Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Mechanics Corner - Engines, Transmission & More...
Old 08-30-2009, 08:02 AM   #1
str8strm's Avatar
1985 34.5' Airstream 345
Tujunga , California
Location of transmission neutral switch?
the switch has failed on our 1985 Moho, we can start it by jumping the starter. Hubby is on his way to burning man and has not been able to find a mechanic.
From internet research it sounds like it might be on the tranny.
Any pictures or ideas on bypassing it would be appreciated.
thanks
Ron and Debbie Lawrence
1985 345 Motorhome...... delightfully tacky......yet unrefined
AIR 7992
str8strm is offline   Reply With Quote
Old 08-30-2009, 08:52 AM   #2
Retired.
. , At Large
If your motor home has a turbo 400, the switch will probably be on the steering column, and look like this:
Old 08-30-2009, 08:55 AM   #3
Retired.
. , At Large
The switch also controls the backup lights, which is what two of the prongs on the switch are for. For now, a short piece of wire with make spade terminals crimped on it, and shoved into the two female terminals of the pigtail will get the starter to engage, but remember, it will then start in any gear until you get it replaced.
Old 08-30-2009, 12:30 PM   #4
str8strm's Avatar
Thanks Terry
I was hoping you would be able to give us a clue.
sorry we never got to meet you when you were in So Cal
Debbie
AIR 7992
Old 08-30-2009, 01:12 PM   #5
str8strm's Avatar
Oh well, new switch did not work
He found a new switch, installed it and that did not work so he is just gonna keep crawling under it to start it til the trip is over.
He did find 2 plugs wires off and now it starts on half a crank! to say nothing of running better.
Debbie
AIR 7992
Old 08-30-2009, 01:38 PM   #6
Retired.
. , At Large
Ignition switch would be my next guess. It's mounted on top of the steering column.
Old 08-30-2009, 04:55 PM   #7
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
I have a similar problem with my truck. Until I find the time to locate and fix it I have a starter relay switch clipped to the starter. Again....it will start in ANY GEAR! All auto part stores of any worth will carry the switch. Clip the alligator clips to the starter and run the cable with the push button switch to where you don't have to crawl to. On your coach you may be able to reach up into your driver seat with it. AGAIN...IT WILL START IN ANY GEAR!
Neil.
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Old 08-30-2009, 06:21 PM   #8
1982 28' Airstream 280
Elkmont , Alabama
Solenoid for the solenoid
I replaced the starter, the neutral switch, THE switch and still it wouldn't start sometimes.
I then discovered that there is another solenoid.
It sits on the top of the engine forward of the carb, to the right a little.
It goes ignition switch/neutral switch/solenoid#1/solenoid#2/starter=voila!
Be sure to get a constant duty one from an RV house.
deltatango is offline   Reply With Quote
Non-Automatic Transmission - TH400 Warbs Mechanics Corner - Engines, Transmission & More... 11 02-12-2011 10:27 PM
Hot Ground/Neutral Reversed Snaken49 Electrical - Systems, Generators, Batteries & Solar 14 08-23-2009 03:27 PM
Open neutral diagnosis? markdoane Lights - Interior & Exterior 3 08-07-2009 07:33 PM
Transmission Trouble geodude1958 Mechanics Corner - Engines, Transmission & More... 12 08-02-2005 05:34 PM
