Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums > Mechanics Corner - Engines, Transmission & More...
Old 11-10-2006, 08:17 PM   #1
INSANITY CENTRAL
doorgunner's Avatar
Profile:  1986 32' Excella
1973 29' Ambassador
Lodi , Ca. U.S.A.
Images: 35
Key Stuck In Ignition
Motor running need fast help Tim
www.popasmoke.com
Proud Appellation American
Vine View Heights, by appointment only
YETI ( 65 Quart )
IGLOO (Ice Cube, 50 Quart )
doorgunner is offline   Reply With Quote
Old 11-10-2006, 08:22 PM   #2
Well-Preserved
overlander63's Avatar
Profile:  1974 31' Sovereign
Somewhere , Over the Rainbow
Unplug the coil lead providing 12 volts to it.
(No Longer at Inland RV)
Old 11-10-2006, 08:24 PM   #3
Fyrzowt's Avatar
Profile:  2000 25' Safari
Templeton , California
Images: 8
Or pull the fuse to the fuel pump.
Fyrzowt is offline   Reply With Quote
Old 11-10-2006, 08:24 PM   #4
INSANITY CENTRAL
doorgunner's Avatar
1973 29' Ambassador
Lodi , Ca. U.S.A.
Images: 35
pulled the breaker disconnected the battery, problem is how do I fix the switch assy. Dealer item? Anyone done this before?oh it's my TV 93 burb and I need to tow something tomorrow!
www.popasmoke.com
YETI ( 65 Quart )
Old 11-10-2006, 08:26 PM   #5
Profile:  , Minnesota
Images: 59
Airstream Registry
Happened to my Audi. Cost $700 for a new ignition switch.
Old 11-10-2006, 08:28 PM   #6
Fyrzowt's Avatar
Images: 8
Looking at your signature line....this is a crisis - make sure you break GROUND, just don't do it backwards.
What kind of vehicle is this?
Oh never mind, I type too slow, someone answered.
Old 11-10-2006, 08:29 PM   #7
INSANITY CENTRAL
doorgunner's Avatar
1973 29' Ambassador
Lodi , Ca. U.S.A.
Images: 35
glad none of thet fine german enginnering isn't involved here!
www.popasmoke.com
YETI ( 65 Quart )
Old 11-10-2006, 08:29 PM   #8
INSANITY CENTRAL
doorgunner's Avatar
1973 29' Ambassador
Lodi , Ca. U.S.A.
Images: 35
93 burb
www.popasmoke.com
YETI ( 65 Quart )
Old 11-10-2006, 08:31 PM   #9
Fyrzowt's Avatar
Images: 8
Not to ask the obvious here, Your steering wheel isn't locked against the lock cylindar? Try moving the wheel as you turn the key.
Old 11-10-2006, 08:33 PM   #10
INSANITY CENTRAL
doorgunner's Avatar
1973 29' Ambassador
Lodi , Ca. U.S.A.
Images: 35
tried all that stuff, rig shut down till daylight. But I gotta get it going . I'm trying to guess what is involved with replacing the key switch assy
www.popasmoke.com
YETI ( 65 Quart )
Old 11-10-2006, 08:33 PM   #11
Well-Preserved
Originally Posted by doorgunner
93 burb
You'll have to disassemble the column to get the broken lock out. With any luck, all you will have to take off will be the steering wheel, turn signal switch, and a torx or philips head screw holding the lock in place. If it doesn't come right out, you will need to go a little further to move the broken end back so it will slide out of the hole.
Old 11-10-2006, 08:35 PM   #12
INSANITY CENTRAL
doorgunner's Avatar
1973 29' Ambassador
Lodi , Ca. U.S.A.
Images: 35
Well thats all doable by me, Would the replacement be a dealer item, Thanks Terry
www.popasmoke.com
YETI ( 65 Quart )
Old 11-10-2006, 08:36 PM   #13
Well-Preserved
If it isn't the lock, and I've seen a couple that weren't, there are two pot-metal pieces that can break and cause this. Hope that isn't what it is, they are a pain. They are the rack and pinion that the lock cylinder turns to actuate the switch rod.
Old 11-10-2006, 08:36 PM   #14
Well-Preserved
No, any good auto parts store will have a lock cylinder with keys.
Vote on lost key return service 66TradeWind Community Polls 12 05-01-2009 10:28 AM
wanted key blank for 69 Overlander bgow 1969 Overlander 1 10-02-2002 10:44 AM
Water inlet key replacement Road Ruler Fresh Water Systems 7 09-03-2002 09:07 PM
Stuck Numbers? Mr Jody Hudson Forum How-To's & Support 0 07-31-2002 10:13 PM
door key tomb Doors & Locks 8 07-17-2002 11:16 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
