Old 07-13-2008, 09:40 PM   #1
Bloomington , Minnesota
My Alternator is connected to... This?
My understanding is that my 12si alternator has an internal regulator.
So, what the heck is this thing?
It is mounted on the alternator bracket.
Any info on connectivity appreciated!
Pic's attached.
Thanks!
ID:	63600   Click image for larger version
drfw is offline   Reply With Quote
Old 07-13-2008, 10:36 PM   #2
ronstory's Avatar
1975 23' Safari
Portland , Oregon
drfw--
Are you sure it's a Delco 12si (or clone)? I've seen a lot of them, clocked all different ways... but never with that connector.
Ron
ronstory is offline   Reply With Quote
Old 07-13-2008, 10:57 PM   #3
My Grandparents Airstream
Andrew Selking's Avatar
2007 28' Safari SE
Hillsboro , Texas
Images: 18
Send a message via AIM to Andrew Selking
That is the blower relay. It has nothing to do with alternator . It might be mounted by or near the alternator . I have replace many over the years working on cars and trucks.
Andrew Selking
WBCCI #6062
International 3rd Vice President
"Airstream the Best trailer ever built."
Andrew Selking is offline   Reply With Quote
Old 07-13-2008, 11:18 PM   #4
guy99's Avatar
1984 31' Airstream310
Dunsmuir , California
Images: 16
I have one of those which is actually my starter relay.
1984 310 Limited Motorhome
guy99 is offline   Reply With Quote
Old 07-14-2008, 06:00 AM   #5
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
It is a multipurpose relay. In this case, it could engage when you energize it, and route some of the alternator's output to the house batteries. If used in that manner, it would be a crude, but effective, isoltion switch.
Old 07-14-2008, 10:01 AM   #6
I did a bit of wire tracing.
Looks like she goes to the starter among other things.
must be a starter relay.
how does it work?
IE:
alternator/Batt parallel connected as big juice to output when triggered?
ignition switch start postion juice as input trigger?
Big juice output to starter solenoid?
There is a fourth wire that may go to the coil or something.
Old 07-14-2008, 04:50 PM   #7
OK
I believe I have the answer.
This relay is known in the biz as a "hot start" relay.
They are commonly used in GM starter applications to feed a nice big flow of current to the (super hungry when hot) solenoid/starter.
please find connectivity explanation link below.
http://www.type2.com/bartnik/images/relay.gif
Lots of cats are using the old ford type bypass solenoids to fix the hot start issue.
Please see the link below.
(It's a link to an online catalog, but it has a well written explanation for the application.)
Catalog
Best to all of you.
Old 07-14-2008, 11:07 PM   #8
ronstory's Avatar
1975 23' Safari
Portland , Oregon
drfw--
Glad to hear to worked out.
Ron
Old 07-15-2008, 07:10 AM   #9
Please note:
Airstream originally wired the genny's 12v feed directly to the engine starter.
Unfortunately, using the old ford type bypass solenoid as a hot start fix will kill 12v power to your genny, unless you rewire the genny 12v feed to somewhere other than the starter.
drove off with cord connected jparks Electrical - Systems, Generators, Batteries & Solar 2 11-14-2007 05:29 AM
Which battery (batteries) are connected to solar? Santart Land Yacht/Legacy Motorhomes 1 08-29-2007 05:15 PM
Leaving trailer connected to 110 ac? jglabrown Electrical - Systems, Generators, Batteries & Solar 1 09-28-2006 09:36 AM
can the univolt be operated without batterys connected 0557 Batteries, Univolts, Converters & Inverters 5 08-01-2004 08:48 AM
TV connected & on shore power? Kistler Audio, Video & TV 4 04-03-2004 05:12 AM
