Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Mechanics Corner - Engines, Transmission & More...
Old 09-01-2004, 05:26 AM   #1
Nick Danger
Nick Danger's Avatar
Profile:  Beverly Hills , Florida
Question Oil cooler fan
I have a 1989 370 LE MH with a Ford 460. There is an oil cooler fan attached to the radiator on the passenger side. It is fed by a black ground wire and a blue battery wire that I assume is connected to a sensor or sending unit on the block. Can anyone enlighten me as to when this fan should turn on? I've disconnected the circuit and tested the fan with straight 12 volts and it works, but I never see it working after the engine is at operating temp. I am guessing that there is a temperature threshold that must be met. My coach runs at 215 on the road.
Any help is appreciated.
Nick Danger, Third Eye
Nick Danger is offline   Reply With Quote
Old 09-01-2004, 10:20 AM   #2
Tinsel Loaf
Tinsel Loaf's Avatar
Profile:
215 degrees is hot enough to turn on the cooling fan. Check the thermostat to see if it is working properly. The thermostat most likely shorts to ground completing the circuit turning on the fan. Pull the thermostat and check it for a buildup of crud which would make it not open and close properly.
Tinsel Loaf is offline   Reply With Quote
Refrig fan noise FIXED...really dtbw Refrigerators 39 08-23-2007 01:24 PM
noisy refrigerator fan Turtle 1999 - 2004 Bambi 9 06-03-2004 03:45 PM
HELP Emergency oil line busted! Astrodokk Airstream Motorhome Forums 8 10-30-2003 07:01 AM
Oil Cooler Lines swebster Mechanics Corner - Engines, Transmission & More... 35 09-03-2003 06:49 PM
Exhaust Fan Cat Roof Vents, Skylights & Fans 1 10-04-2002 10:44 PM
Cooking Forum - Sailing Forum - Early Retirement - Airstream Trailer - Aquarium Forum - Royal Forum - Book Forum - Yoga Forum - Volkswagen Touareg Forum - Jeep Wrangler Forum - Whitewater Kayaking & Rafting Forum - Fiberglass RV Forum - U2 Forum
