Old 06-30-2008, 07:32 PM   #15
Red Deer , Alberta
If you do put a spin on filter on your transmission you can cut open the old filters to get a good idea of the condition of your transmission. It's a pretty good idea for your engine oil filter too. And it gives you an idea of how well the filter is made, you'd be surprised at the difference between OEM and name brand filters.
canadianguy is offline   Reply With Quote
Old 06-30-2008, 08:16 PM   #16
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Originally Posted by myfirstrv View Post
Metal in Transmission Fluid
All,
Thanks for all the advise,
I got the beast back from the shop, He said there is a filter screen in there already (by factory I do not know) anyway drove it 100 miles no problems,
So the metal was like "chips" not shavings, looks like machining chips about 1/32" wide x 1/4 " long most smaller ??
Total amount of "chips" well you can spread it over a face of a dime to maybe a nickel.
Magnetic ? Yes.
Fluid was clean.
I told him I will replace the fluid in 2 months "If nothing else happens" and see what it looks like.
Rob
Two months is an excellent plan. Surprising how many people are resistant to that sort of approach. This ought to ensure you truly have fresh fluid throughout the system.
slowmover is online now   Reply With Quote
Old 07-01-2008, 09:15 AM   #17
Red Deer , Alberta
The chip was 1/32" x 1/4", but how thin was it? Like aluminum foil thin? Was it steel or aluminum?
If it's steel that type of chip comes from steel on steel rolling (without slippage), so a roller bearing, or from the face of a gear tooth. (The teeth are cut so that they roll on each other.) They aren't any cause for concern unless you're getting lots of them.
Old 03-12-2009, 10:32 AM   #18
myfirstrv's Avatar
2000 35' Land Yacht XL w/slide
Vermilion , Ohio
All,
Update
I had my fluid changed after 5000 miles and the good news is that no chips where found the fluid was clean
Regards
Rob
myfirstrv is offline   Reply With Quote
Synthetic Transmission Fluid AirHog Tow Vehicles 28 12-30-2008 11:15 AM
Brake Fluid Reservior DonaldWyllie Land Yacht/Legacy Motorhomes 3 07-15-2007 03:06 PM
Transmission Fluid heating up neil.ervin Tow Vehicles 14 01-07-2005 08:33 PM
Washer Fluid Connection '93 Legacy danwhite84 Land Yacht/Legacy Motorhomes 1 01-01-2005 06:16 AM
Grey water deodorizer fluid needed lbrodsky Waste Systems, Tanks & Totes 5 08-27-2003 08:28 AM
