Old 09-29-2004, 12:28 PM   #1
1976 28' Argosy 28
Lansing , Michigan
need a new carb-HELP!!!!
Shade tree mechanic says I need a new carb. What is the best one for a '76 28 ft MH with the 454? How about the EB with electric choke and 750 cfm? any and all help would be appreciated. What is everyone's preference? Thanks!!!!!!
tandemfish is offline   Reply With Quote
Old 09-29-2004, 01:03 PM   #2
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Check this thread out it has your answer.http://www.airforums.com/forum...ight=EDELBROCK
I guess I should ask, has the old one been cleaned well? New fuel filters also?
Makes a big difference.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 09-29-2004, 02:15 PM   #3
RivetAddict
swebster's Avatar
1986 34.5' Airstream 345
Louisville , Kentucky
have you considered a rebuild on your stock carb? I rebuilt mine and changed all of the fuel filters and it was like new motorhome. All in all it cost less than $100 and took about four hours. A clean, tuned, working QJet is pretty hard to beat.
Read about it here: http://www.airforums.com/forum...t=rebuild+QJet
If you just need to completely replace yours then you could start at Summit Racing or Jegs (both have online catalogs www.summitracing.com and www.jegs.com).
Steven Webster
1986 Airstream 345 Classic Motorhome
AIR 1760
swebster is offline   Reply With Quote
Old 10-02-2004, 06:51 AM   #4
Carb.
Tfish,
It has been my experance over the years, that most of the time, rebuilding your old carb.(providing it is the origional AND correct one) is better than a "rebuilt" one at the auto stores.
G.M. produced a gazillion models of "Q" jets, each one just a little different for each special application.
A rebuilt "will Fit" "Q" jet from the auto stores will most times work, BUT it lacks the special differances specific to the applicable models.
Unless yours is physically worn out or damaged. it is almost always better to put a simple kit in it.
I wish I had a Nickel for all the carbs. that were replaced with a "rebuilt" that didn't need to be.
A Mechanic can replace a carb quickly.
Taking the time to clean and put in a "jiffy kit" in the origional one just don't make as much money, and takes longer.
If you "must" replace your carb, either a new GM factory carb ($$$$) or Edelbrock makes a good replacement one.
Edelbrock bases theirs on the old "carter" AFB carb. I found those to be good carbs.
ol'George
George is offline   Reply With Quote
Exhaust ALANSD Airstream Motorhome Forums 44 11-30-2003 09:23 AM
EDL 1906 carb. needs mod!!!? for '81MH Astrodokk Airstream Motorhome Forums 6 09-25-2003 03:53 PM
HELP! Need correct carburetor '81 454 Astrodokk Airstream Motorhome Forums 4 09-23-2003 06:58 AM
carb cleaning George Mechanics Corner - Engines, Transmission & More... 7 09-01-2003 07:55 PM
Carb cleaner Bill Resseau Mechanics Corner - Engines, Transmission & More... 4 04-30-2003 10:17 AM
