Old 05-13-2003, 08:48 PM   #1
ViewRVs's Avatar
1977 20' Argosy 20
Charleston , West Virginia
Send a message via Yahoo to ViewRVs
Oil Filter Study
Here is an interesting web page on oil filters. I was reading a whopper of a usenet thread on oil filters. That's not a place for the weak minded!
Oil Filter Study
Oil Filters
One man's opinion based on his research.
Fred H.
1977 Argosy 20' Motorhome
Fred's Airstream Archives @ ViewRVs.com
ViewRVs is offline   Reply With Quote
Old 05-13-2003, 10:46 PM   #2
53flyingcloud's Avatar
1984 29' Sovereign
Savannah , Missouri
Thumbs up Great website~!
Fred
Thanks for the link!~!
That is quite a site and, eye opener.
I'm gonna print this one out and, keep it for easier reading.
BTW, it just confirmed what I had been told abt FRAM..
(I noticed that the date on his research information is (1999) somewhat 'dated'..Do you know if he has anything more recent?)
thanks~!
WBCCI 5292 AIR 807
NEU #64
New England Unit
53flyingcloud is offline   Reply With Quote
Old 05-14-2003, 05:58 AM   #3
ViewRVs's Avatar
1977 20' Argosy 20
Here's the thread out on usenet:
Are all oil filters created equal?
WARNING: You will be leaving the friendly confines of the Forums!
Fred H.
Old 05-14-2003, 06:12 AM   #4
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
When it comes to Oil Filters......
You only need to know 3 things:
1.Amsoil
2.Mobile 1
3.Hastings
Pure One's are rated pretty good also.
I have some pix of a Hastings that I sawed apart, excellent construction.
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 05-14-2003, 07:31 AM   #5
59toaster's Avatar
1959 22' Caravanner
Atlanta , Georgia
Images: 22
I have been having good luck with the A/C brand filters. Good drain back valves. I have to get the Fram off it that the PO put on it this weekend.
For the record Autozone is phasing out the A/C and Bosch filters. The Bosch Filters for GM trucks are IDENTICAL to the A/C. It's the same filter different paint and sticker. I have been using Bosch on My Supra that has a oil filter mounted on it's side so very prone to drain back problems. I had tried a couple of filters and I had run accross this story right after I had purchesed the car. Only filter that was in stock at the time was a Fram. Lots of start up rattle. Swapped on the Bosch for the vehicle and it stopped the start up rattle all together.
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
59toaster is offline   Reply With Quote
Old 05-14-2003, 07:52 AM   #6
markjoandall's Avatar
2001 30' Excella
Bedford , New Hampshire
Fram
I'm in shock, I've been using Fram for several years now. Next oil change I'm going to the Amsoil product.
-Life is a journey, not a destination.
Aerosmith
markjoandall is offline   Reply With Quote
Old 05-14-2003, 08:13 AM   #7
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
There are a bunch of those oil filter threads floating around most of the car/truck forums.
The Fram is a POS. I didn't believe it until one nearly dumped all the oil out of a Brandi's Accord. The filter valve siezed and the weakest link was the gasket, so it blew almost all the oil out. So I can attest first hand stay away from Fram.
I use the UPF-52s in the battleship. Cost is about $6 compared with the standard PF-52s cost of about $3.
Eric
Old 05-14-2003, 08:31 AM   #8
59toaster's Avatar
1959 22' Caravanner
Atlanta , Georgia
Images: 22
Re: Fram
Scary isn't it.
I have never been a fan of fram. Before I was driving GM trucks I was driving Mazda RX7 and I always bought the filters from the dealer. Those were Nippon as I recall. Before that I was driving VW's and like my Dad I alwsy Bought the MANN filters from the dealer. MANN is a excelent filter but not widely available. THere was a guy in either German our the UK that did a simular study of the products available there. The MANN filters were well rated.
Let me see if I can find a link. I have changed computers a couple times and no longer have the book mark.
1959 22' Caravanner
Atlanta, GA
Old 05-14-2003, 12:49 PM   #9
zduke4x's Avatar
oil filters
I read this post and links and it is an eye-opener.....does anyone know where Castrol filters fit in?.....such as the MaxPro?
The Silver Buffalo
Saturn with Blue OX towbar
WBCCI # 14067
zduke4x is offline   Reply With Quote
Old 05-14-2003, 02:17 PM   #10
1984 29' Sovereign
Savannah , Missouri
Exclamation Surprised to say the least
zduke4x
Castrol PH922A (all Fram numbers should be same on Castrol filters) Champion ... 1500's
This was taken off the internet and, sorta says it all..
ciao
WBCCI 5292 AIR 807
NEU #64
New England Unit
Old 05-14-2003, 09:39 PM   #11
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
I remember seeing this study over a year ago and thought it was interesting. Amsoil magazines have said that the Mobile One, AC and Hastings filters were good so that is what I buy when I wasn't using the Amsoil SDF-15 filter. I use the Amsoil recommended Hastings filter in my 8.1 engine until such time they make an SDF filter. I have also used the STP media filter as well as the Castrol filter. I do not use the Fram on any of my vehicles.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 06-17-2003, 05:43 PM   #12
Hayseed's Avatar
Oil Filter Study ...
WOW !!! Always used Fram ... figured since they were a big company they should know what they're doing ... WRONG !!
Changed the filter (only) to a Wix filter- no oil change - in our '00 Jeep ... oil pressure increased by 26% !! (Currently using 5-30 Mobil-1 in it.)
Did the same to our '75 Argosy ... 32% increase in oil pressure !! (Currently using 20-50 Castrol GTX in it.)
Are Fram filters that much of a P.O.S that they actually inpeed the oil flow ??
The Hayseed
Hayseed is offline   Reply With Quote
Old 06-17-2003, 06:00 PM   #13
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
Re: When it comes to Oil Filters......
1.Amsoil
2.Mobile 1
3.Hastings
pick,
fourth,
ac delco.
fram filters are the number one cause of cold start "knock" in chevys.
john
Old 06-17-2003, 09:55 PM   #14
1987 29' Sovereign
Sparta , Tennessee
Send a message via Yahoo to wingfoot321
Oil Filters
I have used Fram for 15 years based on an old comparison study that judged them primarily on particle filtration size.
I have been having valve train noise with an old 300six Ford during warmup. Will change the filter tomorrow.
Fram will never get on the new GMC.
I need to thank you guys for the good discussion.
wingfoot321 is offline   Reply With Quote
Old 06-18-2003, 11:23 AM   #15
garry's Avatar
1969 31' Sovereign
Broken Arrow , Oklahoma
After reading about Fram decided to switch to AC after 25 yrs of Fram use. No longer changing my own oil so I went to Walmart and they stock and use only Fram Filters.
Went to a Jiffy Lube and they only stock Pennzoil filters made by Fram.
Decided it was back to the DIY oil change and went to Auto Zone and bought the last 2 AC filters in stock that would fit on my GMC.
Went back to Walmart and they changed the oil using my filter.
Didn't seem to make any difference Fram or AC on the oil pressure but I don't think I will ever use a Fram again.
Thanks for the post and info.
Garry
Old 06-18-2003, 12:03 PM   #16
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
I put on a a k&n I got at etiher NAPA or Advance auto, hows that stack up... a good choice??
I am using Valvoline synth blend 10-40 summer 10-30 winter.
Old 06-18-2003, 01:01 PM   #17
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
The AC filters are a little harder to find these days. Apparently Walmart is no longer stocking them. I've been using AC since reports of Fram quality issues began surfacing. I found AC is stocked at the local Auto Zone store.
Consumer Reports did an oil filter study many years ago and rated Fram the best at that time. I remember that those results moved me to change to Fram filters. I think this is one of the reasons they became so popular with the DIY crowd.
Jack
Jack Canavera
STL Mo.
AIR #56
jcanavera is online now   Reply With Quote
Old 06-18-2003, 06:13 PM   #18
AC Filters
I too, have decided to go away from the FRAM filters I have used for years. As far as I can tell, none of the local auto parts stores carry them. However, they are available at GM dealers, though somewhat overpriced ($7 ea).
alan is offline   Reply With Quote
Old 06-18-2003, 07:40 PM   #19
1987 29' Sovereign
Sparta , Tennessee
Oil Filters
Napa had only Napa Silver and Napa Gold.
Walmart had only Fram & a few Motorcraft, have dropped AC.
Advance Auto had a small section of Fram, A huge section of Purolator, and a small section of Purolator Pure One for $5.99. I decided to try the Pure One.
Toyota ( for the Camry) is using Mobile bulk oil and Toyota filters and the service manager showed me a sample of disassembled filters to distinguish themselves from the crowd. I think I will trust my Toyota friends to make a good engineering choice.
Didn't get to Auto Zone yet or O'Reilly.
JCanavera is right. I remembered that study being Consumer Reports. United Technologies bought Fram about 10 years ago. I guess I should have known to audit their quality after the purchase.
Old 06-18-2003, 07:52 PM   #20
1987 29' Sovereign
Sparta , Tennessee
Oil filters
Forgot to tell you.
I pulled the Fram filter about 4 hours ago. I had driven the van yesterday. There was almost no oil in the filter. I expected oil to run down as I loosened it but, none came out. Apparently the valve wasn't holding the filter full of oil. Then the sky opened up and poured rain so I haven't been able to drive it. I hope to handle my noisey valves.
Tranny 'flush' or Filter change Sav'h Steve Mechanics Corner - Engines, Transmission & More... 18 04-02-2004 08:22 PM
Synthetic oil viscosities for heavy-duty towing ipso_facto Tow Vehicles 1 01-16-2004 07:04 PM
Oil Filter cooperhawk Mechanics Corner - Engines, Transmission & More... 8 11-03-2003 12:57 PM
Onan 4k 1979 Oil Filter? RichardT Mechanics Corner - Engines, Transmission & More... 2 09-28-2003 07:50 AM
GM/Dodge advice needed uwe On The Road... 16 08-17-2003 09:10 AM
