Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Mechanics Corner - Engines, Transmission & More...
Old 07-13-2008, 09:40 PM   #1
drfw
Profile:  Bloomington , Minnesota
My Alternator is connected to... This?
My understanding is that my 12si alternator has an internal regulator.
So, what the heck is this thing?
It is mounted on the alternator bracket.
Any info on connectivity appreciated!
Pic's attached.
Thanks!
ID:	63600  Click image for larger version
drfw is offline   Reply With Quote
Old 07-13-2008, 10:36 PM   #2
ronstory
ronstory's Avatar
Profile:  1975 23' Safari
Portland , Oregon
drfw--
Are you sure it's a Delco 12si (or clone)? I've seen a lot of them, clocked all different ways... but never with that connector.
Ron
ronstory is offline   Reply With Quote
Old 07-13-2008, 10:57 PM   #3
Andrew Selking
My Grandparents Airstream
Andrew Selking's Avatar
Profile:  2007 25' Safari FB SE
Fort Worth , Texas
That is the blower relay. It has nothing to do with alternator . It might be mounted by or near the alternator . I have replace many over the years working on cars and trucks.
Andrew Selking
WBCCI #6062 VAC
"Airstream the Best trailer ever built."
Andrew Selking is offline   Reply With Quote
Old 07-13-2008, 11:18 PM   #4
guy99
guy99's Avatar
Profile:  Dunsmuir , California
Images: 16
I have one of those which is actually my starter relay.
1984 310 Limited Motorhome
guy99 is offline   Reply With Quote
Old 07-14-2008, 06:00 AM   #5
overlander63
overlander63's Avatar
Profile:  1974 31' Sovereign
Still in the trailer , Fulltiming
Images: 58
It is a multipurpose relay. In this case, it could engage when you energize it, and route some of the alternator's output to the house batteries. If used in that manner, it would be a crude, but effective, isoltion switch.
Change is inevitable, except from a vending machine
AIR#2611
Old 07-14-2008, 10:01 AM   #6
drfw
I did a bit of wire tracing.
Looks like she goes to the starter among other things.
must be a starter relay.
how does it work?
IE:
alternator/Batt parallel connected as big juice to output when triggered?
ignition switch start postion juice as input trigger?
Big juice output to starter solenoid?
There is a fourth wire that may go to the coil or something.
Old 07-14-2008, 04:50 PM   #7
drfw
OK
I believe I have the answer.
This relay is known in the biz as a "hot start" relay.
They are commonly used in GM starter applications to feed a nice big flow of current to the (super hungry when hot) solenoid/starter.
please find connectivity explanation link below.
http://www.type2.com/bartnik/images/relay.gif
Lots of cats are using the old ford type bypass solenoids to fix the hot start issue.
Please see the link below.
(It's a link to an online catalog, but it has a well written explanation for the application.)
Catalog
Best to all of you.
Old 07-14-2008, 11:07 PM   #8
ronstory
ronstory's Avatar
Portland , Oregon
drfw--
Glad to hear to worked out.
Ron
Old 07-15-2008, 07:10 AM   #9
drfw
Please note:
Airstream originally wired the genny's 12v feed directly to the engine starter.
Unfortunately, using the old ford type bypass solenoid as a hot start fix will kill 12v power to your genny, unless you rewire the genny 12v feed to somewhere other than the starter.
drove off with cord connected jparks Electrical - Systems, Generators, Batteries & Solar 2 11-14-2007 05:29 AM
Which battery (batteries) are connected to solar? Santart Land Yacht/Legacy Motorhomes 1 08-29-2007 05:15 PM
Leaving trailer connected to 110 ac? jglabrown Electrical - Systems, Generators, Batteries & Solar 1 09-28-2006 09:36 AM
can the univolt be operated without batterys connected 0557 Batteries, Univolts, Converters & Inverters 5 08-01-2004 08:48 AM
TV connected & on shore power? Kistler Audio, Video & TV 4 04-03-2004 05:12 AM
