Old 04-12-2016, 06:22 AM   #1
Mud flap source
I've been poking around online looking for mud flaps for my Argosy without any real luck.
Anyone know of a source for truck mud flaps that will fit our motorhomes?
On a related note I was crawling around underneath Peanut this weekend and noticed the propane tank is right behind the right rear wheel. Peanut doesn't have any mud flaps either and thinking about it, it seems like a pretty dangerous situation to have a propane tank in that location with no protection
I think I'm going to recommend to Martin before he drives Peanut anywhere that mud flaps should be installed!
Old 04-12-2016, 07:37 AM   #2
shepherd57's Avatar
1985 32.5' Airstream 325
Lindsay , Ontario
When I bought my 75 26ft Argosy it had no mud flaps and the propane tank was in the same place. Before I could get the propane system cert I had to replace all of the copper propane lines. They were almost collapsed flat from the stones coming off the tires.
I went to the truck wreckers and got some rubber mud flaps off heavy trucks. I got some that had no logos on them.Just make sure they are not to heavy there was 2 styles.One is a real thick rubber and the other is thinner and lighter.
Get the lighter ones some times you can get 2 flaps from 1 big one. Just make a cardboard temp. Sometimes they will give the flaps to you.
I had to make 2 rear flaps for my 32.5 you just need a sharp razor knife
shepherd57 is offline   Reply With Quote
Old 04-12-2016, 09:02 AM   #3
2020 Classic 33 on order
Box Elder , South Dakota
Try the folks at www.duraflap.com. They can probably make whatever you want.
Gary
2020 Classic 33 Twin, 2019 Ram 3500 Longhorn, ProPride
NØVPN
ghaynes755 is offline   Reply With Quote
Old 04-12-2016, 09:07 AM   #4
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
I guess we need three sets because Bella doesn't have any either....
martin300662 is online now   Reply With Quote
Old 04-12-2016, 09:08 AM   #5
Keen amature
1975 20' Argosy 20
Chestfield , Kent
Just an idea but why couldn't the 'flap' be part of a complete inner wheel well and wrap right around?
Old 04-12-2016, 09:34 AM   #6
John,
I'm thinking the propane lines need to be looked at on Peanut as well. A cursory check shows the lines to be loose in places which worries me a bit.
Unfortunately for me there are no salvage yards anywhere near close to me that are worth looking through. Good salvage yards are one something I miss living in this area of Kentucky. If they are around here they've stayed well hidden!
Old 04-12-2016, 09:37 AM   #7
Thanks Gary, I'll poke around on their website to see what's available.
Old 04-12-2016, 09:41 AM   #8
Martin, I can't quite picture what you're describing.
The back wall of the Airstream motorhome wheel wells are flat with holes for mounting mud flaps. The originals were basically flat sheets of rubber like John described with the word AIRSTREAM embossed on them.
Old 04-12-2016, 11:59 AM   #9
shepherd57's Avatar
Lindsay , Ontario
All of the line clamps on my Argosy were all loose to I had to redo all of the lines and clamps in the area ahead of the tank and I also had to replace the regulator.
How many flaps do you need I can check the truck wreckers where I got mine to see if he has any.
Old 04-12-2016, 12:30 PM   #10
I have the front mud flaps from the 345 but still looking for the rears.
I found these Mud Flaps on Amazon. They might need to be cut down but the price isn't to bad.
Old 04-12-2016, 02:20 PM   #11
Keen amature
1975 20' Argosy 20
Chestfield , Kent
Not sure how practical it is but was think something like this.
Attach at the front and back vertical edge but creates a loop from front over the tire to the back and carries on to be the flap - almost to act as an inner wheel well.
Old 04-12-2016, 02:29 PM   #12
Ok, I see what you're getting at.
It would need to be somewhat rigid to hold the arch properly and I'm not sure you would want rigid mud flaps. The existing wheel well housings are ABS plastic and covering the inside of the wheel wells with an arched panel certainly couldn't hurt matters in that area.
Old 04-12-2016, 03:26 PM   #13
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
I would love to find a pair of these. These are on Mike Leary's 310.
Name:	ImageUploadedByAirstream Forums1460496358.137411.jpg
mayco is online now   Reply With Quote
Old 04-12-2016, 07:51 PM   #14
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
Check with inland RV.
bobmiller1 is offline   Reply With Quote
Rock Tamers Mud Flap System au_ee Tow Vehicles 42 10-28-2016 06:50 AM
Mud Flap Mounting jdalrymple Tow Vehicles 38 06-04-2013 08:24 AM
Splash Guard/Mud Flap Bob & LaVon Land Yacht/Legacy Motorhomes 0 05-17-2010 01:24 PM
'08-'09 Duramax Mud Flap Advice Sought AirsDream Tow Vehicles 10 01-21-2009 07:17 AM
Mud flap ground clearance? hazegrey Hitches, Couplers & Balls 4 10-31-2007 08:42 PM
