Old 11-10-2006, 08:40 PM   #15
INSANITY CENTRAL
doorgunner's Avatar
1986 32' Excella
2014 Interstate Ext. Coach
Citrus Heights , California
Images: 35
O.K. I guess
i'll be able to sleep tonite. Thanks for the immediate help. Just need to find my steering wheel puller> Thanks again
www.popasmoke.com
Proud Appellation American
Vine View Heights is now closed.
YETI ( 65 Quart )
IGLOO (Ice Cube, 50 Quart )
doorgunner is offline   Reply With Quote
Old 11-10-2006, 09:14 PM   #16
RichardT's Avatar
Same thing happened on my 1992 Gmc jimmy, I bought part at Advance cheap and fixed it in the parking lot.
I also had to change both door key cylinders and that was cheap and easy too!
RichardT
RichardT is offline   Reply With Quote
Old 11-11-2006, 05:47 AM   #17
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
I had that happen to a 1985 GMC P/U. Local mechanic fixed it for me, can't remember the cost.
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 11-11-2006, 10:39 AM   #18
1960 24' Tradewind
santa barbara , California
Tim you'll have to get a tool for the tilt /lock plate to depress it to remove the small wire lock ring ,a pain to get it off ,the turn signal canceler harness
at the lower part of the dash needs to be unplugged to give the canceler some slack to pull it up abit to access the Torx screw that retains the lock cylinder, you won't have to go any deeper into the column unless the rack
is broke ,but that results in a different problem/symptoms,not related to it not turning .Like I PMd ,if you have a non tilt column the better /easier to
do .If you don't without the lock plate tool and try to do it without ,it'll be near
impossible to get the wire lock ring back on as the spring under the plate will fight you and the column shaft wants to also move down ,the tool is pretty cheap to buy ,then you'll have it for next time .
Scott
scottanlily is offline   Reply With Quote
Old 11-12-2006, 11:54 AM   #19
INSANITY CENTRAL
doorgunner's Avatar
1986 32' Excella
Images: 35
+Scott; Thanks for the info,I removed the steering wheel and then found the dreaded C clip. Tried the two handed screwdriver approach- NOT. Jusy picked up a steering wheel lock plate remover tool for $9.99. Will post a pictoral process of replacement of switch later tonite. Tim
www.popasmoke.com
YETI ( 65 Quart )
Old 11-12-2006, 05:40 PM   #20
INSANITY CENTRAL
doorgunner's Avatar
1986 32' Excella
Images: 35
It WORKS!
Yup got er done! I was a little leary of doing this myself but a few members encouraged my on. Thanks guys. Explaining how to do this relatively simple task follows. Remove steering wheel. Use a puller for this. luckily I own one!
Name:	93 Burb Tow Vehicle 010.jpg
ID:	28551   Click image for larger version
Name:	93 Burb Tow Vehicle 001.jpg
www.popasmoke.com
YETI ( 65 Quart )
Old 11-12-2006, 05:51 PM   #21
INSANITY CENTRAL
doorgunner's Avatar
1986 32' Excella
Images: 35
Wheel removed you can see a round plate that is removerd by removing torx screws at 8 and 11 oclock positions. Fiddle around with this plate to remove it, remove the horn wire, and the 4 way flasher knob(on outside of column). That reveals the spring hold down plate.Attach the retainer removal tool ($9.95) to the shaft. As you tighten down the wing nit the retainer plate moves in to expose the C clip. Use a pick to lift the C clip up onto the shaft.Remove the screw that goes to the turn signal lever.
Name:	93 Burb Tow Vehicle 003.jpg
ID:	28554   Click image for larger version
Name:	93 Burb Tow Vehicle 004.jpg
Name:	93 Burb Tow Vehicle 005.jpg
www.popasmoke.com
YETI ( 65 Quart )
Old 11-12-2006, 05:55 PM   #22
INSANITY CENTRAL
doorgunner's Avatar
1986 32' Excella
Images: 35
Slip the retainer assy over the shaft to reveal the area of concern. See the white painted torx about 1 Oclock. Remove it and slide out the bad lock assy
Name:	93 Burb Tow Vehicle 002.jpg
ID:	28557   Click image for larger version
Name:	93 Burb Tow Vehicle 007.jpg
www.popasmoke.com
YETI ( 65 Quart )
Old 11-12-2006, 06:00 PM   #23
INSANITY CENTRAL
doorgunner's Avatar
1986 32' Excella
Images: 35
Afew minor glitches here
The round plate in the last post belongs in the post before it. If you were doin it you would figure that out. Note there is a wiper contact switch blocking the white torx screw. Lift it out with a pick, it's a spring pressure type of affair. pulls out easily to expose the torx that holds the switch mechanism in.
ID:	28560   Click image for larger version
Name:	93 Burb Tow Vehicle 008.jpg
Name:	93 Burb Tow Vehicle 009.jpg
www.popasmoke.com
YETI ( 65 Quart )
Old 11-12-2006, 06:05 PM   #24
INSANITY CENTRAL
doorgunner's Avatar
1986 32' Excella
Images: 35
Pretty much done
Simply reverse the process and check all functions before goin on the road. OH yea- Remove the battery leads before doing this! It took me almost as long to post the process as it did to do the process.I hope this helps all others that may incure this problem, The switch was $19.98. Tools needed below. Tim
Name:	93 Burb Tow Vehicle 011.jpg
www.popasmoke.com
YETI ( 65 Quart )
Old 11-12-2006, 06:17 PM   #25
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Looks like it was all in a Sunday's work, Tim. If you're not careful, we'll have you rebuilding your own transmission before long.
Old 11-12-2006, 06:39 PM   #26
Fyrzowt's Avatar
2000 25' Safari
West of Fort Worth , Texas
Images: 8
Tim,
Great step by step post, great photos.
Dave
Fyrzowt is offline   Reply With Quote
Old 11-12-2006, 07:17 PM   #27
1960 24' Tradewind
Tim good job ,and I didn't have to tell you about the plastic piece with the copper strips in front of the torx screw ,that can fight you sometimes to seat back in right (your key in ign buzzer contact ),without that cool tool its a night mare ,sometimes also if your canceler lever doesn't come back after a turn ,those small flat coil springs mounted in the canceler can break .They have them at the dealer separate so easy to replace when the lock plate is
off and they cheap to buy. Now lets get back to the diesel conversion !
Scott
wanted key blank for 69 Overlander bgow 1969 Overlander 4 10-04-2015 11:15 PM
Vote on lost key return service 66TradeWind Community Polls 12 05-01-2009 10:28 AM
Water inlet key replacement Road Ruler Fresh Water Systems 7 09-03-2002 09:07 PM
Stuck Numbers? Mr Jody Hudson Forum Admin, News and Member Account Info 0 07-31-2002 10:13 PM
door key tomb Doors & Locks 8 07-17-2002 11:16 AM
