Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Mechanics Corner - Engines, Transmission & More...
Old 12-22-2004, 06:31 PM   #1
ALANSD
GA Airstreamer Air_005
Profile:  North , Georgia
Manifold..or
I have burnt my right front spark plug wire thru twice in recent trips.This past trip took 350 miles to fry thru an Accel wire. This plug is the only one that is missing a heat shield so that seems likely to be the cause, although his never happened before in three years of travel. I also notice a slight ticking which I think might be a manifold or gasket leak,, the manifold was replaced twenty thousand miles or so ago, and looks to be in good shape..but it could have a small leak right below the plug boot.
Any ideas on the nest way to tell what is up with this? I would replace the manifolds with headers, but the expense is not high on my list right now.
I made it home no problem on this trip using a wrap of aluminum tape over the plug boot, loosely wrapped about four times...got us 400 miles with no issues.
Rallys twice a year..Lots of fun, food, and aluminum.
http://groups.yahoo.com/group/gaairstreamcampers/
http://airstreampassion.blogspot.com/
My Music Site:
HTTP://ALANDAVIDSONGS.COM
Old 12-22-2004, 07:26 PM   #2
thenewkid64
Just a member
thenewkid64's Avatar
Profile:  Tampa Bay , Florida
Images: 21
If the manifold is leakingyou could loosen the manifold and add an exaust gasket to help fill the gap. The other option would be to be sure the bolts are free, but tight. Start the engine to heat the manifolds then get in there and tighten the bolts.
Brett G
WBCCI #5501 AIR # 49
"Stop worrying about the potholes in the road and celebrate the journey." -- Fitzhugh Mullan
Wise men talk because they have someting to say; fools, because they have to say something. -- Plato
In politics, absurdity is not a handicap— Napoleon
Old 12-23-2004, 03:14 AM   #3
TomW
TomW's Avatar
Profile:  1967 26' Overlander
Normal , Alabama
Images: 77
I had a similar leak problem with the RH manifold on my 454 which a new gasket solved for a reasonable amount of time. Although I thought I was using a good gasket (Felpro), 59toaster, in a different post, allowed that Felpro makes different "flavors" of good.
If you go the gasket route, make sure you get a good one.
BTW, is it possible to install a new plug heat shield?
Tom
Old 12-23-2004, 05:24 AM   #4
74Argosy24MH
Profile:  LOST , Hawaii
IF you have a tick and are burning boots you doubtless have a leak. Copper gaskets are better for heat transfer and sealing. Make sure your studs are in good shape. Age, rust, several times of the nuts going on and off will wear the threads. Put a straight edge along the flange of the manifold and see if runner(s) are warped or twisted. Use new good hardware and antisieze on the studs. Torque is 20 ft. lbs., it is easy to over tighten.
John
74Argosy24MH is offline   Reply With Quote
Old 12-23-2004, 06:13 AM   #5
john hd
john hd's Avatar
Profile:  1992 29' Excella
madison , Wisconsin
Images: 40
alan
can you make a copy of the other side heat shield out of galvanized flashing? that or head off for a visit to the boneyard for one.
if would be a perfect time to make one if you have the manifold off for new gaskets!
john
you call them ferrets, i call them weasels.
Old 12-23-2004, 06:49 AM   #6
ALANSD
Thanks, I will check the manifold and try to pull it when I get some warmer weather.
The heat shield might be able to be copied when I pull off the others, I might try to do that with some galv metal from hd if that would work.
My Music Site:
Help on engine RonJudi Mechanics Corner - Engines, Transmission & More... 67 04-04-2007 09:50 PM
Factory Headers? swebster Mechanics Corner - Engines, Transmission & More... 23 08-31-2004 03:43 PM
Right cast iron manifold free Astrodokk Airstream Motorhome Forums 1 10-19-2003 09:04 PM
Spacer on exhaust manifold needs replacing. rdm Mechanics Corner - Engines, Transmission & More... 30 11-19-2002 03:14 PM
Heat Riser ALANSD Airstream Motorhome Forums 7 09-11-2002 03:38 PM
