Old 08-28-2003, 02:35 PM   #29
RivetAddict
swebster's Avatar
1986 34.5' Airstream 345
Louisville , Kentucky
Uppers are available but lower is no longer made (which really doesn't make sense if you think about it!). I guess I could get two uppers and reshape one to fit the contours under the frame support but he timing to order these parts would put the completion of these repairs well into next week.
I'm kind of getting into the aux oil cooler idea at this point.
Steven Webster
1986 Airstream 345 Classic Motorhome
AIR 1760
swebster is offline   Reply With Quote
Old 08-28-2003, 02:59 PM   #30
87MH's Avatar
1978 31' Sovereign
Images: 292
FWIW (for what it's worth)
I have been involved in industrial engine cooling design in the past, and don't know how much would carry over from permanently mounted engines to the 454, but.....
the air/liquid heat exchanger is usually designed for a 70/30 or 60/40 split of the water/oil cooling loads. In other words, the oil cooled 30 to 40% of the engine heat load, and water cooled the remaining 60 to 70%. This is a fairly significant number, indicating that the oil cooler should definitely not be underdesigned.
I found another website while researching filters that reported that the oilpump of a 454 puts out about 6 GPM @ 3000 rpm (that will empty a 6 qt sump in 15 seconds!). I don't know how the flow is split engine/cooler/filter. Bottom line is that it appears risky to me to bypass the radiator/oil heat exchanger.
As far as the tranny, mine comes out of lock at 2500 rpm, and I keep a close eye on the rpm/speed difference, and manually drop to a lower gear when I confirm that the torque converter is slippng.
Any motor heads out there that may have numbers specific to the 454/TH400?
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Old 09-02-2003, 10:38 AM   #31
IPM
1996 clipper gas 34'
Blue Springs , Missouri
Get braided hose from napa at cost
of around $4/ft. Expensive but will hold up to anthing your MH can through at tit. Trim your original hose fittings to accept new hose (slide on) or buy new fittings. Use hose clamps to attach hose to fittings. Go to a friendly pick and pull junk yard and get an oil cooler from a turbo volvo car. they are nice units. Got mine for $10. Plumb two of them together in series for extra cooling capacity. Aftermarket coolers of similar quality are very $$$. I moved my coolers to the side away from the radiator and added an electic fan just for those coolers.
It's all good
IPM is offline   Reply With Quote
Old 09-02-2003, 11:26 AM   #32
59toaster's Avatar
1959 22' Caravanner
Atlanta , Georgia
Images: 22
Re: I'm kind of getting into the aux oil cooler idea at this point.
Uhhhhh your TH400 has lock up? I was under the impression they didn't have lock up. They have no brains (electronics) and other then the kick down solonoid they have no electrical connections. They have a modulator but that's it.
I'll have to pay attention to my tach better. I know it stays rock steady at 2800 at 70mph. To tell you the truth that makes sense because even when I hit a hill it doesn't seem to change enough to sugest slippage.
Ok let me get out the shop manual and see what it says. When I got this truck I though the converter was not staying locked. I was getting a weird serge on the hwy. Somebody on a Truck forum said it didn't lock up. I ended up tracing the serge I was getting back to a bad EGR.
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
59toaster is offline   Reply With Quote
Old 09-02-2003, 12:45 PM   #33
RivetAddict
swebster's Avatar
BTW - I found a radiator shop that is making up new lines for me. It took quite a bit to find someone who knew what these were. I have the entire ordeal on another thread if you are interested
http://www.airforums.com/forum...9902#post49902
Its about my 345, but some other members have chimed in with similar stories about their tow vehicles
Steven Webster
AIR 1760
Old 09-02-2003, 03:55 PM   #34
87MH's Avatar
1978 31' Sovereign
Images: 292
Torque converter lockup
Eric:
I have never rebuilt a TH400, and maybe I should have used the term "stall" instead of "out of lock".
In third gear, there is a linear relation between the tach and speedo down to 2500 rpm (when going up a grade ((slowdown)) situation), thereafter, the transmission appears to keep the engine at 2500 rpm, pretty well independent of the speed, until the engine is able to produce enough power to get the beast to speeds in excess of the magic 2500 rpm. This 2500 rpm "unlock" or "stall" is happening about 40 to 42 mph, just about where I like to run max engine speed (3200 rpm) in second gear. I have let the unit stay in third down to about 30mph in third, and it does not appear to want to downshift on its own.
I have learned to live with the situation, and use my own judgement as to whether or not drop it manually down to second.
One of the reasons I am so paranoid about the "stall" point is, given the weight of the bus, the torque the 454 puts out, and the relatively small reservoir of transmission fluid, I suspect that heat in the tranny builds in a hurry in any "out of lock" situation. I therefore try to avoid any tranmission slippage at all.
The next big project on the motor home is the installation of an all new instrument panel. First, I have a hard time reading the present guages, (always seems to be an excessive amount of glare), and second, in my opinion, the amount of information displayed is woefully inadequate.
I'd appreciate criticism on my thoughts, and also what others in the forum would include if they had carte blanche in designing an instrument panel.
It is, after all, my toy, and have often explained to the AB that it is WAY better than a live mistress -- she ALWAYS knows where to find me!
Dennis
WBCCI # 1113
AirForums #1737
Old 09-02-2003, 05:06 PM   #35
59toaster's Avatar
1959 22' Caravanner
Atlanta , Georgia
Images: 22
Dennis:
Ok that makes sense. I thought I got gyped and didn't get lock up.
Mine has FI and the computer controls the kickdown instead of having the full throttle/passing gear switch like yours has. It seems to automaticlly down shift. It comes out of thrid around 30mph on its own and then out of second around 10-15. Booger is the FI wants to idle at 800 RPM in gear. At that speed it's still pushing. It is set that way factory. I am trying to figure out if I can back it off to around 600 to get the tranny unloaded. It will idle 1k out of gear. Sounds high but that's the factory set. I think it has to do with the MAP sensor. I think the signal may become weak at lower RPMS and possibly give a bog at take off. Still researching.
88 was only the second year they used FI on the trucks so it's still a bit behind current set ups. Heck it's down right archaic compaired to systems that are on Toyota's at the time. The FI in my 73VW was a better design except it did not use a O2 sensor. If they used a MAF sensor or a Speed density they could have dropped the RPMS.
1959 22' Caravanner
Atlanta, GA
Old 09-03-2003, 06:49 PM   #36
RivetAddict
swebster's Avatar
Oil Cooler Lines for $50 bucks
Finally got both oil cooler lines made up for $50 at a great radiator shop. Then made up the nipples, replaced the fittings and cut to length for me. Ended up a few bucks cheaper than the GM replacements
Here's a pick:
Steven Webster
AIR 1760
Tranny 'flush' or Filter change Sav'h Steve Mechanics Corner - Engines, Transmission & More... 18 04-02-2004 08:22 PM
Transmission cooler thenewkid64 Mechanics Corner - Engines, Transmission & More... 13 11-10-2003 09:37 AM
HELP Emergency oil line busted! Astrodokk Airstream Motorhome Forums 8 10-30-2003 07:01 AM
Tag Axle Oil Level? swebster Airstream Motorhome Forums 9 08-25-2003 05:01 AM
GM/Dodge advice needed uwe On The Road... 16 08-17-2003 09:10 AM
