Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Mechanics Corner - Engines, Transmission & More...
Old 03-22-2002, 09:38 AM   #1
FrankR
Profile:
MH front wet hubs
The change to front wet hubs is a good upgrade. In most cases the hubs can be modified by a few drilled and threaded holes. All the long haul trucks use this method of hub lube. The lube is usually 75-90 synthetic gear oil. The only down side is when doing any repair/maintence, the hubs must be drained before disassembly. The rear axle hubs are already lubed this method. Ya know ...just a thot..... Frank
Visit Idaho The people are great
FrankR is offline   Reply With Quote
Old 07-19-2002, 03:31 PM   #2
74Argosy24MH
Profile:  LOST , Hawaii
Wondering if you thought any more about this, what to use for the outer cover, clear would be nice to check the level, and what to use for the inner seal, not sure if the grease seal would work for oil. Does sound like a good idea, just wondering if you had done any searching for parts, etc.
John
74Argosy24MH is offline   Reply With Quote
Old 07-19-2002, 07:19 PM   #3
joepospisil
Profile:
Thumbs down caution
Unless you plan on checking the lube level in those front hubs every time you use the vehicle you will be a lot better off using it as the factory built it. There is no advantage using gear oil in the hubs over grease and the risk of the hubs running out of lube is a real down spot. Even the new semi trucks are going back to the grease type front wheels and going away from the oil type. Too much trouble running the bearings dry because of loss of oil.
Joe
joe
joepospisil is offline   Reply With Quote
front MH grill repair Astrodokk Airstream Motorhome Forums 10 03-27-2004 04:09 PM
front suspension/ ball joints wb13798 Mechanics Corner - Engines, Transmission & More... 13 11-07-2003 07:57 AM
Front dinette overlander63 All Argosy Trailers 7 08-12-2003 08:47 AM
Z71 or Z85? River Rat Tow Vehicles 7 05-09-2003 04:40 PM
MH side window frames Bfrank General Motorhome Topics 6 04-15-2003 11:15 AM
Cooking Forum - Sailing Forum - Early Retirement - Airstream Trailer - Aquarium Forum - Royal Forum - Book Forum - Yoga Forum - Volkswagen Touareg Forum - Jeep Wrangler Forum - Whitewater Kayaking & Rafting Forum - Fiberglass RV Forum - U2 Forum
