Old 08-26-2010, 02:45 PM   #1
Gunter
gunner's Avatar
2000 35' Land Yacht XL w/2 slides
Greenville , Ohio
Oil Cooler Line
I had to recore the radiator on my 1984 Classic Motorhome. When I reinstalled it I found that the bottom aluminum oil cooler line has a leak just before the fitting at the radiator. Does anyone know where I can purchase a replacement line. It goes from the adaptor above the oil filter to the lower fitting on the radiator. I would appreciate manufacturer or auto parts store name and part number if available.
Gunter
2000 Land Yacht XL 355
gunner is offline   Reply With Quote
Old 08-26-2010, 03:36 PM   #2
r carl's Avatar
Lin , Ne
You will have to take it off to match a new one to make sure you get the right one. I would go to a GM dealer if your chassis is a chevrolet.
Does the fitting that goes in the radiator have an 0-ring? If the hose is leaking where it is crimped on to the fitting then you will just have to get a replacement.
Old 08-26-2010, 03:54 PM   #3
3 Dog Nite's Avatar
1989 34.5' Airstream 345
Cleveland , Tennessee
Any mechanic should be able to replace that line. Using the right diameter tubing & a tubing bender. It's the same as replacing a fuel or brake line.
Riky
"Sometimes I wonder if the world is being run by smart people who are putting us on, or by imbeciles who really mean it." Mark Twain
AIR 22749 WBCCI 2349 NOVA TAC TN-6
1989 345 LE Classic Motorhome
3 Dog Nite is offline   Reply With Quote
Old 08-26-2010, 06:07 PM   #4
r carl's Avatar
Lin , Ne
Riky
Not on a chevy,, they are like a power steering hose, reinforced rubber hose with crimped fittings on each end. You thinking of a transmission cooler line Riky?
Old 08-26-2010, 07:16 PM   #5
3 Dog Nite's Avatar
Yes I was. Sorry for giving some bad info. I'll have to take a close look at my MH in the daylight tomorrow.
Ricky
Old 08-26-2010, 07:34 PM   #6
Gunter
gunner's Avatar
Greenville , Ohio
The line going into the radiator is straight tubing with an O ring against a flat flange then a nut that tightens against the other side of the flange pushing into into the radiator female fitting. It is the same on the other end. My mechanic advised that on the standard P30 Vans and Trucks the line is on the opposite side or passenger side while on the motorhome it is on the driver side and is configured differently. That is the reason I am asking if someone has replaced theirs and knows what to get. If I can't find one has anyone just put a jumper hose at the oil filter and bypassed the radiator. I am wondering how much heat is dissipated by the oil cooler and if it is enough to make a difference.
Gunter
Old 08-26-2010, 07:48 PM   #7
r carl's Avatar
Lin , Ne
I would keep the cooler. There are places that can make you a new line if you bring in the old one. Call around to places that sell industrial hoses. They also may be able to crimp a new hose to your fittings.
Old 08-26-2010, 08:22 PM   #8
Gunter
gunner's Avatar
Greenville , Ohio
Just to clarify this is a solid aluminum tubing with several bends, has no rubber hoses etc.
Gunter
Old 08-26-2010, 08:50 PM   #9
r carl's Avatar
Lin , Ne
So is the 0-ring leaking or is the tube cracked? If it is cracked, it can be TIG welded.
Old 08-26-2010, 09:38 PM   #10
I believe you are talking about the same lines I recently had replaced. They were sent to a shop where they duplicated them. My mechanic noted that it was fortunate it was a good job on them. Apparently they can be tricky to get right.
Keith
argy is offline   Reply With Quote
Old 08-27-2010, 02:35 AM   #11
1989 37' Airstream 370
Louisville , Kentucky
Any hydraulic shop such as a "Parker store" should be able to take care of you all the new hose and fittings you could imagine.
oliver00 is offline   Reply With Quote
Old 08-27-2010, 12:25 PM   #12
Gunter
gunner's Avatar
Greenville , Ohio
I have ordered two possible alternative lines that fit other GM products to see if I can make them work. I also found that the fittings and O rings are the same as Air Conditioner line fittings; this will allow me to use the fittings and put a Oil resistant hose between them if the two other lines will not work. Once the alternative lines come in next monday I will determine the best solutions but at least I have some alternatives.
Gunter
Old 08-30-2010, 08:58 AM   #13
I did a search and came up with this one...
ACDELCO Part # 12472194 from RockAuto... is was about $70.
Should be the same as a Chevy C30 from the same year.
I know the part you are talking about as I had a leaking hose on my '87 Suburban with a 454. I was lucky to have a spare engine with the hose that didnt leak.
Old 08-30-2010, 04:05 PM   #14
Gunter
gunner's Avatar
Greenville , Ohio
One of the alternative lines worked fine with a little modification, bending the line a little. That problem is fixed, radiator is back in and everything is working fine.
Gunter
Does the amount of engine oil increase with the addition of a larger oil cooler? Mr. D Mechanics Corner - Engines, Transmission & More... 5 03-07-2009 08:56 AM
Condenser/Oil cooler combo ? Dash air Jetstreamer Classic Motorhomes 4 07-04-2008 05:35 PM
Condenser oil cooler combo replacement Jetstreamer Mechanics Corner - Engines, Transmission & More... 0 06-23-2008 09:14 AM
Oil cooler fan Nick Danger Mechanics Corner - Engines, Transmission & More... 1 09-01-2004 10:20 AM
Oil Cooler Lines swebster Mechanics Corner - Engines, Transmission & More... 35 09-03-2003 06:49 PM
