Old 09-16-2015, 12:48 PM   #1
1986 34.5' Airstream 345
Ad , Ohio
Newbie Needs Help - 86 345 MoHo Fuel Gauge Not Functioning Properly
Fuel gauge stuck on full, 2 pink wires @ sender lead on fuel gauge. Open circuit to ground. Infinity reading. What is the wiring diagram for the gauge? Can I acccess the sending unit thru an access port? Do I have to drop the tank? SOMEONE HAS been here before, if I knew how to navigate the sight I know the info is somewhere?
Please help ....Thanx gizzyguy
gizzyguy is offline   Reply With Quote
Old 09-16-2015, 02:14 PM   #2
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Howdy..
Welcome aboard.. there are some folks who can give specifics.. but, this is just like any fuel tank gauge.. nothing 'special'.
What previous work was attempted on the gauge?
Peace and Blessings..
Channing
WBCCI# 30676
cwf is online now   Reply With Quote
Old 09-17-2015, 02:37 AM   #3
bigbidule's Avatar
1981 28' Airstream 280
Lisle sur Tarn , France
I had a problem with the sender which was blocked . Drop the tank is not easy job... I made an access just above, through the floor ( half of an hour! ) The sender wasn't in the right position since I bought Excella
bigbidule is offline   Reply With Quote
Old 09-17-2015, 02:01 PM   #4
What Bigbidule suggests is by far the fasted way to get access to the fuel tank sender.
Should you decide to cut an access hole measure twice and cut once
I haven't had the opportunity or need to work on a GM fuel gauge so I'm not sure just how they are wired. Martin has been working on his recently so hopefully he will chime in with some suggestions on what to look for.
Good luck!
access to fuel gauge from inside moho ? bigbidule Classic Motorhomes 2 03-22-2015 09:49 AM
Brake lights, brake controller not functioning adwriter73 Brakes & Brake Controllers 17 01-16-2014 09:37 AM
Functioning Normally? holtenc Electrical - Systems, Generators, Batteries & Solar 14 11-05-2013 08:16 AM
Fuel gauge not working..help Animkeg Land Yacht/Legacy Motorhomes 6 07-10-2013 09:09 AM
110 outlets not functioning mguinn Electrical - Systems, Generators, Batteries & Solar 5 07-09-2010 07:21 AM
