10-05-2010, 01:16 PM
1984 31' Airstream310
Ajo
mo/ho question: huh?
We had a 310 Diesel, same year, come into the campground and the owner showed me a part that came with the coach. Anyone have a clue what it is/does/did? I can't make out the manufacturer (it is made in the U.S.A.). Looks like a motor of some kind, but I've not seen anything like it on our coach.
10-05-2010, 01:18 PM
1951 21' Flying Cloud
1960 24' Tradewind
Folsom
my guess would be window winder (do they have electric power windows?) or windshield wiper motor . . .
Aluminumbskull with Led Balloon in Drag
Birch Plywood and Aluminum go together like
Peanut Butter and Chocolate
10-05-2010, 02:59 PM
2012 31' Classic
1999 36' Land Yacht Widebody
Andalusia
, Alabama
It's a windshield wiper motor.
10-05-2010, 03:20 PM
Gunter
1966 24' Tradewind
Greenville
, Ohio
I agree with Robfike, windshield wiper motor.
Gunter
2000 Land Yacht XL 355
10-05-2010, 03:29 PM
Ajo
Well done, sharp-eyed forum members! I just looked at mine and though it's a different model from some other coach, it is indeed a wiper motor.
10-08-2010, 02:00 AM
1982 28' Airstream 280
Port Angeles
While you were looking do you have one or two wiper motors? I have two and the drivers side motor died on the road and I had to do some creative fudging to make a NAPA unit work. A few months later the end of the link from the motor to the wiper mount post broke. I was lucky to find a truck shop to weld it back on for me. Now I hesitate every time I turn the wiper on.
Cheers, Dan
10-08-2010, 10:07 AM
1960 24' Tradewind
West Coast
, BC
Cheers, Dan
RainX your windshield. Works great when traveling, and when you do have to use your wipers they seem to work far better. If you kept the old wiper motor find an electric motor repair shop and get them to fix it. Cost me about $100, well worth it to have the proper wiper in my '57.
Barry & Donna
Life is short - so is the door on a '51 Flying Cloud (ouch)
10-08-2010, 11:48 AM
Ajo
I have two wiper motors and they've never been serviced. Looks like the typical AS bearcat to get at. I too, cross my fingers every time I turn them on. Another good reason to winter in Arizona! That motor that was in the other guys mo/ho would never fit ours, I think the PO got it given to him by a well-meaning friend.
10-08-2010, 12:09 PM
moderator
2016 27' International
Wilton
I think airstream assembled the dash and suspended it by wires.. and then built the coach around it.. never considering the poor sap that had to work in and around that mess.. I saw the wiper motors and thought to myself I hope they continue to work!
10-08-2010, 12:32 PM
Central
, Mississippi
... Anyone have a clue what it is/does/did? I can't make out the manufacturer (it is made in the U.S.A.). Looks like a motor of some kind, but I've not seen anything like it on our coach.
wow, flashbacks...
I worked for a company that supplied components to the place that made that motor. Yup, it's a windshield wiper motor and it was built for heavy truck/RV/Aftermarket use in Columbus Mississippi- the facility went thru several name/owner changes and finally closed in the late '90's. Some of the products ended up transfering to China when Globe Motors shut it down.
anyway
That's kinda a neat motor. The rear of the housing is adjustable to "park" the wiper where its' needed!
10-08-2010, 12:46 PM
Ajo
Wow! That is cool, I wondered what the increments were all about. Thanks.
10-08-2010, 01:09 PM
Port Angeles
The wipers actually clear the windshield pretty well. The problem was I was on a trip with time limits. Mill Supply has the motors but it wasn't an option on Friday afternoon on a rainy weekend. I think the core charge from NAPA was almost as much as the motor. If I remember the motor was $65 and the core was $35 or $40. The mount was easy but finding the right fitting to connect the link was the problem. Also had to fudge the wiring and couldn't get the park to work with my switch just had to turn off when the wiper was down. A bit of a pain but better than no wiper.
Cheers, Dan
10-08-2010, 01:23 PM
Port Angeles
Actually it's pretty easy to remove and reinstall. The worst part is the little spring retaining clip. It's real hart to find on wet asphalt.
You may run to Arizona Mike but water is the basis of life and I prefer green and trees to sand and cactus. I'll stay North and play with the wiper motor.
Cheers, Dan
