Old 05-03-2012, 04:44 PM   #1
Mr. D's Avatar
1988 34.5' Airstream 345
White Lake , Michigan
Need help with electric brake wiring...
I disconnected my brake wiring at the outside of the inner hub on the tag axle. In the heat of the moment on the roadside I thought my brakes had locked up when in fact it was heat generated from bad bearings. Anyways, I have a black and white wire coming from the brake controller and two white wires coming out of the hub. Is there a polarity issue when you make this connection? If so, anyway to do this without taking the hub apart? Mr.D
Mr. D is offline   Reply With Quote
Old 05-03-2012, 04:51 PM   #2
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
There is no polarity problem with the magnet hookup.. Just splice it back together
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 05-03-2012, 06:14 PM   #3
Mr. D's Avatar
Thanks, I'm trying to get the MH ready for a Western trip in June. I'd like to do as much preventative maintenance and up keep while I have the luxury of tools, work bench, and parts, Nice to have the forums for a source!
