Old 11-17-2017, 01:54 PM   #15
No doubt that Superbright is a good place to shop.
I’m just throwing the options out there that I am looking at.
Glad it helps but I too got a little buried in the details. I can’t afford to buy $700 headlamps, even if they are better, but I can justiy under $100 for brighter lights, especially, the kit takes the load/resistance/voltage loss off the headlamp switch too!
Just so happens there is a perfect place to plug the headlamp feed in, right on the bulkhead!
Keyair is online now   Reply With Quote
Old 11-18-2017, 04:57 PM   #16
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
Got the lights delivered today. The weather turned to total crap this morning so didn't get to work on them. I did go out and slip one into place to see if it would physically fit into the headlight bucket without any mods. Indeed it did, that was my biggest concern with installation. So that's cool. If the weather lightens up tomorrow I'll try and get one set installed. While I'm at it I'm going to trace down the grounds for each light and clean those up.
Any of you able to point me in the right direction to find where the grounds terminate on the headlights? I think they are usually fairly near the lights, I'll poke around and see what I can find. I'd like to do that first before proceeding with installing the lights.
Mike
mayco is offline   Reply With Quote
Old 11-18-2017, 05:38 PM   #17
Sweet!
Old 11-19-2017, 04:44 PM   #18
mayco's Avatar
So I installed the low and high beam headlamps on the drivers side today and HOLY CRAP! It was hard to get pics because the low beams were so bright. I didn't even try to take any pics with the high beams on. I guess the pictures speak for themselves, I should have taken some from inside the cab, maybe later. But man, what a difference. The install wasn't bad though it is a tight fit with the connectors on the back. They are DOT approved and stamped.
ID:	299467Click image for larger version
This one from across the street up into the neighbors driveway, rig is parked about 40' up in my driveway.
Wow, from inside the cab it's an unbelievable difference.
Old 11-19-2017, 05:04 PM   #19
Wow, Those pictures don't lie!
Old 11-19-2017, 05:53 PM   #20
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
Don't forget the B/U lights, they were a big improvement on our Burb AND AS.
ID:	299471   Click image for larger version
Instead of going to íStarbucksÖI make my own Coffee at home, yell out my name rong, then light a five dollar bill on🔥
"The hardest thing about Airstreaming, clearing your head and accepting how others feel itís supposed to be done"Ö..
Amanamus
"Tahawus"
Old 11-19-2017, 05:56 PM   #21
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Measure the voltage at the headlamp. The difference in light output with incandescent is 80% from 11 to 13+.
So this difference may be as much due to Moho electrical system deterioration as to the more efficient LED.
Use an E-Code aiming chart transposed onto a wall. I've done that with every personal vehicle and Class 8 tractor the past twenty years. It's a noticeable difference.
See www.danielsternlighting.com for that link in the Tech section (which has other worthwhile projects).
Old 11-19-2017, 05:56 PM   #22
mayco's Avatar
No doubt Bob. I already have taken care of the B/U lights but good point absolutely.
Old 11-20-2017, 01:06 AM   #23
Boom Sounds's Avatar
1991 25' Airstream 250
Oxford , Oxfordshire
Brilliant in every respect. Iíll never forget driving our coach from Northern California to Houston. Took three weeks in March through deserted interstates and some backroads. Frankly, it was terrifying in places. I was driving on the other (wrong!) side of the road and couldnít see a thing.Iíd never driven anything bigger than a small van and the stock headlights seemed little better than a good torch.
Iím in for this upgrade. Would you mind reposting the link to the ones your purchased so that I can make sure I get the correct model.
Nick
Boom Sounds is offline   Reply With Quote
Old 11-20-2017, 02:47 AM   #24
WayneG's Avatar
1984 27' Airstream 270
Scotia , New York
Which headlight set did you end up buying?
WayneG is offline   Reply With Quote
Old 11-20-2017, 04:08 AM   #25
mayco's Avatar
I measured voltage at idle before installation of the new LEDS, 12.8-13.2
I was surprised it was that good. Installed a new headlight switch last year also.
Old 11-20-2017, 04:09 AM   #26
mayco's Avatar
Nick
Old 11-20-2017, 07:36 AM   #27
Nick
Nick,
I might be wrong but if I remember correctly you need different bulbs in the UK than you do in the US. I thought the low or dipped beams were supposed to angle to the side of the road and that involves both the bulb inside and the glass housing.
At least that's how I thought the Triumph sports cars were set up. Possibly it's different now or I just don't understand how headlights are supposed to work!
Old 11-20-2017, 07:40 AM   #28
Originally Posted by mayco View Post
Martin, do you want these in Peanut?
LED Tow Vehicle to LED Trailer Problems murreywalker Hitches, Couplers & Balls 25 09-10-2012 03:42 PM
To LED or not to LED? SilverHoot Lights - Interior & Exterior 56 10-03-2011 12:15 PM
Clipper, Hella LED, Design Line Hella, LED Kit, Stop/turn LED masseyfarm Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 1 12-15-2010 11:03 AM
