Old 01-21-2006, 03:45 PM   #1
guy99's Avatar
1984 31' Airstream310
Dunsmuir , California
Images: 16
Need mechanic Dallas area
Hello everyone,
We are currently on the homeward leg of our 6000+ mile trip from Northern California to Puerto Peñasco, MX and New Orleans, LA.
We're in Arlington, TX. The 454 in our 84 310 Limited MH is begining to miss at high RPM and has become very difficult to start the first time in the morning. I'd like to have it looked at before we head out.
I'm looking for recommendations for a competent, fair, mechanic who, might be able to squeeze us in on Monday, Jan 21, 2006. Any ideas? I'm not broken down (yet) so I could also take it to someone located west of here.
1984 310 Limited Motorhome
guy99 is offline   Reply With Quote
Old 01-21-2006, 05:59 PM   #2
1995 36' Classic 36
Ottawa , Ontario
Can't help you with a mechanic suggestion (I am up in Canada), but:
Assuming internals of engine are healthy, when were spark plugs, plug wires and ignition components last changed? The 454, in fact most motorhomes, are hard on plug wires (heat cooks them).
If you can't get a mechanic to look at it I'd be tempted to start by putting a new set of wires on it and a new distributor cap and see if that helps. Pulling spark plugs would be next step, but you probably don't want to tackle that in a parking lot......
Other possibility that may be simple to fix is fuel starvation due to a pump(s) problem or plugged fuel filter(s) Do you know when they were last changed? Typically, a fuel starvation problem is going to be more visible under heavy load, not just high rpm's so depending on when your miss is occurring this may or may not be the issue.
Good luck!
John
shadejo is offline   Reply With Quote
Old 01-21-2006, 08:39 PM   #3
guy99's Avatar
Images: 16
I had it tuned up just before we left on this trip. Put on super duper lifetime guarentee plug wires. Replaced both fuel filters.
It was missing at about 3000 RPM in second gear as I accelerated onto an interstate.
Old 01-22-2006, 10:57 AM   #4
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
Just a suggestion;
Pop the cap on the distributor cap and pull the rotor, check and see if the advance weights on the distributor shaft (almond shaped metal with springs) move freely. The Distributor internals get rusty with non use and these will seize. This will cause it to Idle fine, but miss under load, I had to R&R my distributor on the way home from Lansing 2 yrs ago in an Auto-zone parking lot. If you still need a mechanic, I can give you one in south Dallas. PM me.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 01-22-2006, 10:57 AM   #5
noiva's Avatar
Chesapeake , Virginia
Images: 46
I know this is repetitive, but sure sounds like wires, fuel, or spark plugs. Any chance one of the plug wires or plugs is not secure? Wires, of course, need to be checked at distributor and at plugs. At least that stuff is fairly easy to check. I've had new stuff malfunction before. Best wishes with this.
Tim
noiva is offline   Reply With Quote
Old 01-22-2006, 01:43 PM   #6
87MH's Avatar
1978 31' Sovereign
Images: 292
My vote goes to "Fuel Starvation".
....Any ideas? I'm not broken down (yet) so I could also take it to someone located west of here.
It certainly could be any of the things mentioned above, but, considering the symptoms you described, I think that fuel starvation is the lead culprit.
Do a search here in the Forums on "fuel pressure", "fuel pump", "gas filter", or the like. Much has been discussed previously.
The long run from the rear mounted gas tank to the thirsty 454 creates fuel delivery difficulties many Classic MoHo owners have encountered.
The good thing is, most of the time you can "limp" to a safe haven - given enough time between stops.
I don't recommend running this way (fuel starving the engine continuously) since this causes the engine to run way too lean, promoting other internal problems.
Please post your solution to the problem -
Luck.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Old 01-22-2006, 04:06 PM   #7
GlenCoombe's Avatar
1984 28' Funeral Coach
Belleview , Florida
Images: 27
Not to point fingers at the folks who did your tuneup before you left....but. Often they miss either the internal carb fuel filter, or the chassis fuel filter. Often the boss says, change the fuel filter. Lowest paid grunt on the list changes one, not both.
Keep us informed.
Glen Coombe AIR #8416
Former Rolling Showroom & PuttLab (now party bus)
"I'm not an expert. But I did sleep in an Airstream last night."
GlenCoombe is offline   Reply With Quote
Old 01-22-2006, 04:29 PM   #8
noiva's Avatar
Images: 46
Keep us informed.
In doing my first tuneup last week on my 370, I discovered it didn't even have a filter in the casing on the carb! I had to research the Ford 460 engine on the Internet to determine what went in there. Odd part was the previous "grunt" who had tuned it had taken out the old one, but left the washer and the spring. The washer was sloshing around in there periodically choking the engine off. Go figure... Point is that tune-ups followed by performance problems usually point to improper or just plain not done maintenance. Would really like to hear what the problem turns out to be.
Tim
Old 01-22-2006, 04:37 PM   #9
Just a member
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
One other thing I have experienced is that the frame rail fuel filter acts as a primary filter and can get clogged just from running copious amounts of fuel through the system. There can be sediments that settle in the fuel tank and all the pumping of gas will stir it up. I have changed my frame rail filter approx every 3K mikes since I bought the rig.
Brett G
Old 01-22-2006, 05:23 PM   #10
RivetAddict
swebster's Avatar
1986 34.5' Airstream 345
Louisville , Kentucky
Guy99,
Certainly check (and replace) the items as mentioned (fuel filters - all of them) are particularly suspicious) but don't ignore your insticts on the wires. Motorhomes are particularly notrious for burning wires. I replaced my wireset with a new NAPA set for the 454 P30 before a short trip and fried the number eight wire (from the exhaust) on our very next trip.
If you're near a WalMart (or similar) you should consider purchasing a cheap timing light to keep on board. Run the engine, pull the doghouse and and keep moving the timing light inductor from wire to wire to determine which one (if any) is missing.
My solution was to follow the advice of others on the forum and install a set of Accell 9000 wires (sold at AutoZone and PepBoys, etc). They have coated boots and high temp wires. It virtually cured my wire burnout woes.
Of course, I also had fuel filter problems that I was convinced were ignition problems. It's really a matter of eliminating each possibility to find the one thing (or combination of things) that is the root cause.
Steven Webster
1986 Airstream 345 Classic Motorhome
AIR 1760
swebster is offline   Reply With Quote
Old 01-25-2006, 10:02 AM   #11
guy99's Avatar
Images: 16
Update
To review, I was having two problems:
1) An intermittent miss under load at high (3000) RPM
2) Very, very, difficult starting in the morning. It would take 10 minutes or so to get it started. It would just turn over as if I had either no spark or no fuel. Eventually, I would flood it and have to hold the throttle open for a minute, after doing this for one to n times, it would finally catch and eventually start. When it started, it would run rough and spit raw gas out the exhaust for a little while, then run as usual.
I took it to a mechanic recommended by a forum member. He found two things, the rotor (which was replaced 3- 4000 miles ago) had carbon marks on the top and bottom of the plastic part which made it seem as if the spark was sometimes shorting from the rotor button to the distributor body. The carbon/burning was not bad enough to indicated that this was happening all the time but could have been responsible for my intermittent miss. He also observed that the air cleaner housing had some oil pooled in the bottom of it.
He said the rotors in the 454 were notorious for problems and replaced the rotor. He clean out the oil and opined that the rings are beginning to fail. He didn't pull any plugs and I have not had any problem with fouled plugs. He checked out the PCV system, which he thought might cause the oil in the air cleaner, but found no problems with it.
So I took off midday Monday hoping that my problems were solved. Drove the rest of the day Monday (250 miles) with no missing. Tuesday morning I had the devil of a time starting the engine. Got it started finally and drove 450 miles without problem.
This morning before trying to startup, I pulled the distributor cap and rotor and again inspected the whole ignition system. Everything looked really good. I though about maybe the module failed, or the coil was gone, but that just didn't seem to jive with the fact that once I get it started, it runs fine all day. Gas mileage is normal, hill climbing is normal, acceleration is normal...
So I reassembled the ignition, pulled the top off of the air cleaner, found no oil. Tried to start it, nothing. Didn't see or smell any gasoline when I pumped the accelerator. So I sprayed some starting fluid into the throat of the carburetor, it fired as soon as I turned it over. Had to spray it one more time before it would stay running. I conclude the after sitting all night, it has no fuel in the carburetor and that it is taking allot of cranking to get fuel to the carburetor.
Why? I don't think it is fuel filters since once it is started there are no symptoms of fuel starvation. Ditto with fuel pump problems. So what is it?
Old 01-25-2006, 10:17 AM   #12
The Hawk's Lair
cooperhawk's Avatar
1985 34.5' Airstream 345
BACK WOODS , Minnesota
I suspect that your fuel pump is not holding pressure in the lines when the engine is not running and is not delivering enough pressure when it is running. Have a mechanic put a fuel pressure guage on the fuel line and turn the engine over and see how much pressure you have and if it holds when you turn the engine off.
Fuel will evaporate from the bowl on a warm engine, but there should be fuel waiting in the line so that when the float asks for fuel it is there. If it drains back through the fuel pump, it takes a long time to get it back.And if the pump is weak it takes longer.
AKA THE GUNNER
There is no "I" in the word "team," but there are four in "Platitude Quoting Idiot!"
AIRSTREAM 345 TURBO-DIESEL
VFW, LEGION, NRA
cooperhawk is offline   Reply With Quote
Old 01-25-2006, 11:08 AM   #13
noiva's Avatar
Images: 46
I'm assuming the carb floats have been checked to be sure they're not sticking in position. That happened to me years ago. Relatively easy to fix, but a little difficult to catch. The lack of fuel getting to the carb (you're not smelling gas) sure sounds like lack of pressure or (less likely) sticking carb floats.
Tim
Old 01-25-2006, 01:02 PM   #14
guy99's Avatar
Images: 16
I have a hard time seeing why a weak fuel pump won't cause other symptoms of fuel starvation.
If the floats are sticking, why do they unstick and why don't they ever stick except when the MH has been parked overnight?
New VAC club in South East area smily Our Community 12 03-14-2013 09:21 AM
The fancy stuff - Vacuum and Nutone Cheryl Nu-Tone Appliances & Central Vac System 9 10-13-2007 07:59 PM
Front floor area and rebuilding dresser jeanarlene 1969 - 1973 Safari 10 09-05-2002 11:11 AM
Air streams in New York area?!? mitchm71 Our Community 0 07-25-2002 09:33 AM
Good campground in Omaha NE area? 83Excella On The Road... 0 07-24-2002 09:01 PM
