Old 11-10-2002, 07:54 PM   #1
rdm
rdm's Avatar
Question Kohler Fuel shutoff problems
Our kohler 7000 fuel shutoff does not shut the fuel supply off quickly when the stop switch is applied. The result is running on of the generator has anyone else had this problem and what will fix the problem.
Ray
rdm is offline   Reply With Quote
Old 11-11-2002, 04:56 AM   #2
LOST , Hawaii
Doesn't shut the fuel off quickly or the generator doesn't stop quickly? I have an Onan, it grounds the ignition in stop and shuts off 12v electrical to the generator (ignition, fuel pump) in off. It takes a few seconds to stop, the whole rotating mass of the generator has to coast down. If it takes 4 or 5 seconds to do this it is probably OK.
John
74Argosy24MH is offline   Reply With Quote
Old 11-11-2002, 05:22 AM   #3
ViewRVs's Avatar
1977 20' Argosy 20
Charleston , West Virginia
Send a message via Yahoo to ViewRVs
The Kohler 7000 has a shutdown solenoid (sp?) device that closes the carb. My 7000 has had that problem since I bought the MH a year ago. I sprayed a little WD-40 on the shut-down mechanism and it works much better.
With the generator cold, use the manual switch on the generator itself and switch it to STOP a few times. You will see the mechanism pull back. Hit that with some WD-40 and see if it helps. It may need some adjustment (there are several on that mechanism). If it doesn't pull back at all, the shutdown solenoid needs replacing.
Fred H.
1977 Argosy 20' Motorhome
Fred's Airstream Archives @ ViewRVs.com
ViewRVs is offline   Reply With Quote
Old 11-12-2002, 05:46 PM   #4
rdm
rdm's Avatar
Thumbs up Many thanks for the help!!
Fred,
I tried your suggestion and applied some liquid film to the solenoid shaft and it seems to have fix the problem.
for your information the new part is still available from kohler for a cost of $140.00 for the solenoid only.
Thanks again
Ray
Old 11-12-2002, 06:58 PM   #5
ViewRVs's Avatar
1977 20' Argosy 20
Boy, I sure hope Peter reads that! I actually helped someone with a technical problem! I am delighted that I could finally contribute to the community!
Fred H.
Old 11-12-2002, 07:11 PM   #6
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
Yup, I was reading Ray's message and thought to myself:
Check out that Fred, I am so proud of him, just hope he won't blow it now. Oh well...
1991 25' Excella Trailer
1990 25' Excella Trailer
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Onan Fuel Pump swebster Mechanics Corner - Engines, Transmission & More... 20 11-06-2003 04:35 PM
Kohler generator fuel filter ViewRVs Mechanics Corner - Engines, Transmission & More... 3 08-23-2003 06:17 AM
Trip report (fuel filter issues) PeterH-Airstreamer Airstream Motorhome Forums 10 08-01-2003 05:57 AM
Electric fuel pump and fuel line routing cooperhawk Mechanics Corner - Engines, Transmission & More... 7 02-06-2003 10:16 AM
fuel pressure PeterH-Airstreamer Mechanics Corner - Engines, Transmission & More... 3 06-09-2002 08:40 PM
