any help you can provide.
WYScott is offline   Reply With Quote
Old 09-30-2005, 06:42 PM   #2
overlander63
overlander63's Avatar
Profile:  1974 31' Sovereign
soon to be , on the move again
Images: 58
First, welcome to the forums.
Second, there are very, very few 454's with the sender for the oil pressure gauge on the front of the engine, almost centered in front of the intake manifold. Even fewer have the sender in a spot just over the oil filter adapter housing. The fact that you can't find it may indicate it has broken or fallen off, although you would see a huge puddle of oil on the ground if that happened. Is the gauge electrical or mechanical? That is, does oil flow into a tube that goes to the gauge, or is it a wire?
Change is inevitable, except from a vending machine
AIR#2611
overlander63 is online now   Reply With Quote
Old 10-01-2005, 09:47 PM   #3
59toaster
59toaster's Avatar
Profile:  1959 22' Caravanner
Atlanta , Georgia
Images: 22
Really Depending on what Generation it is. It can also be on the side of the block in front of the driverside motor mount. Thats where it is on my 88 Suburban.
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
59toaster is offline   Reply With Quote
Old 10-02-2005, 04:18 AM   #4
TomW
TomW's Avatar
Profile:  1967 26' Overlander
Normal , Alabama
Images: 77
Originally Posted by 59toaster
... It can also be on the side of the block in front of the driverside motor mount. Thats where it is on my 88 Suburban.
That's also where it is on my '84 Suburban; I believe a green wire is connected to it.
Tom
Old 10-02-2005, 06:31 AM   #5
59toaster
59toaster's Avatar
Atlanta , Georgia
Images: 22
Tom
Actually there may be two sensors there. On anything from about 81 up it would require two sensors the way GM set it up.
On my 88 (Fuel injected) its one for the gage and one for the Fuel pump that if it isn't running it shuts down the fuel pump.
84 one would be for the Choke (only delivers power to the choke if the engine is running) and the other would be the gage. The second senors could still be at the oil filter boss as well.
I haven't really looked but I don't think the 454 has a oil port behind the distributor like the small blocks do. Its a rats nest in that location on my truck with the fluel lines for the TBI and MAP sensor and a few other lines back there.
1959 22' Caravanner
Atlanta, GA
Old 10-02-2005, 06:46 AM   #6
overlander63
Images: 58
The second sender is really to shut down the fuel pump if you lose oil pressure. Not a bad idea, since most people don't check their gauges often enough. Like people that run out of gas...
AIR#2611
Old 10-02-2005, 07:18 AM   #7
59toaster
59toaster's Avatar
Atlanta , Georgia
Images: 22
Its a very nice side effect thats for sure!
Its primary intent is to save the battery if you put it in Run without starting the engine. That pump has a heathy draw. The FI will prime the pump for 5 seconds for starting then it will turn the pump back off if till it has oil pressure. GM vehciles do not cycle the pump once it reaches pressure. The pump runs continuous.
Also if the vehicle is in a wreck and the motor stalls it keeps the fuel pump from emptying the tank if a line is ruptured. The in tank pump with no pressure to fight will empty a 20 gallon tank in about 7 minutes.
On the electric Choke vehicle its intent was again for you not to accidentally cycle the choke if you put it in run and didn't start the engine. This prevent you from having starting problems in the winter. It also keeps the draw on the battery down if you inadvertently get it in Run without starting.
1959 22' Caravanner
Atlanta, GA
Old 10-02-2005, 03:24 PM   #8
swebster
RivetAddict
swebster's Avatar
Profile:  Louisville , Kentucky
In front of the drivers side motor mount is where it's located on my 86 345. There are two. One for the gauge and one for the "other" stuff.
Steven Webster
1986 Airstream 345 Classic Motorhome
AIR 1760
View My ThisOldRV.com Personal Page
ThisOldRV.com
swebster is offline   Reply With Quote
Old 10-06-2005, 08:03 PM   #9
overlander63
Images: 58
By a strange coincidence...
An SOB Motor Home came in today, with, of all things, a blown-out oil sending unit. Where Steven's sender is, is also where the sender was on this one. Not that it matters, it was a '92 model, doing its best to emulate the Exxon Valdez on my shop floor...
AIR#2611
Old 10-07-2005, 10:38 AM   #10
WYScott
Thanks for your help. I was out there yesterday, crawled underneath, found the sensor and the wire was off. I cleaned the cotacts and plugged it in. The gauge is still pegged to the right. I didn't have time to mess with it, I'll check the connections and do some more troubleshooting today if I have time.
Old 10-07-2005, 10:42 AM   #11
ALANSD
GA Airstreamer Air_005
Profile:  North , Georgia
is the gauge pegged without the power on? I wonder as I have had mine stuck to the right and tapping on it or turning the key on and off released it to its proper spot.
Rallys twice a year..Lots of fun, food, and aluminum.
http://groups.yahoo.com/group/gaairstreamcampers/
http://airstreampassion.blogspot.com/
My Music Site:
HTTP://ALANDAVIDSONGS.COM
Old 10-07-2005, 10:45 AM   #12
smily
"Still Working"
smily's Avatar
Profile:  North Charleston , South Carolina
Common fix
The sending unit can be replaced in about five minutes.
Ken Smillie
My 1994 36' Classic MH is for sale
See it in the classifieds
smily is offline   Reply With Quote
Old 10-08-2005, 05:47 PM   #13
overlander63
Images: 58
And the best thing is, it will probably be the cheapest thing you replace on your engine. The senders can cost as little as $1.99, depending on type.
AIR#2611
Old 10-09-2005, 08:19 AM   #14
59toaster
59toaster's Avatar
Atlanta , Georgia
Images: 22
At Autozone Its about $25 for a gage sender. Idiot light sender is about $4. The pump or choke switch is about $14
At the dealer double the prices above.
1959 22' Caravanner
Atlanta, GA
Engine Oil Question 1985air345 Mechanics Corner - Engines, Transmission & More... 12 05-25-2008 08:45 AM
tire pressure wb13798 General Motorhome Topics 16 01-27-2007 12:31 PM
454 engine questions Curtis-79MH Mechanics Corner - Engines, Transmission & More... 10 10-06-2003 06:22 AM
Low water pressure in Excella murf Fresh Water Systems 7 09-04-2002 07:12 AM
Low pressure / High pressure appliances Rick LP Gas, Piping, Tanks & Regulators 1 06-15-2002 06:29 PM
Cooking Forum - Sailing Forum - Early Retirement - Airstream Trailer - Aquarium Forum - Royal Forum - Book Forum - Yoga Forum - Volkswagen Touareg Forum - Jeep Wrangler Forum - Whitewater Kayaking & Rafting Forum - Fiberglass RV Forum - U2 Forum
