Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Mechanics Corner - Engines, Transmission & More...
Old 06-24-2015, 01:11 PM   #41
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
Here is what Racor sells for use on our turbine series fuel filters.
Engineering Bulletin
RK23284
(500, 900 and 1000 Turbine Series Stainless Steel T-handle/Vacuum Gauge Kit)
Beginning July 2013, Racor will introduce our redesigned Turbine Series T-handle /vacuum gauge kit. The new T-handle will be made of 304 stainless steel and can be removed or installed without tools. Previously, the ‘T-handle’ adapter was made from 3/4" hexagonal brass stock which required a wrench during servicing.
This new design fits all 500, 900 and 1000 Turbine Series fuel filter/water separators. The T-handle has a top 1/4" NPT port to accept our #11-1676 vacuum gage.
Additionally, this kit has been accepted for use on our Underwriters Laboratories Marine Listed turbine series (MA versions).
To use this kit, simply install the supplied vacuum gage into the provided T-handle. Next, remove the existing Racor filter T-handle (brass or stainless steel) and install your new T-handle/Vacuum Gage. It’s that easy!
In use, the vacuum gage shows what the fuel system restriction is. With the resettable ‘tell-tail’ pointer, the engine does not have to be running to see the restriction; the gauge pointer follows the active needle and rests at the highest reading all the time. As the tell-tail pointer enters higher restriction levels (yellow zone or about 10 inHg.) you can easily see that the element is getting plugged with contaminants. Servicing the filter before the needle reads much higher virtually eliminates problems such as hard starting, stalling or a loss of engine power. This also gets the most life from your filter cartridge (always keep a spare new cartridge with you).
Features/Benefits
• No tools required
• 304 stainless steel
• Superior corrosion
resistance
• Reverse compatable toolder models
• UL approved for use on marine listed models
Contact Information
Parker Hannifin Corporation
Racor Division
P.O. Box 3208
3400 Finch Road
Modesto, CA 95353
Phone 800 344 3286 209 521 7860
Fax 209 529 3278
Email racor@parker.com
Web parker.com/racor
Cheers, Dan
~ Margaret Thatcher ~
Smartstream is online now   Reply With Quote
Old 06-25-2015, 10:53 PM   #42
SebasSF's Avatar
1991 30' Airstream 30
San Francisco , California
Great info guys! I went and took a look at my fuel filter. Looks industrial with a clear bowl on the bottom that can be drained. Can you see water vs diesel if there is some in the bowl?Click image for larger version
Name:	ImageUploadedByAirstream Forums1435294430.856675.jpg
SebasSF is offline   Reply With Quote
Old 06-25-2015, 10:55 PM   #43
SebasSF's Avatar
Any comments on the above unit...good one or not?
Old 06-26-2015, 01:40 AM   #44
It's a good size filter rated at 10 micron. I'm not sure how it is used on your coach. Is it set up as a primary or secondary filter and if so what are the other filters? Yes you can see water in the bowl if present. It will separate from the fuel and settle at the bottom and is pretty obvious unless there is enough to completely fill the bowl. At that point you won't see the two fluids and it is difficult to tell the color through the tinted bowl. If you drain a little fluid off then you will know for sure.
Your filter is a Fleetguard but you can get crossovers from Wix, NAPA, Baldwin or whoever you choose. You should also be able to get it in different micron ratings.
Cheers, Dan
Old 06-26-2015, 04:14 AM   #45
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
I should be getting my new bowl delivered today. Hopefully its the right one. Wondering now if I should have just replaced the whole unit.
mayco is offline   Reply With Quote
Old 06-26-2015, 08:14 AM   #46
1995 36' Classic 36
Ludington , Michigan
The sumps get checked regularly on aircraft.
Name:   ImageUploadedByAirstream Forums1435327489.951501.jpg
I've replaced my filters with solid ones that just have a drain cock on the bottom. No site bowl. I cut a notch in aircraft fuel tested that makes it easy to open the cock and catch a sample. It's actually easier than crawling under to see what's in the bowl and more thorough. And nothing to leak.
Just a thought!
Kota is offline   Reply With Quote
Old 06-26-2015, 09:01 AM   #47
mayco's Avatar
I believe the Airstream manual suggests inspecting with each fill up.
Old 06-26-2015, 09:50 AM   #48
1995 36' Classic 36
Good to check it often but you won't see anything until the new fuel settles and travels through the system. I check mine before the first drive of the day as I check the oil, tires, leaks, and lockers... Habits from flying!
Old 06-26-2015, 10:27 AM   #49
mayco's Avatar
Good habit, thanks for the info Kota. Wife and I are talking about coming out to FOCO over Christmas. Split some time between son in Fort Collins and daughter down in Denver. Driving the 310 out. Fort Collins seems pretty liberal about parking, parked in the street at my sons house before the moho get together. Then get a spot at Golden's white water park. My daughter lives in the LOHI neighborhood and its a straight shot down 32nd street from Golden. Have never spent the holidays out there, hope we can pull it off.
Old 06-26-2015, 10:34 AM   #50
1995 36' Classic 36
MAYCO, broke down on the road need advice
A couple years ago I went to Ft Collins to inspect a 360 Classic Gas for a guy. The owners son set it up at a pretty nice KOA on the northwest corner of town.
For the Christmas holidays I'd bring shorts, a down parka, golf clubs, snow shoes, bicycles, and a snow shovel! You've experienced CO weather!
Old 06-26-2015, 11:57 AM   #51
mayco's Avatar
Aint that the truth!!
Old 06-27-2015, 12:07 PM   #52
mayco's Avatar
Installed the new sight bowl this morning, easy job but a little messy on your back refilling the canister with diesel fuel. While I was at it I pulled and cleaned the little turbine mechanism. It unscrews by hand. Inspected and reinstalled. Racor part number for the replacement sight bowl for the 500fg is RK15405.
This unit is referred to as a "turbine" series. After priming the unit and replacing the filter she started right up no problems. QUESTION: to me, turbine means "spin" in most all cases I can think of. After I started her up I watched the sight bowl and did not see the turbine spinning inside the fuel. Hmmm. Like I said, I had pulled and cleaned the turbine from the unit while I had it apart as per the instructions that came with the replacement bowl. Should the turbine be spinning ALL THE TIME when the engine is running??? Tried to find info or a video on just how the turbine series works but no luck. Anyone with more knowledge about these care to share?
Thank you as always,
Mike
Old 06-27-2015, 12:33 PM   #53
Mike it doesn't spin it just sends the fuel out in a swirling motion spinning the heaver particles and water to the outside separating from the fuel and settling to the bottom of the bowl. Here is their "technical" explanation.
Turbine Series filter assemblies are designed to be installed on the vacuum side of the fuel transfer pump for best efficiency and protect precision engine components from dirt, rust, algae, asphaltines, varnishes, and especially water, which is prevalent in engine fuels.
This filter removes contaminates from fuel using the following legendary three stage process:
  • Stage One: Separation : As fuel enters the filter assembly, it moves through the centrifuge and spins off large solids and water droplets which fall to the bottom of the collection bowl.
  • Stage Two: Coalescing : Small water droplets bead-up on the surface of the conical baffle and cartridge element. When heavy enough, they too fall to the bottom of the bowl.
  • Stage Three: Filtration : Proprietary Aquabloc®II cartridge elements repel water and remove contaminants from fuel down to two micron (nominal). They are waterproof and effective longer then water absorbing elements.
It is certainly a lot of marketing talk but this filter has been around for a long time unchanged and they do the job. I have two of these on my boat since the 70's and you would be amazed at the crap I have drained out of those bowls.
Cheers, Dan
Old 06-27-2015, 12:41 PM   #54
mayco's Avatar
Ahhhhhhhhhh, I get it. Thanks Dan, makes sense now. I was thinking along those same lines but thought it might spin as the fuel passed through it. Creating centrifical force to throw the particles to the outside of the bowl and then sink to the bottom. Well good to know that I didnt screw something up during the repair.
Thanks again,
Mike
Old 06-27-2015, 03:30 PM   #55
1981 28' Airstream 280
Atlanta , Georgia
When I bought my isuzu excella in the north Carolina mountains it hadn't run in years, wouldn't start, and I couldn't find anyone within 50 miles willing to tow it. Figuring that the fuel tank was full of crud, I got a 5 gallon plastic fuel can, filled it with clean disel, strapped it up front next to the passengers seat and ran clear plastic tubing to the engine hand pump. Bypassed the Racor which was also full of crud. Also ran a clear tube from the fuel return line back into the 5 gal can. The clear tubing let me see if air bubbles were in the lines and whether the fuel was clear. After getting the hand pump working (whole different story) and pumped the air out, its started right away and I was able to drive it 70 miles or so home.
ArtFJ1 is offline   Reply With Quote
Old 06-27-2015, 03:46 PM   #56
mayco's Avatar
Very cool and great field expediency!
Old 06-27-2015, 10:05 PM   #57
1995 36' Classic 36
These are a bit overkill for the 4 to 5 gallon per hour we run. Not much "turbine" action at that rate. They would work as designed at closest to the 60 gallon per rate. The bigger canisters do have the ability to sequester more crud.
MAYCO's 1982 310 TD mayco Classic Motorhomes 2203 07-05-2023 08:58 PM
Goin' down, down, down... Aironius Axles 12 08-23-2014 08:09 AM
1994 Land Yacht diesel pusher broke down need advice mhpkate General Repair Forum 4 03-18-2014 07:49 AM
Broke Down on the Road in Sturgis SD rklies Our Community 2 08-06-2006 01:39 PM
