Old 05-26-2005, 04:57 PM   #1
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
Thumbs up Mystery coolant leak
Ok, I scratching my head on this one:
Cold engine no sign of any coolant leak
Engine warming up (just before thermostat opens, i think) coolant leaking from bottom of radiator. I can see some seeping out at the lower section of the radiator, just a few inches above the Transmission cooler.
Engine at operating temperature no sign of any leak whatsoever.
I had this radiator rebuilt just a couple of years ago and have not put a lot of miles on the MH since.
Give me your thoughts!
1991 25' Excella Trailer
1990 25' Excella Trailer
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Old 05-26-2005, 05:04 PM   #2
LOST , Hawaii
Probably a small leak? When the pressure begins to build from the heat and water pump it will leak. When it gets hot the coolant evaporates before it has a chance to show as a leak. Easiest way to find the acutal leak will be to put a pressure tester on it when cold and crank it up to 20-25 lbs. and watch the area. The little ones are worse than the big gushers.
John
74Argosy24MH is offline   Reply With Quote
Old 05-26-2005, 05:44 PM   #3
Peter.
As a down and dirty quick repair, there is a material called "radiator stop leak".
Most auto parts stores have it.
It seals small leaks, but it is not a long term fix.
Old 05-26-2005, 06:08 PM   #4
LOST , Hawaii
It also seals steam passages in heads, not a good thing to use.
John
Old 05-26-2005, 06:15 PM   #5
John.
Thats why it's a down and dirty fix. Temporary at best.
Old 05-26-2005, 06:24 PM   #6
Airstream Driver
1997 30' Excella
Images: 51
Originally Posted by 74Argosy24MH
....... When it gets hot the coolant evaporates before it has a chance to show as a leak.......
John
John, that makes sense. So ist just a matter of time til she blows. I guess i have my memorial day weekend planned out.
Peter.
Not my kinda thing unless I find myself in a real bind going down the road 5003 miles away from home.......
As you probably know, I always despised crappy workmanship (radiator rebuild in this case) and sure don't want to add insult to injury.
AIR #13
Old 05-28-2005, 04:31 PM   #7
Airstream Driver
1997 30' Excella
Images: 51
It was a loose hose clamp on the upper back of the radiator, which is practically unreachable and can not be visually inspected.
This explains the leak going away after complete warm up. (the rubber getting warm and is expanding)
Live and learn.....
AIR #13
Old 05-28-2005, 04:49 PM   #8
Peter.
This isn't a "Tall Texas Tale" by chance, is it?
Old 05-28-2005, 05:05 PM   #9
Airstream Driver
1997 30' Excella
Images: 51
Peter.
Which part, the leak or the fix?
I have to agree, they both sound pretty weird.
Keep Austin weird.
AIR #13
Old 05-28-2005, 05:37 PM   #10
LOST , Hawaii
Originally Posted by PeterH-79MH
Keep Austin weird.
I like that, sounds like a good place to be.
John
Old 06-06-2005, 09:09 PM   #11
alfalsetto's Avatar
1982 31' Airstream 310
Longview , Washington
This not the time to be Joking around. The poor Man's working on a water leak.
alfalsetto is offline   Reply With Quote
Old 06-06-2005, 11:34 PM   #12
dscluchfc's Avatar
1984 31' Excella
Abernathy , Texas
Keep Austin weird.
And "Keep Lubbock Flat".....
David
TAC # TX-18
AIR # 410
http://www.flickr.com/photos/dsphotoscapes
dscluchfc is offline   Reply With Quote
Water leak panoramic windows Andy Fay Windows & Screens 16 01-05-2007 08:33 AM
'99 25' Safari water leak driving me crazy Raptorrider2001 1999 Safari 4 12-06-2002 06:34 PM
Rainwater leak James Schmidt Leaks - Weatherstrips, Gaskets, Caulks & Sealants 8 09-11-2002 06:28 AM
Leak in Water System Rich Palmieri Fresh Water Systems 6 06-27-2002 06:17 AM
Help with Coolant Level winner Mechanics Corner - Engines, Transmission & More... 6 04-24-2002 04:47 AM
