Old 03-31-2006, 07:37 AM   #1
Gunter
gunner's Avatar
2000 35' Land Yacht XL w/2 slides
Greenville , Ohio
Motorhome Heater Line Shutoffs
For those of you that have installed the front/rear/water heater water line shutoffs, I have the following questions:
Did you place the shutoffs under the Engine doghouse between the Engine water heater outlets and the "Y" where the water lines seperate for the front heater and the rear/water heater?
Or did you locate the shutoffs under the Engine doghouse after the "Y" and only shutoff the rear/water heater?
Or what other alternatives did you come up with?
For all situations what shutoffs did you purchase, size and where did you locate them? Do you shut them off in the summer to keep the coach cooler and how did that affect Engine temperature?
Thanks for your replies,
gunner is offline   Reply With Quote
Old 03-31-2006, 07:48 AM   #2
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
No rear heater in my coach, but for my front heater, i used a shutoff easy available at any plumbing supply store and its easy to operate (does not freeze up).
Yes, driving in the hot summer month with the heater cores closed will cause the engine to run hotter.
1991 25' Excella Trailer
1990 25' Excella Trailer
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Old 03-31-2006, 04:49 PM   #3
Gunter
gunner's Avatar
Greenville , Ohio
My assumption is you just wanted to keep the heat out of the interior during the summer or shut it off if you had a hose burst on the road but for that you would need two shutoffs. Thanks for your reply, I am still hoping for a reply from all of the 345 owners that have the rear heater and water heater using the engine heater hoses and installed shutoffs to provide me guidance.
One other question I have what is the Warn: (0%) under my profile? I did have two rivets at one time but I had to reregister since the system did not recognize me anymore and I am now listed as a new member.
Old 03-31-2006, 05:36 PM   #4
RivetAddict
swebster's Avatar
1986 34.5' Airstream 345
Louisville , Kentucky
Gunner,
Welcome back. The "warn" is new and something only you see for your profile. There is a thread somewhere around here about how it works...but basically 0% mean you have no warnings so don't worry about it.
I have a 345 with the rear heater. I completely removed the line to this heater after they burst. I would consider adding it back in but would plan independant shutoff valves for the front heater and the rear.
You are correct about the "why" - to completelty disconnect the heaters in summer (it makes a big difference) and to isolate these vulnerable systems in the event of a hose bursting while enroute.
Steven Webster
1986 Airstream 345 Classic Motorhome
AIR 1760
swebster is offline   Reply With Quote
Old 03-31-2006, 05:58 PM   #5
GlenCoombe's Avatar
1984 28' Funeral Coach
Belleview , Florida
Images: 27
If you're concerned about higher engine temps in summer with the shutoffs closed "Y" not install a cooler thermostat? Makes all the difference in the world.
Glen Coombe AIR #8416
Former Rolling Showroom & PuttLab (now party bus)
"I'm not an expert. But I did sleep in an Airstream last night."
GlenCoombe is offline   Reply With Quote
Old 03-31-2006, 06:32 PM   #6
noiva's Avatar
Chesapeake , Virginia
Images: 46
shutoffs
Did you place the shutoffs under the Engine doghouse between the Engine water heater outlets and the "Y" where the water lines separate for the front heater and the rear/water heater?
I put shutoffs on my 370 about 2 months ago when I replaced all the water hoses to both front and rear heaters. I put them in the hoses before the "Y" in the sending and return lines under the doghouse close to the engine. That was to be able to completely shut off the water to both just in case either decided to spring a leak. I purchased my shutoffs at a NAPA store. They have a screw type wing fitting that turns to a complete stop. They were rather pricey, but I feel so much better now about potential leaks. I haven't tried running the coach yet with the valves off, but I will soon just to see if things run hotter. I've already put a lower temp thermostat that has really helped bring the temps down about 20-25 degrees. I like PeterH's valves a little better than mine because they're simple and easy to operate (cheaper too ). I wish I had thought of those , but it's not critical. I did put grease on the shutoff threads so they wouldn't rust open (or shut). I can send you pics or part numbers if you would like, but I think PeterH's pic just about shows what you probably were looking for.
Hope this helps.
Best,
Tim
1987 30P
2003 Suburban 2500
AIR # 5648
noiva is offline   Reply With Quote
Old 04-01-2006, 06:38 AM   #7
Gunter
gunner's Avatar
Greenville , Ohio
Thanks for all of the replies. I like Peter's shutoffs, just a quarter turn shuts it off. I did look at the catalogs and was somewhat surprised by the max temperature of 160 F that even some of the brass valves are rated for. I need to make sure I purchase Brass valves with a higher allowable temperature rating. I assume Peter purchased barb fittings that screw into the valves for the hoses. Normally in the automotive world one of the hoses is 5/8" and the other 3/4". Is this the case with the motorhomes? I have already installed a lower rating thermostat.
Old 04-01-2006, 06:56 AM   #8
noiva's Avatar
Images: 46
I can't speak to the size of the hoses in the Chevy 454, but the Ford 460 in my 370 MoHo had all 5/8". I wasn't aware of the temperature ratings on Peter's valves, if that's true; but I do know the valves I purchased at NAPA were for big trucks, and automotive by design. If you have any concerns about temps, you may be better off spending that extra money. Of course, since Peter apparently hasn't had any temp problems with his valves, that may not be a concern.
Best,
Tim
1987 30P
2003 Suburban 2500
AIR # 5648
Old 04-01-2006, 03:53 PM   #9
Gunter
gunner's Avatar
Greenville , Ohio
The brass valves according to the catalog meet different temperatures based on costs and internal mechanical components. I am sure Peter's valves meet the requirements, I just didn't realize that I had to make sure of the temperature rating. I thought all brass valves would meet the Engine temperature requirements.
Old 07-16-2006, 05:45 PM   #10
str8strm's Avatar
1985 34.5' Airstream 345
Tujunga , California
What did you end up using?
We are going to put shut offs in our 345 what did you use and what was the source? It was a future project til we developed a small leak on the way home today. Didn't someone say it takes about 50 feet of the 5/8 hose. I did a search but can't find that thread? Debbie
Ron and Debbie Lawrence
1985 345 Motorhome...... delightfully tacky......yet unrefined
AIR 7992
str8strm is offline   Reply With Quote
Old 07-16-2006, 08:08 PM   #11
noiva's Avatar
Images: 46
Debbie,
Here's the thread I started after I did the shut-offs. http://www.airforums.com/forum...ent-20141.html I think my first post may be helpful with some of your questions, but if you need any further info., please let me know. Your 345 has just about the same heater setup as the 370, so the items and methods should be very similar. Don't forget to change to a 160 degree thermostat if you have ANY concerns about your present running temps . Glen Coombe can attest to the benefits also. It's the best heat control I've done to my unit. Just got back today from almost 300 miles with outdoor temps in the mid 90s. Averaged about 200 degrees in the engine running just about 60 mph with the dash AC providing all the cooling in the coach. Gear Vendors under/overdrive is waiting in the garage for installation (hopefully ) this week. My rear axle is a 5.29, so I need to slow this rpm down.
Best,
Tim
1987 30P
2003 Suburban 2500
AIR # 5648
Old 07-17-2006, 12:53 PM   #12
str8strm's Avatar
Thanks we got our gear vendor going about 4 months ago. Its about 600 rpm less and really rolls---too easy to look down and be going 75!!
AIR 7992
Old 07-17-2006, 01:22 PM   #13
noiva's Avatar
Images: 46
Glad to hear about your experience with the gear vendors. I don't really need to do 75 , but 65 would be nice. Did that link work for you? I just clicked it and went right back to the main Forum page.
Tim
1987 30P
2003 Suburban 2500
AIR # 5648
Old 05-21-2013, 09:01 PM   #14
1982 24' Airstream 240
Farmington , Missouri
Hey friends, in my search for cab AC answers I came across this thread and the "valve" question. I also have a valve there that I was unsure about. Mine is just a twist knob like you might see on a outside spigot. From what I have read, my cab AC might blow colder if I close this?? (which I will try in the morning) And at the same time it might (will) raise my engine temp?
There have been several mentions about installing a cooler thermostat to help lower the engine temp. I'm not a big engine components type of guy but can figure things out when I have great mentors...and instructions! Could someone explain to me (pics?) how a thermostat actually cools the engine and where it is located. I would totally replace mine if its a job I can do and does the trick. Which one would you recommend. Does it just turn the fan on more often?
Timotreous is offline   Reply With Quote
LP supply line uwe LP Gas, Piping, Tanks & Regulators 9 06-17-2009 02:49 PM
Water Heater Craig 1978- 1979 Excella 500 7 10-01-2007 05:16 PM
Motorhome Mechanix Motorhome Mechanix Airstream Motorhome Forums 1 10-27-2002 12:17 PM
Oven gas line broken lbrodsky LP Gas, Piping, Tanks & Regulators 4 07-23-2002 03:52 AM
Water Heater shell frame BobbyW Water Heaters, Filters & Pumps 0 04-29-2002 10:21 AM
