Old 09-25-2015, 03:40 PM   #15
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
Originally Posted by wizz22789 View Post
Is the radiator new or rebuilt? I would worry more about oil from the cooler leaking into the radiator and water leaking into the transmission fluid. Transmissions are very expensive.
Start twisting the old lines and who knows what you loosen? i WOULD GO WITH A SEPARATE TRANSMISSION COOLER AND NEW LINES
That will have to be a worry for another day. I replaced the Engine Oil cooling lines. My radiator is huge and has 3 cooling reservoirs, water, tranny fluid and Engine oil. That should make a fine mixture if it ever starts leaking internally
1996 Airstream B190
1987 29' Sovereign Trailer
1997 30' Excella Trailer
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Old 09-25-2015, 04:02 PM   #16
My 74 Argosy only has the transmission cooler as part of the radiator. I'm opting to eliminate the transmission cooler aspect and just add bigger external cooling units for both the engine and the transmission.
To me it's a matter of not wanting to tempt fate
Old 09-25-2015, 04:18 PM   #17
1981 31' Excella II
New Market , Alabama
It is also not good to run the transmission too cold. Friction is higher and water can collect in the fluid because it does not get hot enough. There is nothing wrong with trans coolers in the bottom of the radiator. If you live in a hot climate and tow with it, then you might consider an external cooler. I would still put it in series with the one in the radiator. The radiator cooler will still provide some cooling when you are idling or trying to park a trailer when there is not that much airflow going through an external cooler. My 2000 Excursion came with an external cooler only and in later models they put it in series with the radiator. I don't have a radiator cooler at all so I don't have that option. You could put a temp gage on it and see if there a problem before you start trying to fix a non-problem.
Perry
To oil or not to Oil woodyarn General Repair Forum 14 08-03-2012 08:05 AM
"I think I can, I think I can, I think I can".... 2Rhinos Repairing/Replacing Floor &/or Frame 14 08-17-2011 01:39 PM
Shocks' tell-tale oil stain arcamedies Shocks 11 08-18-2010 06:57 AM
Does the amount of engine oil increase with the addition of a larger oil cooler? Mr. D Mechanics Corner - Engines, Transmission & More... 5 03-07-2009 08:56 AM
rally suggestions tell me what you think airstreamDreamer2 Forum Rallies & Meet Ups 4 06-16-2003 05:39 AM
