Old 08-08-2007, 09:13 AM   #1
guy99's Avatar
1984 31' Airstream310
Dunsmuir , California
Images: 16
Location of Horn Relay?
Anyone know where the horn relay is located on the classic motorhome?
Mine is an 84 310 Limited.
1984 310 Limited Motorhome
guy99 is offline   Reply With Quote
Old 08-08-2007, 09:55 AM   #2
Chaplain Kent's Avatar
1994 30' Excella
Milwaukee , Wisconsin
I have an air horn on Chummy the relay is mounted on the left side of the steering wheel above the floor mounted bright light switch.
Chaplain Kent
2015 Coachman Freedom Express 19RBS, Chummy IV- Ford Excursion- 7.3 Turbo-diesel
Chaplain Kent is offline   Reply With Quote
Old 08-08-2007, 10:52 AM   #3
guy99's Avatar
Images: 16
Kent,
Thanks for the reply. I have electric horns. I don't know how Airstream decided whether to install air -vs- electric horns. You don't have air brakes do you?
I'll check where you suggest.
Anyone with electric horns know where their relay is located?
Guy
Old 08-08-2007, 01:08 PM   #4
Safari64's Avatar
1964 22' Safari
Eagle River , Alaska
Sorry, I don’t know the relay location.
Can I ask a related question without stealing your thread?
Electrically what is the purpose of a horn relay?
Why not hard wire from power, through fuse, to horn with the horn button supplying the ground path like on an old car?
Does a relay somehow “boost” amperage to the horn?
Safari64 is offline   Reply With Quote
Old 08-08-2007, 01:11 PM   #5
More than one rivet loose
thecatsandi's Avatar
Los Alamos , New Mexico
yes. the relay "boosts" amperage of the horn. they can run smaller wire into the steering column.
Michelle TAC MT-0
Sarah, Snowball
Old 08-08-2007, 01:42 PM   #6
Safari64's Avatar
1964 22' Safari
Thanks Michelle,
PS:The cover worked great!
Old 08-08-2007, 02:05 PM   #7
guy99's Avatar
Images: 16
As important as the wire size is the fact that the 'switch' - i.e. horn button doesn't have to carry a lot of current (amperage) thus the switch is lighter duty and less likely to overheat or get burned contacts.
Now, anybody got a manual where they can look up the location of the horn relay?
Old 08-08-2007, 08:09 PM   #8
Guy,
I checkout out our 310 and I sure couldn't find the relay. I've been through the service manual for the coach and don't remember any references to the horn relay. The original chassis horn does work on ours so if I get time tomorrow I'll unhook the horn wire and see if I can locate the relay by listening for the clicking.
Old 08-09-2007, 05:36 PM   #9
Guy, the relay is located in the middle of the picture.
When I first tried our horn button a while back I thought the only horn that was honking was the one near the radiator. It turns out the electric horns on top actually work! I think they just need a good cleaning.
Hope the photo helps.
Old 08-09-2007, 05:45 PM   #10
guy99's Avatar
Images: 16
Thanks, Brad. Glad that your roof-top horns now work.
Old 08-10-2007, 05:40 AM   #11
1994 30' Excella
Guy,
no, I do not have air brakes but a small compressor just for the horn. This was an option by AS. Chummy was first owned by a doctor in California and he order all the bells and whistles from the factory. This one still works. Most of the gadgets have been removed.
Chaplain Kent
Old 08-12-2007, 07:25 PM   #12
guy99's Avatar
Images: 16
Attachment 42890
Brad,
Thanks again. Horns are working .
Battery Location uwe 1970-79 Tradewind 23 12-02-2015 07:41 AM
AC location - 1966 Forrest 1965 - 1969 Globetrotter 0 04-17-2004 09:07 PM
P30 VIN location dienst1 Airstream Motorhome Forums 5 01-14-2003 03:11 PM
Wiring for electrical horn on 310 shelocta Airstream Motorhome Forums 3 09-03-2002 09:40 PM
