Old 12-26-2009, 12:02 PM   #1
Glendale , Arizona
MoHo Drivetrain Performance?
Not sure if I am in the right zone here..but I am new looking for insight into purchase of an Air Stream RV. Any insight into the power ratio of a 5,9 cummins on a 95 36Ft RV?
I am wondering if this unit will be seriously underpowered. I check with Banks Power, and they claim they can up power a 5.9 to 259hsp, pulling a 6% grade in their test at 70mph. Any insight for the Air Stream Seach guy...cheerio..karl
dene57k is offline   Reply With Quote
Old 12-26-2009, 12:20 PM   #2
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
Is that a Classic or a Slabside?
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 12-26-2009, 06:18 PM   #3
Diesel Phil's Avatar
1994 36' Classic 36 Diesel
Christmas Valley , Oregon
36ft.classic
Hi in AZ. The Classic is 18000 empty, 20000 loaded.The 5.9 is rated @ 230 hp stock.It uses the Allison md3060 6spd.W/ 5&6 being overdrive .
Cummins reccomends 100h.p. per 10,000 lbs. We have been all over the western states on our summer job & kept up with traffic @ 75mph.
we tow a jeep wrangler 4000 lbs.
In the real heat ,I have to watch temps ,water & pyro,in fact one of my spring projects is to pull rad.replace with bigger ,better ,elect fan,engine oil cooler & whatever will help with problem .
The 5.9 cummins is a proven engine ,that will make lots of power,more power more heat,getting the heat out is what I need to work on , any suggestions would be welcome. Welcome to the forums & hope you find a good one. Phil & Sandy. Christmas Valley, Oregon
Diesel Phil is offline   Reply With Quote
Old 09-28-2010, 09:24 PM   #4
Registered User
1998 34' Excella 1000
1995 36' Classic 36
Spencerville , Maryland
Images: 14
I'm interested to know what others have found in their travels with the 5.9... I just bought mine and am pleased with its performance so far. Any mods to consider?
GREENovaters is offline   Reply With Quote
diesel performance norbert Tow Vehicles 15 01-04-2010 08:23 PM
Drivetrain Swap GlenCoombe Mechanics Corner - Engines, Transmission & More... 3 03-30-2008 09:37 AM
In praise of P30 chassis - drivetrain mods Taxman Mechanics Corner - Engines, Transmission & More... 24 02-13-2007 08:45 PM
Performance changes using the new diesel Stream 1529 Off Topic Forum 19 12-24-2006 04:35 PM
Power Available vs. A/C Performance JimGolden Furnaces, Heaters, Fireplaces & Air Conditioning 11 07-13-2006 08:10 PM
