Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Mechanics Corner - Engines, Transmission & More...
Old 05-15-2007, 05:00 AM   #1
cmadmaxman
cmadmaxman's Avatar
Profile:  Columbia , Tennessee
New Hedman headers and Flowmasters
Thanks for the info Glen.
Just received my new project from the Brown truck yesterday. Working on soaking the old manifold bolts now.
Also using bolts that have used on my sons 2.8 with headers. These bolts do not back off. For 55.00 bucks they better not!
ID:	37381  Click image for larger version
Chris & Brenda
1982 310 Motor Home
Members of the Christian Motorcyclists Association
Pullin a 98 Saturn SL2 or a 96 HD Ultra Classic
Old tow truck, 01 Duramax CC
More on our 310
cmadmaxman is offline   Reply With Quote
Old 05-15-2007, 06:15 AM   #2
Silvertwinkie
Aluminut
Silvertwinkie's Avatar
Profile:  2004 25' Safari
Northern Suburbs , Illinois
Nothin' quite like an afternoon or all weekend project!
Old 05-15-2007, 07:25 AM   #3
overlander63
overlander63's Avatar
Profile:  1974 31' Sovereign
soon to be , on the move again
Images: 58
They look so purty sitting there, almost a shame to put them on and get them greasy. Almost. Take lots of pictures, everybody loves show and tell.
Change is inevitable, except from a vending machine
AIR#2611
Old 05-15-2007, 08:14 AM   #4
Bfrank
Bfrank's Avatar
Profile:  Adams , Tennessee
CMADMAXMAN,
Are those hedders for a P-30 chassis? If so could I inquire as to where they were purchased and a ballpark cost? thanks much
bfrank
Bfrank is offline   Reply With Quote
Old 05-15-2007, 08:43 AM   #5
cmadmaxman
cmadmaxman's Avatar
Header price
Summit Racing is where I bought them. $270.00 for the headers, with $10.50 for extra handling. 70 series Flowmasters FLO-52570 $113.00 and the Summit H pipe 642025, $32.00. Yes they are for the P30, Hedman headers number 69820. Headers, Elite, Full-Length, Steel, Thermal Coated, Chevy, Class A Motor Home, 396/402/427/454, Pair.
Shipping was free, except for the extra handling charge for the headers.
Summit Racing - High Performance Car and Truck Parts | 800-230-3030
Chris & Brenda
1982 310 Motor Home
More on our 310
Old 05-21-2007, 11:59 AM   #6
Mr. D
Profile:  White Lake , Michigan
Exhaust system advice
CMADMAXMAN, What kind of set up did you have before going to the headers and cross over(H) pipe?...How did you decide on the set up your planning to enstall? Do you have any idea what kind of additional horsepower you can expect to get as a result of your upgrade? I currently have a Banks power pac system which has headers...but...my exhaust pipe leaves the headers and crosses over to enter with the other headers exhaust into one extra large muffler with a 3" single exit exhaust... my system is showing signs of cracks/rust and before I do any replacement of existing parts I was looking for advice on maybe upgrading ... what ever information you may have I would appreciate ... Mr. D
Mr. D is offline   Reply With Quote
Old 05-21-2007, 08:55 PM   #7
cmadmaxman
cmadmaxman's Avatar
Headers
Mr. D
I have the OEM exhaust manifolds on the coach now. The pipes going off the manifolds, I think was a lot of the problem. They were bent very tight and not mandrel bent buy any means. Plus I had wiring problems from past exhaust leaks burning through wires and hoses. Having the system out of the way makes it much easier to work on.
The system you have, I think is one of the best out there. I have worked on the Banks, and they are top shelf!
I'm going with the Hedman and twin Flowmasters 70's from others here that have used this set up with great success. And the cost is much less than the $2000 for the full system from Banks.
When I get the system on and running, will find out how much it helps. By the seat of my pants, should be very noticeable!
It looked like the left manifold was original, while the right I know was replaced by the last PO.
ID:	37717  Click image for larger version
ID:	37719  Click image for larger version
Chris & Brenda
1982 310 Motor Home
More on our 310
Old 10-29-2007, 05:53 PM   #8
cmadmaxman
cmadmaxman's Avatar
Sorry for not posting this earlier.
Have the new system on and really like the extra power. Have not noticed much increase in MPG, but can really notice the quicker acceleration. And the sound with the Flowmaster 70's? How about the wife saying she likes it!!!!
I had no problems taking of the old system. The biggest problem that I had was fixing the wiring that got burnt from the PO at some time.
While I was at it I added a Perma-cool trans cooler to the coach. I used -8 Stainless Steel bradded lines and removed the old rusted steel lines.
I had a problem with the three bolts going loose at the header flange. Think I got it fixed at this time after 2 trips trying it out. No problems with the header bolts going loose. I used the "bolt stops here" system that I bought from Summit.
I used a heat shield around the starter and moved the electrical connections up to the frame so that if needed, I can disconnect it and drop.
Photos to follow. Don't have them on my laptop!
Chris & Brenda
1982 310 Motor Home
More on our 310
Old 10-31-2007, 05:55 PM   #9
cmadmaxman
cmadmaxman's Avatar
Here are some Pic's of the install. While I was at it I did the front brake job. New Calipers, loaded, hoses, bearings, hub bolts, and turned the rotors.
I welded the whole system up. If I need to drop it, just unbolt and drop as a complete unit.
I also used all of the OEM hangers and put the u-bolt claps, studs up, so that while under there I don't get hung up on them!
ID:	48442  Click image for larger version
ID:	48444  Click image for larger version
ID:	48446  Click image for larger version
ID:	48448  Click image for larger version
ID:	48450  Click image for larger version
Chris & Brenda
1982 310 Motor Home
More on our 310
Old 11-01-2007, 05:18 AM   #10
bkahler
Profile:  Jefferson , Arkansas
Chris,
Nice work! Doing the work yourself means know the job was done right the first time.
"Wherever you go... there you are." - Buckaroo Banzai
1984 310 Limited Motorhome
1974 31' Excella 500 (future hauler for 2 Triumph race cars)
1974 20' Argosy Motorhome (future Excella 500 tow vehicle)
bkahler is online now   Reply With Quote
Old 11-11-2007, 08:16 PM   #11
wpapke
Profile:  CUMMING , GA
Great photos cmax. had headers installed (1988 345) and it made a big difference in the scoot. the installer said he couldn't crossovers in so i let it go. after seeing yours he obviously was over his head so i will seek soemone else out to install them.
wpapke is offline   Reply With Quote
Old 11-12-2007, 07:37 AM   #12
richinny
richinny's Avatar
Profile:  1994 34' Limited
Westchester Cty. NY , & Miami FL
Originally Posted by bkahler
Chris,
........or where to look if you didn't......not that i ever did that.
Ricky & (Ingrid)
Ingrid, 99.5 y.o. and counting & Ricky, a long way from there!
give life. have you signed your donor card?
kidney & pancreas transplant 9/9/06
welcome to the collective
richinny is online now   Reply With Quote
Old 11-22-2007, 07:32 AM   #13
GlenCoombe
GlenCoombe's Avatar
Profile:  Sumter , South Carolina
I've found that with the same setup minus the H pipe that I got improved fuel economy until the weather allowed me to open the drivers side window.
Both my pipes exit on the road side and my foot gets happy when I can hear the great round sound from the system.... kinda gets ya' deeper into it from time to time.
Nice work Max.
Glen Coombe AIR #8416
1984 28' Funeral Coach
Golf Professional Sales Rolling Showroom
"I'm not an expert. But I did sleep in an Airstream last night."
GlenCoombe is offline   Reply With Quote
Cooking Forum - Sailing Forum - Early Retirement - Airstream Trailer - Aquarium Forum - Royal Forum - Book Forum - Yoga Forum - Volkswagen Touareg Forum - Jeep Wrangler Forum - Whitewater Kayaking & Rafting Forum - Fiberglass RV Forum - U2 Forum
