Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Mechanics Corner - Engines, Transmission & More...
Old 04-24-2011, 07:23 PM   #41
Progress on the Quadrajet...
Here is the plugs in the lower body.
The Reamer and bushing kit arrived, so I did that today...
Reamed out the shaft hole about 12 mm or 1/2" deep...
The brass bushing was Red Loctited..
And driven in just under the external body..
That done, I cleaned the body again and shot a coat of High Temp paint.
Old 04-24-2011, 08:21 PM   #42
1989 34.5' Airstream 345
Jamestown , Kentucky
Images: 13
Good Job
Thank You
Good information
John H. is offline   Reply With Quote
Old 04-24-2011, 09:28 PM   #43
Thanks John...
For the record, the pic of the reaming of the primary shaft bushings is not the way I did it...
I looked at the reamer supplied... and realised that I could no way hold the reamer true and square enough by hand....
It occured to me that if I put the reamer in backward, the shank would guide it thru very accurately... But the shank was not long enough to pass thru the body...
Therefore, I would have to hold the normal "Business End" of the with the drill chuck, and spin it backward!
It worked great and I was feeling very clever and pleased with myself!
On throwing the packaging away, I felt something in the corner...
The instructions!
Reading them retrospectively... it explains that I did it correctly!
Now looking at the color I painted the carb... I am thinking Black would have been cooler...
If I dont change my mind...
Tomorrow I will get it all put back together!
Old 09-06-2011, 06:42 AM   #44
Forgot to post an update on this thread with the carb and intake almost done.
Decide to repaint the Carb, and it looks pretty good to me now!
I also got an Edelbrock Performer 2.0 Aluminum Intake Manifold. The cast surfaces were stained, so that was painted too, although I am concerned about the fact the carb mounting face is 1" taller... Might not fit under the doghouse!
Anyway, for now, here is the finished deal.
With the banks Filter on..
Banks Airfilter wont fit... Keyair Mechanics Corner - Engines, Transmission & More... 6 12-29-2010 09:26 AM
Argosy 24' MOHO Smog? doorgunner Argosy Motorhomes 1 07-06-2007 08:55 AM
Mechanic refused to smog my MH! Astrodokk Classic Motorhomes 15 10-12-2005 05:44 PM
CA. smog - am I in big trouble ? guy99 Mechanics Corner - Engines, Transmission & More... 14 06-27-2004 09:12 PM
Bad Smog Pump? torin knorr General Motorhome Topics 2 07-03-2003 09:25 AM
