Old 07-31-2004, 08:48 PM   #15
RivetAddict
swebster's Avatar
1986 34.5' Airstream 345
Louisville , Kentucky
BTW - I once fixed a Velvac Mirror mount on a big Winnie DP after I whacked it off on a toll both headed over the George Washington Bridge.
$4 thing of JB Weld vs. $900 Mirror. I LOVE JB Weld
Steven Webster
1986 Airstream 345 Classic Motorhome
AIR 1760
swebster is offline   Reply With Quote
Old 07-31-2004, 09:00 PM   #16
59toaster's Avatar
1959 22' Caravanner
Atlanta , Georgia
Images: 22
JB WELD Is awsome. My buddy had a crack in the water jacket on his Toyota FJ40 motor. He sealed it with JB weld. It was a huge joke about the motor being glued together in our 4x4 club. It would last about a year before theh eat and pressure would get to it. It bought him three years on that motor.
I Glued a 700R4 transmssion back together with it. My buddy had swapped a 700R4 into his 1970 Chevy Blazer. He was running down a trail a little fast and hit a water bar and aired the truck. Got the front end about 4 ft in the air. It nosed over hard when it landed. Suspensing did it's thing and the axle goes back as it comrpesses the suspension. Those olf Chevys did not run the clam shell motor mounts. It's basicly just a rbber block. So the motor and tranny went foward. Ran out of drive shaft splines and something had to give. Driverside Rams horn exhaust pipe sheared off at the collector from hitting the motor mount (normally 2 inches of clearence). Transfer case ripped off the back of the transmssions a part of the transmission went with it.
I JB Welded the broken section back on. Drilled the mount holes extra deep into the back of the transmission to get past the broken part. Heli coiled it and bolted it back together.
Still holding after 2 years!
One other thing to check if your going to pull that carb again is the EGR port. Once you get the carb off the plennum devider up under the car has the EGR port. Check and see if it's all carboned up. I had my 79 K5 plug up that port and only delivered EGR to one half of the motor. It will give you some odd looking plugs when that happens.
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
59toaster is offline   Reply With Quote
Old 08-01-2004, 07:12 AM   #17
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
you guys make me glad I carry JB in my emergency parts bin. Thats JB Weld not JB scotch, which isn't a bad thing to carry either. Keeps YOU glue together in a tight circumstance.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 08-01-2004, 07:50 AM   #18
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
quite a few vintage harleys running around with parts repaired with jb weld.
mine included!
john
you call them ferrets, i call them weasels.
Reading the serial number question tiniree Our Community 10 10-30-2015 11:49 AM
fresh water tank plug and valve repair john hd Fresh Water Systems 40 06-01-2010 01:45 PM
Generator Plug neil.ervin Generators & Solar Power 2 07-08-2004 10:52 PM
Rewiring Trailer Umbilical Plug DPeakMD Electrical - Systems, Generators, Batteries & Solar 4 02-29-2004 05:40 PM
Trailer plug - Adapter or New Plug?? Jason1101 Brakes & Brake Controllers 4 01-23-2003 05:24 PM
