Old 12-16-2005, 05:42 AM   #1
GlenCoombe's Avatar
1984 28' Funeral Coach
Belleview , Florida
Images: 27
Oil Pan replacement
Well it seems that I've got some oil seepage around what could be a repaired dip stick insert. Looks like it was brazed sometime in the past.
I've looked at replacing it as the prospect of removing, cleaning, repairing the old pan leaves me a little cold.
I've seen many high performance pans, some with trap door baffels, some just baffled.
I'm thinking of a 7 qt. trap door performance type pan.
What's your experience in this area?
Got any ideas?
How about bright orange paint vs. black vs. chrome?????
I'm going to have my hired wrench do this job but would like to know what is involved before we get deep into it.
This is going to have to happen in the next few weeks as I'm in my down season til mid January.
Glen Coombe AIR #8416
Former Rolling Showroom & PuttLab (now party bus)
"I'm not an expert. But I did sleep in an Airstream last night."
GlenCoombe is offline   Reply With Quote
Old 12-16-2005, 06:38 AM   #2
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
I vote for the Chrome! and added capacity can't hurt. I would change the rear main seal and possibly go to a high volume oil pump while it is apart.
Aaron
WBCCI #XXXX AIR #2495
Old 12-16-2005, 07:54 AM   #3
GlenCoombe's Avatar
Belleview , Florida
Images: 27
I agree with most of what you're saying. However I understand the rear mainseal would be quite an undertaking. The crank has to come down to do this and special tool required to place the upper half of the two piece seal?
High volume oil pump is already something I had thought about.
I like chrome.... already have new valve covers ready to put on as I've got some seepage from the gaskets up there too. Why just replace a gasket when you can make it look pretty too?
Old 12-16-2005, 08:16 AM   #4
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Images: 40
Glen,
I have CRS (Can't Remember S...tuff) syndrome... I know on the small block there was a way to kind of slide the seal around to get it out, it involved a wire with some threaded thing on one end...IIRC it was called a Sneaky Pete Maybe Terry will know what I am talking about, but anyway it will let you replace the top part of the seal without pulling the crank. And I think the big blocks could be done the same way.
Aaron
Old 12-16-2005, 08:23 AM   #5
Glen, I would recommend a US-made replacement, whatever you do; also, there's a GREAT oilpan gasket made by FelPro now - blue silicone and pre-shaped. It's ~$50+, but looks like the shiznet!
TheGanzman is offline   Reply With Quote
Old 12-16-2005, 10:32 AM   #6
RivetAddict
swebster's Avatar
1986 34.5' Airstream 345
Louisville , Kentucky
Glen,
My rear main seal is a bit of a seeper itself (aren't all 454s?). I would be interested in learning more about how this is done.
Steven Webster
1986 Airstream 345 Classic Motorhome
AIR 1760
swebster is offline   Reply With Quote
Removing Belly Pan garp Belly Pans & Banana Wraps 5 07-06-2016 12:48 PM
Water heater replacement Craig Water Heaters, Filters & Pumps 36 12-18-2014 09:13 AM
Water Tank Pan Craig Fresh Water Systems 7 09-06-2002 08:52 AM
Camping World - No A/C Pan? ViewRVs Furnaces, Heaters, Fireplaces & Air Conditioning 6 06-25-2002 08:55 AM
Accordian Door Replacement Tamara Upholstery, Blinds, Walls & Interior Finishes 2 06-17-2002 12:08 PM
