Old 11-17-2004, 11:49 AM   #15
RivetAddict
swebster's Avatar
1986 34.5' Airstream 345
Louisville , Kentucky
If you think about it $2134.00 for a GM factory crate long block with a warrantee is a great deal. When you consider the price for replacement of other "systems" like AC units, refers and a generator repowering an older motorhome for another 100K miles is a good investment.
Steven Webster
1986 Airstream 345 Classic Motorhome
AIR 1760
swebster is offline   Reply With Quote
Old 11-17-2004, 12:24 PM   #16
ViewRVs's Avatar
1977 20' Argosy 20
Charleston , West Virginia
Send a message via Yahoo to ViewRVs
Here is the parallel thread on RV.NET (Open Roads Forum).
I thought the replacement with a 8.1 engine was interesting. Anyone else done that?
Fred H.
1977 Argosy 20' Motorhome
Fred's Airstream Archives @ ViewRVs.com
ViewRVs is offline   Reply With Quote
Old 11-17-2004, 01:28 PM   #17
87MH's Avatar
1978 31' Sovereign
Images: 292
502 Carbureted....
Originally Posted by 1985air345
.....I thought the replacement with a 8.1 engine was interesting. Anyone else done that?
Haven't done it yet, but have put an awful lot of thought into it.
The 8.1 is a bored and stroked Fuel Injected 454......GM offers a 502 cubic inch engine with almost identical bore and stroke parameters as the 8.1, except they market the 502 as a carbureted prime mover. I plan to stick with a carb and not hassle with the electronics of Fuel Injection. Having thought through the best replacement engine for the 345 relieves me of a lot of pressure should a failure occur while I am on the road. Now, if a failure happens, I just have to find a GM ZZ502 fully constructed carbureted engine. Won't have to balance Carb vs FI vs Diesel. Put the pencil to the actuals - weight immediately eliminated the Diesel - engine weight is almost twice as much as a gasser. The ZZ502 comes with Aluminum heads and an Aluminum water pump - I believe the ZZ version is about 100 lbs lighter than the 502 "Truck Engine" that GM offers as a crate engine - plus, the ZZ502 is COMPLETE - every thing except headers comes in the crate.
It was a tough decision - F.I. does offer potential for fuel economy by monitoring and adjusting the spark advance, transmission shift points, and the combustion mixture.....I have opted to stay with the relatively simple and adjustable mechanical (utilizing my existing tranny) set-up when (not if) the time for an engine change comes about.
BTW - anyone contemplating an engine change out - factor in the "while you are at it" add on charges - an engine change is NOT a time to scrimp on peripherals - change EVERYTHING - alternator, belts, pully bearings, water pump, distributor, fan clutch - AND service the radiator......it's false economy to do anything less.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Old 11-17-2004, 05:29 PM   #18
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
Dennis,
This was EXACTLY what I did. The only thing that I did not replace was the Distributor. I ended up doing it in a parts store parking lot.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 11-27-2004, 05:55 AM   #19
Just a thought,
It comes to mind that the transmission has a vacuum operated modulator valve, connected to the intake manifold.
It has a rubber type diaphram in it, if it is leaking, it will cause trans fluid to be sucked into the intake manifold causing "blue smoke" out of the exhaust. also, trans oil will dissapear.
I would check out things BEFORE I replaced the engine
B.T.D.T.
ol'George
George is offline   Reply With Quote
Isuzu engine info maznblu Airstream Motorhome Forums 0 06-15-2004 10:17 AM
Suburban or Van with a 350 or 454...which do you prefer? texasphilter On The Road... 12 04-06-2004 03:05 PM
Question on 454 MH Engine RonJudi Mechanics Corner - Engines, Transmission & More... 7 01-20-2004 10:54 AM
454 engine questions Curtis-79MH Mechanics Corner - Engines, Transmission & More... 10 10-06-2003 06:22 AM
Argosy 454 engine repair in Amarillo TX saxonsraven General Motorhome Topics 5 08-01-2003 05:08 PM
