Old 03-31-2016, 12:36 PM   #1
1984 31' Airstream310
Cle Elum , Washington
Locked Brakes
I purchased an 1984 315 motorhome and the brakes are locked up. It has been sitting for years, I am going to pick it up Monday and need to figure out what the problem might be. I've seen a couple of posts somewhere and this seems to not be real uncommon. Any ideas? Thank you
edcsteve is offline   Reply With Quote
Old 03-31-2016, 01:16 PM   #2
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Welcome to the forum.
The cause could be brake shoes rusted to the drums, master cylinder not releasing, broken return springs, friction material separated from the mounting tables, collapsed hoses.
Old 03-31-2016, 01:49 PM   #3
shepherd57's Avatar
1985 32.5' Airstream 325
Lindsay , Ontario
That coach has all disk brakes and the rotors likely have quite a bit of rust on them. That is probably why the wheels will not turn.You may have to take the wheels off and use a long bar on the wheel studs to try and turn them.
You could try and pull it with another vehicle to break it free. Just be careful what you hook up to.
I think if there is a lot of rust you may have to maybe remove the calipers and clean off some of the rust. Not a fun job
Keep us informed on how you make out.
shepherd57 is offline   Reply With Quote
Old 03-31-2016, 01:50 PM   #4
The 310 has disc brakes front and rear so it could be pads stuck to the rotors, or the other items as Terry suggested collapsed brake hoses. My bet is on the pads being stuck to the rotors or the parking brake was set and the shoes are stuck to the drum. The parking brake is actually a brake drum with shoes attached to the back of the transmission.
If its the parking brake you'll have to figure out a way to get the shoes to release. Working from memory I seem to recall that the cable coming from the hand lever in the cab goes straight into the drum with no place to disconnect it except inside the drum. It's been quite awhile since I've worked on the parking brake so hopefully someone with more experience will chime in with the best way to release frozen shoes.
Old 03-31-2016, 06:48 PM   #5
shepherd57's Avatar
Lindsay , Ontario
Brad I forgot about the em brake. If it is stuck you can try hitting the drum with a hammer to jar it loose
Old 04-03-2016, 05:25 AM   #6
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
WD-40 Rust release penetrant spray should do a fine job freeing the parking brake components, since you will have to rebuild them anyway.
If the pads a are stuck just from sitting you may have a more serious issues of the dreaded preloading master cylinder, which I experienced once.
1991 25' Excella Trailer
1990 25' Excella Trailer
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Old 04-03-2016, 05:46 AM   #7
Well Preserved
1993 21' Sovereign
Verifying that condition is easy, if messy. Simply chock the wheels, and slide under the driver's side front of the motor home. Locat the two lines on the master cylinder, and loosen them slightly. If fluid squirts out, the master cylinder is at the very least partly to blame.
Old 04-03-2016, 08:19 AM   #8
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
Name:	ImageUploadedByAirstream Forums1459692328.866618.jpg
Here is a picture of the parking/emergency brake drum that sits right behind the tail of the tranny. Its works similar to regular drum brakes, shoes expand inside the drum when you apply the parking brake. Release the brake inside the cab and then, as John said, you can whack the drum with a hammer to release the shoes. If you have the hand lever type parking brake, rather then the pedal type, there is a thumb turn adjuster on the end of the lever. Back that off a couple turns before you hit the drum just to loosen the cable a bit. Good luck, hope its an easy fix.
mayco is offline   Reply With Quote
Old 04-06-2016, 08:00 AM   #9
Thumbs up
The front caliper was locked up and once they freed it all worked well. I am having the brakes and everything else checked out before I start my 2,500 mile trek back to Washington State. I'll replace all of the tires and have a lube/oil and anything else that might be needed as well. Thank you for your help. Now the real work begins. Steve
Old 04-06-2016, 08:52 AM   #10
mayco's Avatar
Good deal!
Old 04-06-2016, 09:26 AM   #11
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Carefully Popping the cap on the Master cylinder. If you hear or see fluid come out, there may be a pressurized system. If fluid is discolered then moisture has made it into the system... Not a good thing... Is there anyone near you with auto mechanical skills who can help?
Our sons once worked at "brake" Businesses. They helped folks like the poor or down on their luck (out of work) "off the clock" so that they could carry on with minimal cost. I often contributed as well. I would give them a visit.. Do not just call. Then if you want a professional fix, tell them they have the business
Peace and Blessings..
Channing
WBCCI# 30676
Old 04-06-2016, 10:32 AM   #12
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
Can't help but think of this flowchart every time I see of thread of these type.
martin300662 is offline   Reply With Quote
Old 04-06-2016, 10:36 AM   #13
1978 28' Argosy 28
These make the BEST stories. Can't wait to hear about the drive back. I'll always remember my 600 mile jont back from New Mexico with mine, and all the fun surprises along the way. That's livin. Keep us posted.
bpg_austin is offline   Reply With Quote
Old 04-07-2016, 09:47 AM   #14
Thank you, fortunately I found a mobile repair shop who could do the work for me. I had the MH towed to their shop as I did not want to trust the brakes. They took care of them and are doing some other things for me as well before I hit the road.
Help - MH Brakes Locked Up! swebster Mechanics Corner - Engines, Transmission & More... 99 07-31-2017 05:22 PM
BRAKES, BRAKES and more BRAKES Inland RV Center, In Commercial Listings 7 11-17-2009 05:56 PM
Looking for honest opinions on locked up trailer brakes. Cogen Brakes & Brake Controllers 15 06-02-2008 01:25 PM
Brakes Or No Brakes 62safari Brakes & Brake Controllers 3 01-24-2006 09:18 AM
