Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Mechanics Corner - Engines, Transmission & More...
Old 11-18-2013, 06:26 PM   #1
SebasSF's Avatar
1991 30' Airstream 30
San Francisco , California
Motor noise vs fan noise vs overdrive question
Have a 1991 300LE, and found out after I got it that it has overdrive (really cool!). I found out by getting it going rather fast one day, everything got really quintet all of a sudden...it was like warp drive! Having done some research, I think I have a 4L80E transmission. Problem is, OD only kicks in at 65 and this is faster than I usually drive unless I'm on a wide open highway. As soon as I drop down to 60 or 55, I get much more noise from the motor. I can't tell if it's dropping out of OD or if it's a fan...?
Does anyone know how I can get that nice quiet OD cruise at 55 mph? Thanks, Sebastian
SebasSF is offline   Reply With Quote
Old 11-18-2013, 07:29 PM   #2
Retired.
. , At Large
Higher gearing in the rear axle. You probably have something like 4.10 gears, you could go with, say 4.50. Get quicker pick-up off the line, to boot.
Old 11-18-2013, 08:18 PM   #3
dznf0g's Avatar
Oswego , Illinois
4.5 would be a lower gear. Higher numerically means lower gearing.
-Rich-
Old 11-19-2013, 05:26 AM   #4
"Cloudsplitter"
Thumbs up
Make sure the TV,(throttle valve) cable is adjusted properly, no slack, but little tension usually does it. May take several road tests.
A lot of folks call it the "kick down" cable...rong.
It's the bottom cable in this stock photo.
Check the fan clutch for the roar sound, should only "roar" with engine hot, spin free with engine cold, not running.
Old 11-19-2013, 05:35 AM   #5
Retired.
. , At Large
Semantics...
I was always told that was the detent cable. It moves the valve body in the transmission to change shift points. A 4L80E should not have one, since it's electronically controlled.
Old 11-19-2013, 06:00 AM   #6
"Cloudsplitter"
Thumbs up
Ah yes 700r4...lost track of time again.
Pressure test in order.
Old 11-19-2013, 08:30 PM   #7
SebasSF's Avatar
So, a transmission shop can't remap the transmission controller to kick in OD at a lower speed?
I could see the fan clutch turning off at a higher speed due to increased cooling, but it seems odd that it would kick back on at 55 and off at 65...does not sound temp related, but the noise sounds fan related. I guess I could replace the fan clutch and see if that makes a difference.
Thanks for the feedback
Old 11-19-2013, 09:52 PM   #8
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
I'm curious if you have a tachometer? That would be the easiest way to tell if the trans is dropping out of OD. Temperature change would indicate the fan clutch engaging.
I'm more old school but I would think the trans shift points could be adjusted by linkage adjustment or computer re-map or a combination of both.
Cheers, Dan
~ Margaret Thatcher ~
Old 11-20-2013, 05:49 AM   #9
"Cloudsplitter"
Question
Are you sure of your chassis year? You may be on the cusp of a tranny change.
You may have a 91 AS with a 89-90 chassis. Ck the linkage.
Ck fan cold & after warm-up, ck how difficult the fan is to rotate. Easy cold difficult warm.
Old 11-24-2013, 10:19 PM   #10
SebasSF's Avatar
My chassis is a 1990, and I guess the trams with OD came put in 1991, but I don't know if that would be "model year" so same as mine, but I'm convinced I have the OD. I got her out for a drive today, and same thing...up to 60- 65mph and it gets really quiet. I don't see a drop in rpm, and when I get back down to 55 or 50, the noise starts up again. What's weird is it seems speed or rpm related as the temp is not really changing. I also tried really putting the boots to it off the line as had not tried this yet...for some reason, it ran quite in the lower gears for a short while?!? I have an electric fan on the front as well. I have not figured when that comes on, or if it's on a thermostat. I guess I could unplug it next time I go out. Always an adventure.
Old 11-24-2013, 10:36 PM   #11
SebasSF's Avatar
The 4l80e has 17 bolts...will count next time I'm on location.
Old 11-25-2013, 06:45 AM   #12
"Cloudsplitter"
The electric fan should come on when the engine reaches a specific temp controlled by a sensor and/or when the AC is on.
The fan clutch is on the engine cooling fan, behind the radiator. The fan should spin free with little resistance with a cold engine. If it's hard to spin it will roar on acceleration and be somewhat quieter at lower cruising rpm's.
Do you have a second cable attached to the the throttle linkage?
A lock-up torque converter can feel like OD but will not drop the RPM's.
Old 11-25-2013, 09:37 PM   #13
SebasSF's Avatar
Hi Bob, I have a second cable, but it's for the cruise control.
Lockable-up torque converter eh? I had to read up on that one, and I think you are correct!
Now I wonder why it only kicks in at such a high speed, and how can I get it down to 55? I will see if a transmission shop can adjust it. I also read there are a couple sensors that can be cleaned and throttle position sensor calibrated.
The Powertrain Control Solutions Simple Shift TCU also looks like a good solution...
Old 11-26-2013, 05:03 AM   #14
"Cloudsplitter"
It's easy to tell the difference between cables. The cruise cable will attach at the same point at or near the throttle cable.
The TV cable attaches at a point on the linkage that sends throttle position information the the transmission.
The TV cable gets pulled, the cruise cable does the pulling.
Old 11-26-2013, 06:27 AM   #15
Retired.
. , At Large
The lockup torque converter is controlled by the PROM in the ECM. I remember from the good old days, many torque converters were supposed to engage around 35 or so. If the PROM has been re-flashed, one of the things that is changed is the lockup point of the torque converter. If this has happened, it generally cannot be undone.
Old 11-26-2013, 11:14 AM   #16
Andrew T's Avatar
2019 27' Tommy Bahama
London , Ontario
I drive a 91 350LE quite regularly and it will cruise a 50 MPH in overdrive. If you have the 480 Transmission you do not have a speedometer cable.
However the easiest way to know is look at your gear selector it would have PRND321 with D being the overdrive postion. Also in overdrive you will be around 2100 RPM at 65 MPH if you are closer to 3000 then it is a 3 Speed.
I hope this helps.
Andrew T
Andrew Thomson
London, Ontario
"One test is worth a thousand expert opinions."
Tex Johnston, Boeing 707 test pilot
Andrew T is offline   Reply With Quote
Old 11-26-2013, 06:03 PM   #17
SebasSF's Avatar
Hi Andrew, good point, and it looks like I have a three speed...crapola. So what do I have? I guess it has a lockup torque converter...
I will take some photos this weekend.
Old 11-26-2013, 07:04 PM   #18
Retired.
. , At Large
The howling may be a bad/locked up fan clutch. If you do get a new one, get a thermal fan clutch.
Old 11-27-2013, 01:11 AM   #19
Andrew T's Avatar
London , Ontario
The 3 speeds did not originally come with a lock up torque convertor so unless the transmission has been changed I doubt you have one. Bob is likely correct that you have an over zealous fan clutch. It is normal for them to howl for the first couple of miles after a cold start and when climbing or in stop and go traffic but not all the time at highway speed.
We have changed a couple of 3 speeds over to the 480 with the lock up torque convertor and overdrive. The transmission just bolts in but you need an aftermarket computer module to manage it and another company makes a little motor that drives the speedometer for you.
Andrew T
Andrew Thomson
London, Ontario
Old 11-27-2013, 05:41 AM   #20
Retired.
. , At Large
Interestingly, I used to work for a company that builds torque converters. One of my R&D projects was making a locking torque converter for the TH400/TH475. We discovered that locking the torque converter really didn't accomplish much except removing the ability of the engine to climb into a higher torque band under load, there was no significant saving in engine rpm or fuel consumption. I shelved the project, and we moved forward on making a better torque converter for the Ford E4OD used behind the 7.3 diesels, which at the time were suffering a higher than expected failure rate.
