Old 09-23-2015, 05:54 PM   #1
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
Oil lines, tell me what you think
The 310 has an internal Oil and tranny fluid cooler in the Radiator.
Look at these oil lines, they really look a lot worse than they are. Its just the outer real thin rubber layer thats peeling off.
I am torn between rebuild the lines or wait til I add an external and prob more efficient oil cooler. No sign of a leak and i hate mess with stuff thats working despite the horrible appearance.
ID:	248802   Click image for larger version
1991 25' Excella Trailer
1990 25' Excella Trailer
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Old 09-23-2015, 06:25 PM   #2
1995 36' Classic 36
Ludington , Michigan
I'd replace them. Just getting old and brittle. The interior is probably pretty deteriorated as well. Keep in mind the transmission is designed to run near the coolant temperature. The heat exchanger works both ways. It warms up the oil when cold. The clutches tend to slip when the fluid is cold. Doesn't take much on a heavy vehicle to damage them. If you put an external cooler on, put in in series to remove heat from the fluid before the radiator. It will keep your coolant temperature down.
Kota is offline   Reply With Quote
Old 09-23-2015, 06:31 PM   #3
Airstream Driver
1997 30' Excella
Images: 51
Thanks for your input, Kota! These are engines oil lines going to the passenger side of the radiator.
The transmission lines are steel running from the Tranny directly to the drivers side of the Radiator.
AIR #13
Old 09-23-2015, 08:45 PM   #4
bwoodtx's Avatar
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio , Texas
On any older vehicle-first thing you do is change all fluids/filters and rubbers(belts, hoses etc)
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a great dog.
bwoodtx is offline   Reply With Quote
Old 09-23-2015, 10:56 PM   #5
1974 Argosy 20
Kooskia , Idaho
I had a GMC motorhome with the olds 455 engine. Suddenly, about 10 miles from home one of the engine oil cooler lines broke. All the oil pumped out in a few seconds. I was fortunate to have a pullout right next to where it happened.
It would have totaled the engine had I not stopped immediately. I got lucky.
Replace them now!
Old 09-24-2015, 07:51 AM   #6
Airstream Driver
1997 30' Excella
Images: 51
you guys just don't want to give me a break, just be like that
Perfect hoses...
Whilst I was messing with the fittings by the oil cooler, I found a GM rebuilt label with all 0 over bore. You would think that they would have replaced those hoses at that time...
AIR #13
Old 09-24-2015, 08:25 AM   #7
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
The biggest danger regarding a blown oil hose might be a rapid spray on hot exhaust components maybe resulting in an inferno....
Change the hoses, have some professionally made. There is an excellent place here in Little Rock that will make any hose while you wait for a price that wont break the bank. You should find a similar place.
Brevi tempore!
Old 09-24-2015, 08:52 AM   #8
Yep, you need to replace them!
Just wanted to add my $0.02 to the subject
Old 09-24-2015, 11:33 AM   #9
1977 31' Sovereign
Lynnwood , Washington
FYI - GM oil cooler hoses are the Achilles Heel of all GM vehicles. This is especially true of trucks.
You want NEW. Think of your motor. You want results, not a bargain.
Tom
TomKirk is offline   Reply With Quote
Old 09-24-2015, 02:38 PM   #10
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Glad you replaced them.... right answer.
Peace and Blessings..
Channing
WBCCI# 30676
cwf is online now   Reply With Quote
Old 09-24-2015, 03:12 PM   #11
Airstream Driver
1997 30' Excella
Images: 51
99.60 for the 2 hoses, my labor free as usual..
What a pain to get to the 2 fittings by the oil cooler
AIR #13
Old 09-24-2015, 07:48 PM   #12
1974 Argosy 20
Kooskia , Idaho
Well, never ask a question to which you do not really wish to know the answer.
Glad you replaced them, it was the right thing to do.
Old 09-24-2015, 10:13 PM   #13
1977 31' Sovereign
That's cheap at twice the price.
Save the old hoses for spares. You just never know.....
Tom
Old 09-25-2015, 03:05 PM   #14
Denver , North Carolina
trans lines
Is the radiator new or rebuilt? I would worry more about oil from the cooler leaking into the radiator and water leaking into the transmission fluid. Transmissions are very expensive.
Start twisting the old lines and who knows what you loosen? i WOULD GO WITH A SEPARATE TRANSMISSION COOLER AND NEW LINES
wizz is offline   Reply With Quote
To oil or not to Oil woodyarn General Repair Forum 14 08-03-2012 08:05 AM
"I think I can, I think I can, I think I can".... 2Rhinos Repairing/Replacing Floor &/or Frame 14 08-17-2011 01:39 PM
Shocks' tell-tale oil stain arcamedies Shocks 11 08-18-2010 06:57 AM
Does the amount of engine oil increase with the addition of a larger oil cooler? Mr. D Mechanics Corner - Engines, Transmission & More... 5 03-07-2009 08:56 AM
rally suggestions tell me what you think airstreamDreamer2 Forum Rallies & Meet Ups 4 06-16-2003 05:39 AM
