Old 01-05-2006, 06:28 PM   #15
noiva's Avatar
Chesapeake , Virginia
Images: 46
Originally Posted by Tinsel Loaf
Usually they are flair fittings and do not use o rings. Tighten them just till they are snug then turn one flat. That should do it. Over tighten and you may damage the male threads and the flair.
I'm not sure but I think I've got it. Terry's info on how to loosen the first nut and then the hose nut seems to have done the trick. Haven't tested it yet because I'm in the middle of replacing all the hot water hoses on the engine and back to the auxiliary heater. The heater hoses are pushing 17 years old, and I don't want to fill the inside of my coach with hot coolant, nor dump all the coolant in the highway without knowing it. I'm also adding shut-offs to the send and return hoses for both the dash heat and the auxiliary. I'm putting them at the engine so I can cut them off in the warmer weather saving both unnecessary heat inside the coach, and the potential of a leak. I appreciate the info on the flair fittings. Hadn't even thought of that, but if this repair works, I'll save examining the fitting for another leak . I appreciate the advice.
Tim
noiva is offline   Reply With Quote
new water lines Rob Fresh Water Systems 29 07-11-2006 08:25 PM
Steering Stabilizer rdm Mechanics Corner - Engines, Transmission & More... 2 09-17-2004 06:03 PM
Exterior gas LP lines 83Excella LP Gas, Piping, Tanks & Regulators 1 05-23-2002 01:06 PM
Replace copper water lines in '61 Bambi 61BambiCanada Fresh Water Systems 1 05-22-2002 06:04 AM
Hydraulic Brake Replacement DanLyle Brakes & Brake Controllers 2 03-26-2002 05:02 PM
